Kia Sportage 2008 Passenger Doors Won't Open From Inside but Open Outside
Eskulap120 30957 4
  • #1 14957403
    Eskulap120
    Rate: 22
    I have a problem with the doors in my car, they do not open from the passenger side, but they can be opened from the outside without any problems. Car Kia Sportage 2008. How to solve this problem?
  • #2 14957476
    LordBlick
    Help: 549
    Rate: 69
    The rear doors usually have a child lock to prevent opening while driving. Look for a small lever near the lock mechanism when the door is open.
  • #3 14957491
    Eskulap120
    Rate: 22
    I checked it and it is in the unlocked position. I checked its operation in the second door and it works properly, that is, it locks the door and unlocks it after pulling it back, but unfortunately in those cases the locked or unlocked position does nothing. The door won`t open :-/
  • #4 14957584
    LordBlick
    Help: 549
    Rate: 69
    In that case, I would first look for the cause in the malfunction of this lock. It won`t be possible without tools and removing the upholstery.
  • #5 15125456
    Szymon111969
    Rate: 8
    Hello. If you can open the door from the outside and there is no reaction to the "childproof" lock, then in my opinion the mounting or the rod connecting the handle to the lock has broken. These are most often plastic clips and perhaps one of them broke or "jumped" out of the mounting. Only by removing the upholstery can you find out what is causing the problem. Regards.
