Seat Leon 2010 - The pilot does not open the door on the driver and passenger si
anusek 9840 3
  • #1 16713583
    anusek
    Help: 6
    Rate: 150
    Hello, the problem is the subject. The car does not open to the remote control. After pressing the button on the remote control, you can hear that the engines are working, but the door unfortunately does not open (the car can be opened from inside). I checked the installation and everything looks ok. There are nowhere broken wires. Do you often have problems with damaged locks in this car, like in VW, Seat and Audi? Someone encountered a similar defect? What could be the reason?
  • #2 16713606
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    After all, this buddy is all folded into one piece ;) You forgot about Skoda yet :)
    The only problem is with the driver's door? The rest opens / closes correctly?
  • #3 16713613
    anusek
    Help: 6
    Rate: 150
    Right side front / back. With older models I had to do, but there was no actuator (and here you can clearly hear it in the castle). I wonder here that the car is "only" 7 years old for this fault.
    Added after 8 [hours] 51 [minutes]:
    There are two motors in the castle. The one from opening only closes the car, and no longer opens it. Someone has a diagram so that I can check for voltages
  • #4 16756284
    anusek
    Help: 6
    Rate: 150
    I understand that nobody will help? I would need a place where there should be a signal to the second engine where to look for it?
