Selection of the drilling diameter for the screws for the furniture board?
tomybb 42636 5
  • #1 14989337
    tomybb
    Rate: 1794
    I am interested in the diameters of holes to be drilled for wood screws (the pointed ones) in a 18mm furniture board - screws with an outer diameter of 4mm, the screws will be screwed in perpendicularly and parallel to the edge of the board. You can do without drilling, but you don't want to do it.
  • #2 14989426
    rys57
    Moderator
    Help: 212
    Rate: 436
    From my practice: Take a caliper. Measure the screw between the turns. This will be the diameter of the hole.
  • #3 14989606
  • #4 14989627
    mikke2
    Help: 11
    Rate: 61
    For my eye, a drill with a diameter of about 2.5 mm will be a good one.
  • #5 14993137
    mietek440
    Level 19  
    Help: 15
    Rate: 200
    Screws called confirmates are intended for such boards
    There are special drill bits for these screws Selection of the drilling diameter for the screws for the furniture board?
  • #6 15112216
    tomybb
    Rate: 1794
    mietek440 wrote:
    screws called confirmates are intended for such boards
    So much so that when it comes to joining two boards at right angles, I don't mean something like that ...
    These are not confirmatory drills.
    In summary, you can take the diameter of the screw core, but it is best to do a few tests, a lot also depends on the place of screwing, i.e. in the edge of the board or in the forehead, distance from the edge, tightening force and length of the screw.
