Screw Won't Go Into Stud: Issues with Drill Size and Dowel Fit
kszostak_ 14532 18
  • #1 11504745
    kszostak_
    The question is trivial but please help,
    I drill a hole in the wall some brick some concrete on the way, Drill 10, dowels + screws included for this size drill.
    The dowel goes in without a problem while the screw does not... neither with a screwdriver nor by hand. It just goes in very hard it went in maybe 20% I tapped a little with a hammer but even so it does not go all the way in, The screw has a thread at 60%. On the packaging of the screws it says: "PULLER WITH DRILL" so it is definitely screwed in and it's a set so it's a waste that the pins are too narrow. It can drill larger holes but since on the package I have drawn a drill bit 10 is.... This is stupidity
    Please help. :cry: .
  • #2 11504754
    Tomix C
    Help: 7
    Rate: 16
    Drill in hand and ream a little but not too much because the pin will spin.
    Good luck.
  • #3 11504777
    kszostak_
    That's what I thought but in the end drill 10tka rally so they should give 11;]
  • #4 11504848
    robokop
    Help: 1763
    Rate: 6371
    Show a photo of both the dowel and the screw. A good quality screw should screw in without a problem - or even break off when the breakaway torque is exceeded, if the dowel hole is too tight.
  • #5 11504956
    c4r0
    Level 36  
    Help: 155
    Rate: 565
    If it's brick and concrete then twist a little more with this drill 10 and it will get looser. If you correct with the 11 you may need a second hole next to it later....
  • #6 11505021
    kszostak_
    photo, further the screw does not go in even if there is no peg in the wall.
    Moderated By ANUBIS:
    3.3. The user shall immediately follow the instructions of the moderator.
    Please correct the post by editing correctly insert photo(s).
    According to >>>Instruction for posting and editing images on the forum >> To view the material on this forum you must be logged in.
    ANUBIS
  • #7 11505037
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    The threads in this screw are a little too sharp.
  • #8 11505072
    kszostak_
    This is a set screw + pin.
  • #9 11505075
    Tomix C
    Help: 7
    Rate: 16
    By any chance, isn't this a hollow peg?
  • #10 11505092
    Błażej
    Help: 1923
    Rate: 3626
    This is a peg, for hollow spaces. The screw is to attract its end and flare the middle part. It can do as a strut from poverty, but there are more appropriate ones for that. Sharp threads in the screw should make it easier for the screw to cut into the stud. So, author - you're doing such a trivial thing as driving a screw wrong.
  • #11 11505301
    c4r0
    Level 36  
    Help: 155
    Rate: 565
    And in general, I think it is not a screw, but a screw :D .
  • #12 11505371
    balonika3
    Help: 1336
    Rate: 3758
    Grease the screw if only with margarine and it will go.
  • #13 11505386
    robokop
    Help: 1763
    Rate: 6371
    c4r0 wrote:
    And I don't think it's a bolt at all, but a screw :D
    God you are. Where's the difference and what's the difference?
    This is a universal caster, it needs by design a looser hole - so that either a drill 10 and "bending" sideways, or "11" - otherwise the thread will not pull the screw. In addition, you will not hang anything heavy on it.
  • #14 11505881
    c4r0
    Level 36  
    Help: 155
    Rate: 565
    robokop wrote:
    God you are. Where is the difference and so what?
    Thank you :) And, just like that, I wanted to attach for no reason ;) To view the material on this forum you must be logged in. To view the material on this forum you must be logged in.
  • #15 11506041
    kszostak_
    Well a cliché but not for someone who has no green...
    the more so that they write drill bit 10 it is about drill bit 11 and not drill bit 10, although it is clearly written 10...
    Well then I will think of something
    thx
  • #16 11506214
    robokop
    Help: 1763
    Rate: 6371
    Listen, drill "10" then insert the screw, you need to give it a healthy tap with a hammer, so that it will penetrate the dowel - this last part of solid plastic. Then with a screwdriver you just tighten it - it is important that the hole is not deeper than the length of the plastic dowel.
  • #17 11506403
    saskia
    Help: 174
    Rate: 1086
    The best thing to do is return it to the store where you bought it and look for others that vmaja a sharp bolt.
  • #18 11508713
    zimny8
    Help: 26
    Rate: 503
    By eye you can see that the screw is too long relative to the dowel, typical, drill a deeper hole, or buy a shorter screw.
  • #19 11508859
The discussion revolves around a user experiencing difficulty inserting a screw into a wall stud after drilling a hole. The user reports that while the dowel fits well, the screw does not go in easily, even when tapped with a hammer. Various responses suggest potential solutions, including reaming the hole slightly larger, ensuring the screw is appropriate for the dowel, and checking if the screw threads are too sharp. Some participants recommend using a larger drill bit (11mm instead of 10mm) to create a looser fit, while others suggest greasing the screw to facilitate insertion. The conversation also touches on the distinction between screws and dowels, with some humor about the complexity of the issue.
