Best Screws for Mounting Kitchen Cabinets on Block Wall: Thickness & Length Guide
rho_psi 24567 13
  • #1 19530584
    rho_psi
    Rate: 24
    Hello, I need to hang kitchen cabinets on a block wall. I have a mounting strip for this but I don`t know what screws to choose - thickness/length? Additionally, are washers needed for this? The cabinets themselves are heavy, and in addition to their contents, they must be solidly mounted.
  • #2 19530610
    cysiekw
    Help: 1002
    Rate: 1408
    Chemical anchor, metal anchor for hollow bricks, or dowels for hollow bricks.
  • #3 19530613
    kindlar
    Help: 914
    Rate: 1610
    What kind of hole do you have in the strip? What diameter? The screw must pass through this hole. I think that if you buy a 10x100 quick assembly, it will be enough. You drive the screw into the shirt with a hammer.
  • #4 19530666
    PawełS1717
    Help: 16
    Rate: 108
    If it was a reinforced concrete wall, you could try this solution, but you need to start the discussion about what type of block it is and then choose the appropriate dowels. Regards
  • #5 19530695
  • #6 19530747
    balonika3
    Help: 1304
    Rate: 3668
    Do you have any idea what you`re writing about? The quick assembly pin only holds together with the flange, and I don`t think there are 10mm holes in the strip. The screw itself DOES NOT HOLD in such a dowel!
  • #7 19531162
    rho_psi
    Rate: 24
    A wall made of ordinary foam blocks. I can`t find anywhere what screws to use to secure it. What do you think about 6 mm x 80 mm screws? Will they be enough?
  • #8 19533507
    PawełS1717
    Help: 16
    Rate: 108
    Use at least 10×120. Several pins for one rail, if the original rail has too few holes, you need to drill more holes. Regards
  • #9 19533883
    rafbid
    Help: 153
    Rate: 417
    Place the pins on the rail so that they are close to the cabinet handles.
  • #10 19535819
    palmus
    Help: 232
    Rate: 744
    In the case of aerated concrete, its strength is important. Dia 8 screws will be more than enough. The dowel dedicated to aerated concrete is important. A cabinet full of porcelain will hang easily on a strip with 2 screws. If there are 2-4 cabinets, you can add 1-2 more screws as a precaution.
  • #11 19536050
  • #12 19536216
    DiZMar
    Help: 2878
    Rate: 6571
    Here on the electrode, even a simple hanging of kitchen cabinets creates an academic discussion. Eh...
  • #13 19537279
  • #14 19537302
    DiZMar
    Help: 2878
    Rate: 6571
    101pawel wrote:
    I assure you that selling cash registers is not a particularly complicated procedure.
    Do I claim that it is complicated and write essays on this (cash registers) topic? After several dozen years of working in the fiscal industry, you don`t have to explain to me that it (sales and service of cash registers) is actually simple. You confirm my observation that a simple topic can be turned into a theoretically very complicated discussion (e.g. your arguments post #11 25 Jul 2021 22:42) and practice is hammer and screwdriver.
✨ To securely mount kitchen cabinets on a block wall, various screw types and lengths are recommended based on the wall material. For ordinary foam blocks, 6 mm x 80 mm screws may suffice, but 10 mm x 120 mm screws are suggested for better stability. It's crucial to use appropriate dowels, such as Fischer Duopower anchors or glued anchors with a mesh sleeve, especially for aerated concrete or silicate blocks. The mounting strip's hole diameter must accommodate the screw size, and additional screws may be necessary for heavier cabinets. Washers are not explicitly mentioned but may be considered for added support.
TL;DR: For foam‑block walls, 8×65 or 10×80 are the longest common options, and "fi6 is completely sufficient" for screw strength. Use dedicated anchors, space several fixings per rail, and place them near cabinet hangers. [Elektroda, Anonymous, post #19536050]
Why it matters: This FAQ gives DIYers clear sizes, anchor types, and placement tips to hang heavy kitchen cabinets safely on block walls.
What screws and anchors should I use for foam block (aerated concrete) kitchen cabinets?
Use dowels dedicated to aerated concrete and pair them with 8 mm screws. That combination is sufficient for typical wall cabinets. A cabinet full of porcelain can hang on a strip with two screws. If multiple cabinets share a rail, add one or two more screws. The wall’s AAC strength still matters, so avoid short or generic plugs. Keep spacing even and avoid edge distances that crumble AAC. [Elektroda, palmus, post #19535819]
Are 6×80 mm screws enough for a cabinet rail on a block wall?
For screw strength, fi6 is sufficient, but anchor length in your wall is critical. Choose the longest system length available for your anchor type. In the Duopower family, 8×65 or 10×80 are the longest sizes. If your rail slots limit screw diameter, adjust the rail holes rather than shortening anchors. As the expert said, “fi6 is completely sufficient,” provided the embedment is maximized. [Elektroda, Anonymous, post #19536050]
When should I step up to 10×120 mm fixings?
Use 10×120 when you need deeper bite in softer blocks or thicker finishes. It increases embedment and safety margin under heavy, loaded cabinets. Install several pins across one rail. If the factory rail lacks enough holes, drill more holes to expand the anchor pattern. This improves load sharing and reduces the chance of pull‑out. [Elektroda, PawełS1717, post #19533507]
Should I use “quick‑assembly” frame fixings in a slotted cabinet rail?
Avoid relying on quick‑assembly frame fixings for slotted rails. They often clamp only via the sleeve’s flange and may not match slot diameters. As one pro warned, “The screw itself DOES NOT HOLD in such a dowel!” Use anchors compatible with the wall and rail holes instead. That reduces the risk of a slip or sudden failure. [Elektroda, balonika3, post #19530747]
Do I need washers under the screw heads?
Usually no. Focus on correct hole sizing and anchor selection so the screw head bears properly on the rail. If your dowel requires fi10 screws and the rail holes are tight, enlarge the rail to 11–12 mm for clearance. That eliminates the need to ‘patch’ fit with washers and maintains proper clamping. [Elektroda, Anonymous, post #19536050]
How many anchors per suspension rail do I need?
Use several anchors along each rail to distribute loads from heavy cabinets and contents. If the rail has too few factory holes, drill more to expand the pattern. Spacing anchors regularly reduces point loads and improves safety. Bigger anchors do not replace the need for a good pattern. [Elektroda, PawełS1717, post #19533507]
Where exactly should I place the anchors along the rail?
Place fixings as close as practical to the cabinet hangers. This aligns the load path and reduces bending in the rail and wall face. It also minimizes rail flex during door operation and uneven loading. Fill remaining spans with evenly spaced anchors. [Elektroda, rafbid, post #19533883]
What if my wall is hollow brick or incomplete silicate?
Use chemical anchors with mesh sleeves for incomplete silicate or fragile, voided substrates. Alternatively, consider universal plugs like Fischer Duopower in lengths 8×65 or 10×80. Prioritize maximum usable length and proper hole sizing in the rail. Choose one system and follow its drilling and torque instructions precisely. [Elektroda, Anonymous, post #19536050]
My rail holes are 10 mm—should I enlarge them?
Yes, if you use fi10 dowels/screws, give yourself clearance for drilling tolerances. Enlarge rail holes to 11–12 mm to avoid misalignment fights. This helps keep anchors long and straight rather than compromising embedment to fit tight slots. Deburr the holes after drilling to protect finishes. [Elektroda, Anonymous, post #19536050]
How do I mount a cabinet rail on aerated concrete (AAC)?
  1. Level and mark the rail. Plan several fixings across its length.
  2. Drill the rail and wall; add extra rail holes if the factory pattern is sparse.
  3. Install long anchors and tighten to spec; recheck level before hanging cabinets. [Elektroda, PawełS1717, post #19533507]
Are 8 mm screws really enough for heavy, porcelain‑filled cabinets?
Yes, when paired with AAC‑dedicated plugs and installed correctly. “A cabinet full of porcelain will hang easily on a strip with 2 screws.” For multiple cabinets sharing one rail, add one or two screws to keep loads balanced. This keeps pull‑out and shear within safe limits for quality AAC. [Elektroda, palmus, post #19535819]
Does wall type really change the anchor choice?
Absolutely. Identify whether it’s reinforced concrete, aerated concrete, silicate, or hollow brick. Then match the dowel or anchor system to that substrate. This choice dictates drill size, embedment, and load capacity. Guessing the wall can lead to the wrong anchor and poor holding power. [Elektroda, PawełS1717, post #19530666]
Is chemical anchoring better than standard plugs here?
Use chemical anchors when the substrate is weak or voided and expansion plugs cannot grip reliably. In solid, suitable block with correct plugs, mechanical anchors are simpler and effective. Select based on wall type first, then on load and embedment needs. [Elektroda, cysiekw, post #19530610]
Any common mistakes or edge cases to avoid?
Avoid quick‑assembly frame fixings in slotted rails; they can hold only by the sleeve’s flange. That can slip under load because the screw alone does not grip the wall. Choose anchors designed for your substrate and rail geometry to prevent this edge‑case failure. [Elektroda, balonika3, post #19530747]
