Which Drill Bit Type to Use for Drilling Screw Holes in Wood?
23907 11
What type and size of drill bit should I use to drill screw holes in wood?
Use a wood drill bit, and choose the drill diameter according to the screw diameter [#18025324][#18028905] For a clean finish, use a countersink drill so the screw head sits in a recess, but do not make the hole too large or the screw will not hold properly [#18025299] For small holes in hard wood, an ordinary metal twist drill can work, while larger holes (about 8 mm and up) call for special wood drills with a different sharpening [#18025350]
  • #1 18024348
  • #2 18024378
    enhanced
    Help: 963
    Rate: 883
    hmm standard drill bits, which screws are we talking about?
  • #4 18025231
    zimny8
    Help: 26
    Rate: 503
    Now there are screws that you don't have to drill, maybe sometimes in extreme cases.
  • #5 18025299
    zworys
    Help: 519
    Rate: 573
    You have the answer in the link from post number 3. It's about a drill with a countersink - it nicely makes a recess for the screw heads. Of course, the drilled hole must not be too large in diameter because the screw will not hold properly.
  • #6 18025324
    sanfran
    Help: 963
    Rate: 3004
    Use wood drill bits to drill holes in wood. They are specially profiled.
    Conversely, using countersink screws is fun, but it can sometimes take revenge when you screw the screws into a slat that tends to break.
  • #7 18025350
    mod22
    Help: 130
    Rate: 312
    You can drill in hard wood, e.g. oak. You can drill with an ordinary metal drill and nothing will happen. Another thing with drilling larger holes, e.g. fi 8 up, you need special wood drills which, by the way, look similar to metal drills but are sharpened differently.
  • #9 18025837
    mod22
    Help: 130
    Rate: 312
    marekhab wrote:
    Buy Confirmant Drill as in the link:
    Provided that he wants to shoot confirmations, but rather furniture is not what he wants.
  • #10 18028677
  • #11 18028905
    Loker
    Help: 575
    Rate: 721
    You choose the diameter of the drill according to the screw diameter.
  • #12 18029077
    zworys
    Help: 519
    Rate: 573
    zyx12345 wrote:
    I understand that they do not produce smaller ones?
    Even 0.3 mm, by default, you will still have 2.5; 2; 1.5; 1 mm smaller diameters are rather in modeling sets (e.g. with a dremel)
To drill holes in wood for screws, wood drill bits are recommended due to their specialized profile. Countersink drill bits can create a recess for screw heads, ensuring a proper fit. The diameter of the drill bit should match the screw diameter for optimal results. While standard metal drill bits can be used for harder woods, larger holes require specific wood drills that are sharpened differently. For smaller screws, twist drills can be utilized, but the smallest sizes are typically found in modeling sets.
TL;DR: Use wood or standard twist bits sized to your screw; 0.3 mm bits exist. "Even 0.3 mm… 2.5; 2; 1.5; 1 mm." Countersink for flush heads; don’t oversize pilots. [Elektroda, zworys, post #18029077]
Why it matters: This FAQ helps DIY woodworkers choose the right bit and pilot size to avoid splitting and weak joints.
Which drill bit type should I use to drill screw holes in wood?
Use wood drill bits when drilling wood. They are specially profiled for clean, accurate holes. Drill pilots where needed, then drive the screws. Avoid aggressive countersinking in fragile slats that split easily. [Elektroda, sanfran, post #18025324]
Do I need a pilot hole, or can I drive wood screws directly?
Many modern wood screws drive without a pilot hole. In some extreme cases, predrill to avoid problems. [Elektroda, zimny8, post #18025231]
Is a 3 mm drill bit OK for all screws?
No. Match the drill diameter to the specific screw you plan to use. "You choose the diameter of the drill according to the screw diameter." A single 3 mm bit will not fit all screws. [Elektroda, Loker, post #18028905]
Are smaller than 3 mm drill bits available?
Yes. Bits are available down to 0.3 mm, including 2.5 mm, 2 mm, 1.5 mm, and 1 mm. Modeling kits often include sub‑millimeter bits that fit rotary tools like Dremel. [Elektroda, zworys, post #18029077]
How do I drill and countersink for a flush screw head?
Countersink to recess the head after drilling the pilot. A drill with a countersink "nicely makes a recess for the screw heads." Do not oversize the pilot or the screw will not hold. How‑To:
  1. Drill the pilot hole.
  2. Create the countersink recess.
  3. Drive the screw until the head sits flush. [Elektroda, zworys, post #18025299]
Can I use metal drill bits on wood?
Yes. You can drill wood, including hardwoods like oak, with ordinary metal drill bits. For larger holes, around 8 mm and up, switch to wood bits sharpened for wood. These bits look similar but have different sharpening. [Elektroda, mod22, post #18025350]
What bit should I use for 8 mm and larger holes in wood?
Use special wood drills for holes around 8 mm and larger. They look similar to metal drills but are sharpened differently. [Elektroda, mod22, post #18025350]
When should I avoid countersinking?
Avoid countersinking when driving screws into slats that tend to break. In such pieces, the countersink can "take revenge" and cause splitting. [Elektroda, sanfran, post #18025324]
Should I buy a Confirmat drill bit for general wood screws?
Buy a Confirmat drill only if you use Confirmat screws for furniture assembly. It is not the right choice for typical wood screws outside furniture work. [Elektroda, mod22, post #18025837]
What if my pilot hole ends up too big?
If the drilled hole is too large in diameter, the screw will not hold properly. Size the pilot conservatively to maintain holding strength. [Elektroda, zworys, post #18025299]
What tools are best for micro pilot holes?
Use modeling micro-bits for tiny pilots, including 1 mm and below. These sets often pair with compact rotary tools like Dremel. [Elektroda, zworys, post #18029077]
Does the screw type matter when choosing a drill bit?
Yes. Bit choice depends on the screws you plan to use, including their diameter and head. Be specific about the screws, not just the drill. [Elektroda, enhanced, post #18024378]
