Best Drill Bit Size for Expansion Plug: Using 12mm Bit or Alternative Options
oiir 104067 13
What drill bit size should I use for an expansion plug without making the hole too large?
Use a drill bit that matches the plug’s body diameter, measured at the neck rather than at any flange, so a 12 mm plug is normally drilled with a 12 mm bit; if the plug has a collar, the required hole may be smaller than 12 mm [#5459523][#5459407] Use a good, not worn drill bit and a drill with little side play so the hole does not end up larger than the bit [#5459407] For brick, one reply recommends 11 mm for a strong fixing and only enlarging it if needed [#5459410]
  • #1 5459189
    oiir
    Rate: 10
    I don't want to make a hole too big ... Use drill bit 12?
  • #2 5459244
    adamjur1
    Help: 772
    Rate: 1003
    It still depends on what material ...
    Generally like a pin or 12 mm
    If you do not want to break the hole too much, first drill ? 6mm with impact, and then 12 without impact. You'll get a bit tired but the hole will be precise. And bear in mind that what is called a stroke in a supermarket car makes only a lot of noise and the benefit of hard materials is very little.
    Greetings J.
  • #3 5459290
    dybas
    Help: 419
    Rate: 338
    You dimension your drawing wrong. The diameter of the hole should be equal to the diameter of the pin, but measured not on the flange, but on the neck. Sometimes the diameter is indicated on the pins. May be less than 12 if there is a key 13 for the bolt. Probably ?10. Do not start drilling from this diameter, it will be hard and the drill will slide off the point.
  • #4 5459316
    oiir
    Rate: 10
    I have a Bosch GSB 1600RE drill, I think it is ok, but I have no comparison to others.
    Drilling into the wall from the outside for the antenna mast clamp.
    I just don't have a drill like this yet. What type exactly to buy?
    EDIT: The drawing is from the Internet Link
  • #5 5459407
    sebastian.rak
    Help: 10
    Rate: 31
    The drill should be the same as the diameter (outer) of the pin - it should be written on it - you can also measure it with a caliper, but in the place of these "rings" in the middle of the pin, not at its end.
    In order not to make too large a hole, I suggest using decent drills (especially with this diameter) and a drill that is not too worn out - if it will have too much play (beating to the sides :) ) the hole can be "drilled" and have a larger diameter than the drill bit used.
    I guess I had the website open for a while and didn't notice that many answers ;)
  • #6 5459410
    mczapski
    Level 40  
    Help: 468
    Rate: 1658
    We have not found out what material this wall is made of. Differently with concrete, differently with bricks and differently with cellular concrete. But for a brick (not a block) and a strong fixation, I would take a diameter of 11 mm. In case of problems, zoom in. The drill is not a fortune after all.
    In the following statement, the colleague is right as long as he is sure what is dimensioned in the drawing. What if there is a collar? And there are pegs with collars. I have often managed to pull out the peg or at least turn it.
  • #8 5459523
    robokop
    Help: 1763
    Rate: 6370
    Gentlemen, are there any jokes? After all, a child from primary school knows that he drills with the same drill as the diameter of the dowel, its name says it "expansion plug" that is bursts out in the hole. Drilling with a bit of a smaller diameter will either prevent the dowel from hammering in, or the screw will twist when screwing in. And believe me, I turned a dozen or so thousand of them.
  • #9 5459532
    badboy84
    Help: 1197
    Rate: 1485
    You don't need an impactor for a brick ... and I would even turn it off so I wouldn't throw it on the other side of the hole ;) . If there are not many holes, an ordinary market drill will suffice. I even drill holes in a brick with a cordless screwdriver (18V).
  • #10 5459592
  • #11 5459613
    -Obywatel-
    Rate: 86
    Speaking of drilling and fastening in various building materials, I will go to the topic. What kind of patent would you recommend for gypsum board because an ordinary wall plug is a failure?
  • #12 5459636
    robokop
    Help: 1763
    Rate: 6370
    There are special wall plugs for k / g boards, the so-called butterflies.
  • #13 5459668
    -Obywatel-
    Rate: 86
    OK, thanks for the tip.
  • #14 5459787
    sebastian.rak
    Help: 10
    Rate: 31
    Butterflies sometimes turn when tightening (especially if the hole does not come out quite as it should)
    I recommend pegs in the shape of "drill" (I don't remember the professional name) - they are a bit better for regips - I have failed several times on "butterflies"
The discussion centers around the appropriate drill bit size for installing expansion plugs, specifically whether to use a 12mm bit. Participants emphasize the importance of matching the drill bit diameter to the pin's neck diameter rather than the flange. Recommendations include starting with a smaller bit (e.g., 6mm) to ensure precision, especially when drilling into materials like brick. The Bosch GSB 1600RE drill is mentioned as a suitable tool for this task. Users also discuss the impact of different wall materials on drilling techniques and the necessity of using appropriate wall plugs for specific applications, such as gypsum board.
