Amica EB833BA + IN Oven (10203.3TzDpsScLbJVQSm): Disabling DEMO Mode Instructions
Shalafi11 26784 4
  • #1 16177298
    Shalafi11
    Rate: 15
    I have a problem with switching off the Demo mode in the Amica EB833BA + IN oven (10203.3TzDpsScLbJVQSm).
    The mode turned on when you wiped the oven and now I have no idea how to turn it off, please help me.
    Thank you and best regards.
  • #2 16184472
    Piotr2608
    Help: 851
    Rate: 4487
    In standby mode, press and hold for about 12 seconds:
    [clock setting] + [temperature setting] + [minus / down [-]]
    ZimTech Piotr Zimny
  • #3 16184839
    Shalafi11
    Rate: 15
    This combination does not work in this oven. But after calling the site I found out the correct combination. In the standby mode, touch and hold the quick heating button (3 from the left) and simultaneously press the down arrow twice.
  • #4 17458604
    MIRAKIUS
    I have the model INTEGRA EBI B1064 B AA and I have a combination of clock, temp and minus buttons for 12 sec. He worked. Thanks to Shalafi11
  • #5 18840748
    tomaszp1977
    In the Amica oven model EB73331 IN, the same combination as in the Amica EB833BA + IN: in standby mode, press quick heat-up and 2x sensor arrow down. Amica EB833BA + IN Oven (10203.3TzDpsScLbJVQSm): Disabling DEMO Mode Instructions
    At least annoying that it is not in the manual, especially since customer support does not work on weekends.
