Locating Fuse Diagram for Windshield Washers on VW Golf 5 1.9 TDI 105KM
adrian1307 95520 10
Why do the windshield washers and wipers on a VW Golf 5 1.9 TDI 105 KM not work when the car is stationary, and where can I find the fuse diagram for this car?
The most likely cause is the micro switch in the hood/engine cover lock: if Bordnetz thinks the hood is open, the wipers will not operate at a standstill and the washers can also stop working [#15077250][#15077351] In most cases reported here, the problem was the lock itself; only rarely was it the handle, wiring, or control unit [#15077454] One user identified the wipers as fuse F31, but the thread points first to checking the hood lock contact rather than replacing a fuse [#15077311] The fuse boxes in this car can be on the right side of the cockpit, on the left behind the Bordnetz, and in the engine compartment at the front and under the box [#15077379]
  • #1 15077129
    adrian1307
    Rate: 31
    Hello, I am looking for a description, a fuse structure diagram, which is responsible for what. I have a problem with the windshield washers, they do not work, and the wipers do not work when the car is stationary, but while driving. My suspicion is that there is no fuse in the right place, because I checked the rest and they are good. I bought the car, the previous owner did not tell me about it. I am asking for help, as I cannot find the diagram anywhere. Regards.
  • #2 15077141
    domex32
    Help: 585
    Rate: 2451
    You do not have information on the clocks that the engine cover is not closed?
    Enter the year and engine code, I will send you a fuse list.
  • #3 15077213
    adrian1307
    Rate: 31
    I do not have information about the cover.
    2005, COMFO engine code, is that it?
    adds a photo of my fuse locations
  • #4 15077250
    domex32
    Help: 585
    Rate: 2451
    Engine code on the timing cover, if you have 105 horses, without DPF you can have BKC, BXE if you have DPF to BLS.
    If Bordnetz sees the hood open, the wipers will not operate.
    Below are all the boxes with the description of fuses and relays in your car.
    • golf_6.pdf (107.47 KB) You must be logged in to download this attachment.
    • golf_5.pdf (125.14 KB) You must be logged in to download this attachment.
    • golf_4.pdf (168.49 KB) You must be logged in to download this attachment.
    • golf_3.pdf (111.54 KB) You must be logged in to download this attachment.
    • golf_2.pdf (133.41 KB) You must be logged in to download this attachment.
    • golf_1.pdf (171.41 KB) You must be logged in to download this attachment.
  • #5 15077311
    adrian1307
    Rate: 31
    So from what I noticed, the wipers are fuse F31, which I have.
    And it is possible that the sprinkler also does not work because Bordnetz sees the hood open. How to fix this error?
  • #6 15077351
    domex32
    Help: 585
    Rate: 2451
    Yes.
    You need to check the micro contact in the lock of the engine cover.
  • #7 15077360
    adrian1307
    Rate: 31
    I will figure it out for days and I will write if you have any questions, I still have a question, because I found the fuses under the hood and on the left side next to the steering wheel, where are the rest of them?
    domex32
    Help: 585
    Rate: 2451
    They can be on the right side of the cockpit, on the left behind the bordnetz, and in the engine compartment, on the fuse box at the front, and under the box.
  • #9 15077392
    adrian1307
    Rate: 31
    And the Lord is more saying that something happened to one of the fuses, or more to damage the micro contact?
  • #10 15077454
    domex32
    Help: 585
    Rate: 2451
    99% of the cases I have had a problem with the lock.
    1% is the rest, i.e. the handle, wiring, control.
  • #11 15079501
    adrian1307
    Rate: 31
    Would you have to replace the lock itself with a new one or something else? After that, the wipers at a standstill and the washers should work?
The discussion revolves around locating the fuse diagram for the windshield washers on a 2005 VW Golf 5 1.9 TDI 105KM. The user reports issues with the windshield washers and wipers, which only function while driving. Responses suggest checking the engine cover lock's micro contact, as it may prevent the wipers from operating when the hood is open. The fuse for the wipers is identified as F31, and additional fuses are located in various compartments, including under the hood and near the steering wheel. The consensus is that the lock mechanism is likely the source of the problem, with suggestions to replace it if necessary.
