Locating Fuse for Front Windshield Wiper Motor in 2008 VW GOLF 1.9 TDI 105HP
kosiu_pl 72567 5
  • #1 16532268
    kosiu_pl
    Rate: 13
    I'm on vacation and I can have a problem back ..
    I've looked at fuse diagrams and I can not find where the fuse is behind china.
    "F31 Front windshield wiper motor 30A" - I check the steering wheel and the battery.
    Of course, I'm deluding myself that there is a problem here but I have to start somewhere.
    VW GOLF 1.9 TDI 105HP 2008
    adam7009
    Help: 656
    Rate: 1635
    F 31 is an old model, with you F19. Is from wipers.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #3 16532335
    Dawid W
    Help: 8
    Rate: 88
    And these non-working wipers you checked with the hood open or closed? I do not know if in this model but in younger vw there are micro contacts in the lock so that the wipers do not hit the mask.
    Lowline version uses fuse F19 under hood
    #4 16532352
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Under the hood.
    What you gave is for the Highline version.
    For the Lowline version, this is fuse F19.
    In both cases, this year is 30A or a green fuse.
    Look in the middle of the box.
    Maybe the driver sees the mask open and therefore does not turn on the wipers - there is a micro-tag next to the lock if the mask is open or closed and the driver will not allow the wipers to work when he sees the mask open.
  • #5 16532363
    adam7009
    Help: 656
    Rate: 1635
    Even if he sees an open mask, he will not start the wipers when the car is parked, they will work while driving.
  • #6 16532411
    kosiu_pl
    Rate: 13
    Uff thanks Gentlemen - the perpetrator is F19.
    It works!!
    By the way, playing with a child with wipers can also end up for someone else :)
    Thanks again.
