Asus Laptop Stuck in Endless Restart Loop After Format Attempt
marcel8127 28719 6
  • #1 15098568
    marcel8127
    My laptop broke. I was doing the computer format, I went to eat dinner when I came back, there was a message saying 'Problem' I clicked OK and there was a safe mode I clicked restart the computer and it was like this (photo below) and this message appeared, the computer turned off and it turned on like that endlessly. Please help
    To view the material on this forum you must be logged in.
  • #2 15098838
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1541
    Can you go into the bios?
    Disk visible, tested?
    Did you fire up any live system from cd?
  • BIOS flash blocked until AC and charged battery connected
    #3 15099353
    marcel8127
    Tak WSZEDŁEM do BIOS'U i teraz mam niebieski ekran
    Nie odpalałem nic z cd.
    Są teraz takie napisy:
    Initialize...
    Please plug in AC!!
    System doesn't permit flashing BIOS!! Please press and key after plug in AC!!
    Uruchomiłem ponownie laptopa i teraz jest tak:
    Initialize...
    Please plug in AC!!
    Please plug in BATTERY and its remaining capacity should be more than 20%!!!!
    System doesn't permit flashing BIOS!! Please press any key after plug in BATTERY
  • #4 15099440
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1541
    Perform CMOS reset.
  • #5 15100010
    chisel
    Help: 102
    Rate: 171
    If he performs a cmosu reset in the ASUS by removing the battery, then he will look for the bios password, because he will set it. Plug in the charger and run some live cd.
  • #6 15100353
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    Charger, do you have a good battery?
    Check behavior with no battery, no disk, no drive.
  • #7 15100430
    marcel8127
    I have a working charger, maybe someone will advise me what to do with the BIOS because I can turn it on. Please help, you will need a laptop for tomorrow.
The user is experiencing a continuous reset issue with their Asus laptop after attempting to format it. Upon returning from dinner, they encountered a problem message and a blue screen. Subsequent attempts to access the BIOS revealed messages indicating the need for AC power and a battery with more than 20% capacity. Suggestions from other users include performing a CMOS reset by removing the battery, checking the charger and battery status, and using a live CD to troubleshoot further.
