Windows 10 Continuous Reset Issue: Error Loop & BIOS Settings after Forced Shutdown
Niezniszczalny 7332 7
  • #1 17285463
    Niezniszczalny
    Hello, recently, when I wanted to turn off the computer, I accidentally restarted it, I was in a hurry, so I held the button and it turned off, now I'm trying to turn it on and when the windows dots spin for 0.5 sec an error pops up that it must restart and so on over and over again. I took out the battery from the motherboard, but I entered the same in the bios, I gave it to the default settings and the same (I overclocked the processor once). Even from the original album, it does not move. How can I fix this problem?
  • #2 17285574
    rtj71
    IT specialist
    Help: 474
    Rate: 353
    Damaged system - so in short, if you have access to another computer, download Media Creation Tool, run, point to the flash drive, install, insert the flash drive, start the computer, choose operating system repair.
  • #3 17285628
    Niezniszczalny
    It's nice, only he downloads all windows on the pendrava.
    It will take a while and I have the original one on the record
  • #4 17285655
    rtj71
    IT specialist
    Help: 474
    Rate: 353
    Then insert the CD if you have and start the repair too.
  • #5 17285686
    Niezniszczalny
    Well, as I wrote earlier, I inserted the disc and set it to boot from it. It was spinning fast, something moved only the dots started to move and it was "your pc ran into a problem and needs to restart" and it kept turning on over and over again.
    Unless I am doing something wrong when it boots up, should I click something?
  • #6 17286144
    rtj71
    IT specialist
    Help: 474
    Rate: 353
    If you get this error right away, try with a pendrive, download this media creation tool, run from pendrive and select system repair there.
  • #7 17290123
    bzc0fq
    Rate: 19
    What exactly computer model do you have?
    Download the diagnostic program and scan the equipment for possible problems. If you have a CD, look for freeware cd-roms (or bootable USB images) with diagnostic software and scan your computer.
  • #8 17290382
    Myrasz
    Help: 10
    Rate: 82
    First: the specification of the computer.
    Second: give pictures from the BIOS, from the BOOT tab.
    This error should not show up when BOOTING is set from external media, because there are no errors there, just a normal WIN install. In my eyes, the BOOT is set incorrectly.
The discussion revolves around a Windows 10 continuous reset issue following a forced shutdown. The user experiences an error loop where the system fails to boot, displaying a message that it needs to restart. Attempts to resolve the issue include removing the motherboard battery, resetting BIOS to default settings, and using both a recovery CD and a USB flash drive with the Media Creation Tool for system repair. However, the user continues to encounter the same error. Other participants suggest checking BIOS settings, ensuring the boot order is correctly set to external media, and running diagnostic software to identify potential hardware problems.
