Using TachoPro Cables with Digiprog: DB25 Connector Pinout & Nec Dongle Compatibility
zgjana 14925 9
Can I use TachoPro cables, especially the #37 NEC dongle, with Digiprog by matching the DB25 pinout, and what is the TachoPro DB25 pinout?
You cannot directly use the TachoPro #37 NEC dongle cable on Digiprog by matching only the DB25 connector, because TachoPro drives the DB25 differently depending on the cable/application and Digiprog does not output the same TX/RX signaling [#15102078][#15123743] The reported #37 cable pinout is: 4=reset, 7=tx, 8=rx, 17=ss, 21=vcc, 25=gnd, with the other pins marked nc [#15102232] Digiprog’s DB25 is described as having EEPROM direct-programming pins and CAN network output, not the same interface used by TachoPro’s dongles [#15123743] So an adapter/interface would be needed to translate between the two “languages,” likely using an ATmega plus custom software, and one reply considers that approach impractical [#15146648][#15149193]
  • Request for TachoPro DB25 connector pinout
    #1 15100425
    zgjana
    i,m trying to figure out how to use tachopro cables to digiprog, so i mean, tacho pro has the nec dongle included , and as i,ve searched on internet they look the same, the only difference is the db25 pinout connector, so please does anyone has the tachopro db25 connector pinout ? cause for the digiprog i,ve find one,, cause about the digiprog cables there are a lot of them missing, i mean, hc12, st53, st59 are not included , but i,m sure we can use the cable 37 nec dongle of tachopro as the st59 on digiprog.
    please help me to find pinout informations about tachopro db25 connectors
  • TachoPro DB25 pinout varies by cable application
    #2 15102078
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    D25 connector to TachoPro has diferrent configuration regardless of what eprom/processor needs to be programmed. It is on main board and there are two CMOS chips connected directly to this db25 called octal buffer/line driver 74HC541D. Depending on what processor/eprom needs to be programmed internal processing unit on tachopro sending diferrent signals to 74HC541D and diferrent pins on db25 actually works (eg diferrent pins works on c66 memory cable than on 9s12 processor cable / dongle). It is about aplication - internal software choosing how to drive db25 to work with specific cable.
    I bet to find cable #37 nec dongle schematic to tachopro and take a look on db25 pins.
    Hope it helps.
  • ATmega32L #37 cable and Digiprog DB25 pinouts
    #3 15102232
    zgjana
    i have 2 #37 cables they are a bit different but not so much, and based on atmega32L pinout the db25 pinout of #37 cable is:
    1=nc
    2=nc
    3=nc
    4=reset
    5=nc
    6=nc
    7=tx
    8=rx
    9=nc
    10=nc
    11=nc
    12=nc
    13=nc
    14=nc
    15=nc
    16=nc
    17=ss
    18=nc
    19=nc
    20=nc
    21=vcc
    22=nc
    23=nc
    24=nc
    25=gnd
    hope someone know how to connect this adapter to digiprog3
    and digiprog db25 connector pinout is:
  • #4 15123743
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    As you see cable 37 has tx/rx pins to be driven by tachopro. Digiprog has them not. It only has Eeprom pins (to direct programming) and Can network output. So in this case some kind of interface is needed to decode signals from digiprog to language of tachopro cable #37. I do not see any way to directly connect both devices.
  • #5 15145825
    zgjana
    hi friend, ok can we recruit someone to build this kind of interface adapter between digiprog and tachopro cables? if yes, just tell me what is needed and how much will cost, so we can try out to find that cash
  • #6 15146648
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    I think it needs to be built with some kind of interface based on atmega. First of all schematic is needed and main problem is to write software that will transfer "languages" between those two diferrent programmers. IMHO this is pointless. Better to buy good working tachopro and use it for programming. It will be cheaper and less time consuming.
  • #7 15146805
    zgjana
    tacho pro has its car list limitation, and digiprog3 has its own car list limitation, combining those two will be great, anyway i understand it, but i compare the nec dongle of tacho pro and nec dongle which is in sale for digiprog3 , they look the same , same chips and components, it could be only db25 different connection i think
  • #8 15149193
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    It might be same aplication for both. But main problem is as I wrote few posts over adapter driver has diferrent way that is controlled by tachopro or digiprog. I mean adapter might have same chip in it but chip might have such diferrent software inside.
    I will look in my db I should have tachopro nec dongle schematic. If you will find digiprog nec dongle schematic we can do something.
  • #9 15465771
    vinay1230012
    I think it needs to be built with some kind of interface based on atmega. First of all schematic is needed and main problem is to write software that will transfer "languages" between those two different programmers. IMHO this is pointless. Better to buy good working tachopro and use it for programming. http://howtorootandroid.net/free-download-framaroot-all-versionsframaroot-apk
  • #10 15898520
    zgjana
    ok, i,m back again, i did some research and i will come soon with some interesting infos here
The discussion revolves around the compatibility of TachoPro cables, specifically the NEC dongle, with the Digiprog programming device. Users seek the DB25 connector pinout for TachoPro to facilitate this connection. It is noted that the pinout configurations differ based on the specific EEPROM or processor being programmed, with the TachoPro utilizing an octal buffer/line driver (74HC541D) for signal processing. A user provides a pinout for the TachoPro #37 cable, while others express the need for an interface to bridge the communication between TachoPro and Digiprog, as their internal software and signal handling differ. Suggestions include creating a custom adapter, though some argue it may be more efficient to use each device independently due to their respective limitations.
