Lenovo G700 Laptop: Damaged Charging Plug Replaced, BAMBI Motherboard Rev 2.1, No Power Response
marshal22 6057 8
  • #1 15110640
    marshal22
    The laptop had a damaged charging plug. was replaced. I have also measured the voltages at the point of contact with the motherboard are correct.
    The charger has been checked on another laptop and vice versa so I exclude it.
    The symptom is a complete lack of response to the power supply. The battery charging indicator or any warning sound is not on. Nothing squeals as in the posts already posted about this equipment.
    A request for advice may be some kind of fuse that could burn out when you snatch the socket or some other item that needs to be checked - replaced.
    BAMBI motherboard main board rev. 2.1
    • Lenovo G700 Laptop: Damaged Charging Plug Replaced, BAMBI Motherboard Rev 2.1, No Power Response Bambi_rev_2_1.jpg (207.89 KB) You must be logged in to download this attachment.
  • #2 15110678
    miecho18
    IT specialist
    Help: 3087
    Rate: 2778
    Plate designation enter.
  • #3 15111325
    lisek
    Service technician RTV
    Help: 6363
    Rate: 6895
    This is a CD under Leonovo (Intel i3-i7 IIIgen.) P / nr. 69N0B5M10A01
    - Pegatron platform or something from Asus
    HM70 (Intel SJTNV) / sometimes HM76
    KBC IT8528E FXA
    stby TPS51225C
    GPU chip (N14M-GE-B-A2) GT720M
    Measure the stba and LDO voltages (see datasheet), see if it warms up?
    Then take care
    - if you have a small resistance after LDO (it powers the NCB and Power button) it's 99% KBC to exchange
    Similar to G500
  • #4 15111368
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    Incorrect socket replacement could lead to various faults. You do not write anything about the behavior of the power supply - if it has a light / diode, it does not dim after connection.
    Measure the resistance + of the power supply socket in relation to ground to the beginning - there is no short circuit. If it does not have to plug in the power supply and measure the voltage - do you have those around 19V on the power supply socket.
  • #5 15168043
    Balzat
    Rate: 14
    I have exactly the same problem
    TPS51225 warms up
    LDO3 - 3.36V to a mass of 3.4k Ω
    LDO5 - 5.19V to mass 23k Ω
    Maybe someone has a schematic of this CD or can send the page itself with the vicinity of TPS51225
  • #6 15168151
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1541
    Schema unavailable.
    Take the system off and give the appropriate voltage to the LDO pins from the service power supply and see what effect it has.
    Measure the resistances on the main transformer coils and pass along the keys.
  • #7 15172651
    piotrp26
    Rate: 15
    Hello. TPS51225 is in the Acerach M series, PM50 platform, it may be helpful in the diagnosis, because the BAMBI (G700) and DUMBO2 (G710, Z710) schemes are nowhere to be seen. By the way, the slaughtered nest in these models results in damage to KBC ITE8528E.
  • #8 15183882
    Balzat
    Rate: 14
    I put in a new TPS51225 because I just had it at hand.
    There is no change, the laptop still does not react and warms up TPS51225
    I think, just like piotrp26, that the NCB is damaged, I will replace it and it will turn out, I just have to wait for the package because I do not have one.
  • #9 18461697
    bekirsalman
    SCL SDA 3.3 V
The Lenovo G700 laptop is experiencing a complete lack of power response after a damaged charging plug was replaced. The user confirmed correct voltage measurements at the motherboard contact points and ruled out the charger as the issue. Responses suggest checking the TPS51225 chip and LDO voltages, as well as measuring resistance at the power supply socket. There are indications that the KBC (ITE8528E) may be damaged due to the socket replacement. Some users have replaced the TPS51225 without success, leading to speculation about potential damage to the NCB. Schematic diagrams for the BAMBI motherboard (Rev 2.1) are not readily available, complicating troubleshooting efforts.
