How to connect the drain of the washing machine when there is no installation?
real_romek 49521 5
  • #1 15113155
    real_romek
    Rate: 29
    There is no drainage system for the washing machine in the bathroom. The solution used so far is a pipe inserted into the toilet. A risky solution, it may flood the bathroom and the downstairs neighbor.
    What solutions are possible without breaking walls and general renovation?
    The washbasin is on the wall perpendicular to the one next to the washing machine, it is a small bathroom, so the distance is not big. Between them there is a toilet suspended on the same wall as the washbasin.
    I would be grateful for any suggestions or suggestions.
  • #2 15113210
    Pieraś
    Rate: 23
    Well, it is not possible to run the PVC pipe from the washing machine to the toilet or sink drain? I have a PVC 30 release, but the drain from the washing machine is attached to the wall. There is no problem with tightly pressed in.
  • #3 15113294
    dzi_dziuś
    Home appliances specialist
    Help: 341
    Rate: 1170
    You can buy a siphon for the washbasin with the possibility of connecting a hose from the washing machine.
  • #4 15113568
    real_romek
    Rate: 29
    Thanks for the help.
    @ Pieraś
    Connecting this to a toilet drain would be the least invasive and visible. The question is whether it can be easily connected to the toilet drain? How can this be done?
    @baby
    Is it then possible to let the drain pipe of the washing machine run off the floor? Won't it cause any water flow problems?
    dzi_dziuś
    Help: 341
    Rate: 1170
    The drain hose from the washing machine can normally lie on the floor, only its end should be permanently installed in a prepared hole in the sink siphon (height about 60 cm). Sample photo.
  • #6 19581180
    JacekKot1
    Rate: 9
