Philips AZ787 Boombox Inverter Issues: Voltage Drop Under Load & Troubleshooting Steps Taken
KrzysztofK 8922 10
Why does the Philips AZ787 inverter output rise very slowly with no load but collapse to 2 V or 0 V under load, and what should I check to fix it?
The inverter is most likely faulting on the primary/controller side, not in the output bridge or secondary parts, so you should check the SMD parts in-circuit, the primary electrolytic capacitors, and especially the controller-area 1 µF capacitor(s) shown in the application circuit [#15160427] [#15160436] [#15160522] [#15160650] Replacing C906 (1 µF) did not change the result in the thread, which makes a bad controller IC or another nearby 1 µF part such as C908 a likely suspect [#15162882] The service manual/schematic for the converter was also provided, and the advice was to trace the circuit with a meter using that diagram [#15160483] [#15160522] If the controller is indeed defective, one reply noted it can be sourced inexpensively online [#15163100]
  • #1 15160368
    KrzysztofK
    Help: 31
    Rate: 45
    Hello, I would like to ask for help.
    Converter from Philips AZ787 boombox. Without load, it takes a very long time to rise to the output voltage of 9.87 V.
    When the load (boombox) is connected, the voltage drops to 2 volts, so the boombox does not start.
    After loading the bulb with 6.3 V, the output voltage drops to zero - the bulb does not light.
    After loading with a red diode with a 50 Ohm resistor, the voltage drops to 6 V - the diode is on. However, if the diode is connected to the output before connecting 230 V - the voltage at the output does not appear - the diode is off.
    What I did:
    I checked the bridge, all diodes, transistor - everything is OK. I replaced the output capacitors, nothing has changed. I am wondering about the transformers: between the pins 1-3, the resistance is 9 Ohm, between 2-4 only 0.1 Ohm. Did I miss something.
    Philips AZ787 Boombox Inverter Issues: Voltage Drop Under Load & Troubleshooting Steps Taken Philips AZ787 Boombox Inverter Issues: Voltage Drop Under Load & Troubleshooting Steps Taken Philips AZ787 Boombox Inverter Issues: Voltage Drop Under Load & Troubleshooting Steps Taken
  • #2 15160427
    hazet
    Help: 62
    Rate: 510
    You have also measured the SMD elements - at least in the system.
  • #3 15160436
    niewolno2
    Level 40  
    Help: 630
    Rate: 1262
    Are the electrolytic capacitors on the primary side checked / operational?
  • #4 15160483
    hazet
    Help: 62
    Rate: 510
    Schematic diagram of the converter
    You have the complete service manual here.
    • philips_az787-61_ver_1_0.pdf (2.31 MB) You must be logged in to download this attachment.
  • #5 15160490
    KrzysztofK
    Help: 31
    Rate: 45
    I do not have to replace the capacitors on the primary side, they look ok. I shorted one by accident after disconnecting the power supply and it discharged with a bang, so I think they are ok.
    The SMD diodes are working, I measured the resistors and they also seem ok.
  • #6 15160522
    hazet
    Help: 62
    Rate: 510
    Here you have the application chip of the inverter controller. Meter in hand and go. Something is telling me that he may be "set".
    • c2472px2.pdf (466.14 KB) You must be logged in to download this attachment.
    niewolno2
    Level 40  
    Help: 630
    Rate: 1262
    The application shows that there is a 1uF capacitor on the primary side, has it been checked / replaced?
  • #8 15160785
    KrzysztofK
    Help: 31
    Rate: 45
    No, I did not replace this capacitor. I'll try to do it tomorrow.
  • #9 15162882
    KrzysztofK
    Help: 31
    Rate: 45
    A new day, a new hope and ... failure.
    Capacitor 1uF C906 replaced and no change. I checked all the resistors and diodes again. Everything looks good. Now I saw there is one more 1uF C908. I do not know if there is any point in replacing it.
    Probably the controller has fallen, unfortunately I am not able to replace it. You will probably need to convert the radio to a traditional power supply.
    hazet
    Help: 62
    Rate: 510
    On the Alliexpres auction site $ 2.20, in Poland you probably won't get it.
  • #11 15163167
    KrzysztofK
    Help: 31
    Rate: 45
    I give up repair. Thanks to everyone for your help. I close the topic.
The discussion revolves around troubleshooting voltage drop issues in the Philips AZ787 boombox inverter. The user reports that the output voltage takes a long time to stabilize at 9.87 V without load, and drops to 2 V under load, preventing the boombox from starting. Various tests were conducted, including checking the bridge, diodes, and replacing output capacitors, but the problem persisted. Suggestions from other users included checking the primary side electrolytic capacitors and a 1uF capacitor on the primary side, which the user later replaced without success. The user concluded that the inverter controller might be faulty and considered converting the radio to a traditional power supply. The discussion ended with the user giving up on the repair.
