Opel-Isuzu 1.7 Pump Controller: Diode Short Circuit, 7809 Stabilizer, 6.5A Limiter, BYV & BUZ
castin 4995 10
How can I locate the short circuit in an Opel/Isuzu 1.7 pump controller when the 7809 stabilizer and BYV/BUZ parts are OK and the bench supply current limiter keeps tripping?
Check the capacitor area and the rest of the board for a hidden short; if the capacitor is correct, the fault is likely further in the circuit, not in the BYV or BUZ parts [#16905945][#16905979] For bench testing, the 160 V converter should start immediately, and you can feed a rectangular control signal into the input [#17334410] Replace the valve with a 220 V bulb as the load and connect it to the two output pins in the plug, pins 14 and 20 [#17334410][#17336906] A working EDU can draw about 4–5 A, so a 6.5 A limiter trip suggests an abnormal load or short [#17334410]
  • #1 16890359
    castin
    Help: 63
    Rate: 164
    I got the driver. I replaced the 7809 stabilizer, improved February in sensitive places. When checked on the table, the workshop power supply reduces the voltage, the controller has a short circuit in the power supply. I have the limit set to 6.5A and the limiter continues to turn on. It turned out that there is a short circuit between the diodes on the PCB. Someone was working on a similar topic?
    Of course, both BYV and BUZ have been checked and are ok.
    • Opel-Isuzu 1.7 Pump Controller: Diode Short Circuit, 7809 Stabilizer, 6.5A Limiter, BYV & BUZ shortcircuit.JPG (273.2 KB) You must be logged in to download this attachment.
  • #2 16905945
    żałosna udręka
    Help: 191
    Rate: 1020
    The condenser sticks up. You did not close under it?
  • #3 16905979
    castin
    Help: 63
    Rate: 164
    Kondek ok, no short circuits. This is how it should be on the album, I have already established it. I have a short circuit in the further part of the system, tomorrow I will show the ns photo.
  • #4 17333976
    nieparzysty_35
    Buddy, did you fix this driver?
  • #5 17334201
    castin
    Help: 63
    Rate: 164
    No, in this case, the chapel. The drug is set up and ok. This one lies and stinks.
  • #6 17334221
    nieparzysty_35
    It's a sad thing with these drivers. I wanted to help my brother fix the driver, but I also couldn't deal with it. The car doesn't start, it doesn't start. By the way, I would like to ask you if, when trying to run this controller "on the table", we connect it to the 12V 10A power supply and you also need to connect the "control pulses" somewhere to be able to check if the driver gives high voltage (160V)?
  • #7 17334287
    castin
    Help: 63
    Rate: 164
    I don't remember now, I don't think so.
  • #8 17334321
    nieparzysty_35
    Thank you for your answer. Due to the fact that the PCB is multilayered, it is difficult to get to where it goes. And when the metallization of the holes is damaged, as is often the case with those larger elements on the board, such as a coil or a capacitor, it is possible I think that is why there are so many offers on the Internet such as "I am selling a broken driver". I will fight this driver again, even though my brother decided to buy one after regeneration, because he had no other option. Maybe someone more experienced will tell you whether you need to run this driver by connecting the appropriate mileage to trigger high voltage to control the flow valve. you need to connect such a waveform, what shape and value?
  • #9 17334410
    damdam
    Help: 274
    Rate: 950
    160V converter works immediately. you can give a rectangle for input and a 220V bulb instead of a valve and check more carefully. I have a bulk SPV valve for testing, EDU can take 4-5A when functional.
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #10 17334447
    nieparzysty_35
    Damdam thank you very much for a quick hint. Thanks to this I am a bit ahead and know a little more about it. Tell me if I should connect the light bulb as a load directly to the two outputs in the plug (right and left)? Now I just don't remember the exact pin numbers I think number 14 and 20.
The discussion revolves around troubleshooting an Opel-Isuzu 1.7 pump controller experiencing a short circuit in the power supply. The user replaced the 7809 stabilizer and confirmed that the diodes (BYV and BUZ) are functioning correctly. Despite setting a 6.5A limit, the limiter continues to activate due to a short circuit on the PCB. Participants share insights on testing the controller with a 12V 10A power supply and suggest using a 220V bulb as a load for further diagnostics. The complexity of the multilayer PCB and potential damage to metallization are noted as challenges in repairs.
