Homemade ways to print - stickers / foil or self-adhesive paper
19680 9
How can I cheaply print durable self-adhesive stickers or front-panel labels at home?
Use self-adhesive foil made for a laser printer, or self-adhesive photo paper if you want to keep using an inkjet printer [#15190016][#15188676] Inkjet prints need extra protection because they are not waterproof, so they should be covered with foil or another clear layer [#15188676] Another suggested method is to print on smooth paper with a colour copier, stick it down with double-sided tape, and spray it with clear acrylic varnish for protection [#15189882]
  • #1 15188301
  • #2 15188398
    leonov
    Help: 1039
    Rate: 2248
    Or maybe yes, printing on plain paper, then laminating and gluing on a thin double-sided tape? I admit that I do not know how costly it would be?
  • #3 15188407
  • #4 15188439
    anders11
    Level 30  
    Help: 197
    Rate: 204
    Leonov, instead of plain paper, use photo or fine textured paper
    for printing business cards
  • #5 15188676
    GBW
    Help: 123
    Rate: 293
    You have to cover the inkjet printing with foil anyway because it is not waterproof.
    More like a laser on a special white foil.
  • #6 15189807
    leonov
    Help: 1039
    Rate: 2248
    ivyivy wrote:
    I wonder if you can make a small plotter out of an ordinary printer and have fun with a different type of ink.
    Rather forget it :idea:
  • #7 15189882
    abart64
    Help: 271
    Rate: 633
    Print on an inkjet and use a colored xero on smooth paper and stick it on a double-sided tape because I do not know if they are photocopied on self-adhesive. The whole thing can be sprayed with a clear acrylic varnish, which will give a protective coating.
  • #8 15190016
    Paweł1000
    Help: 58
    Rate: 70
    There is self-adhesive photo paper for inkjet printers, photo papers for inkjet printers can be said that they are waterproof, I used to have a lot of such paper when I still had inkjet printers and I remember that the printout was even waterproof. Another, much better solution is to print on a self-adhesive foil intended for a laser printer. THESE ARE THESE FOILS.
  • #9 15190231
  • #10 15190249
    Paweł1000
    Help: 58
    Rate: 70
    What do you want to know? When I used it (about 12 years ago) it was quite expensive, I remember that 1 A4 sheet cost PLN 4. and you had to buy the entire package (probably 25 sheets), now such films have probably become cheaper, you have to search on googles.
The discussion revolves around cost-effective methods for printing self-adhesive stickers on foil or paper, particularly for front panels of homemade devices. Users share various techniques, including printing on plain or photo paper, laminating, and using double-sided tape. Suggestions include using waterproof self-adhesive photo paper for inkjet printers and self-adhesive foil designed for laser printers. Some participants mention the need for protective coatings, such as clear acrylic varnish, to enhance durability. The conversation highlights the challenges of achieving precise alignment and quality when outsourcing printing to professional services.
