Achieving Gold Print Effect: Printer, Ink, and Process for Wedding Invitations (Colaria-01)
ZurasGliwice 37219 3
  • #1 8750883
    ZurasGliwice
    As in the subject ... how to get such an effect? What printer is needed, what ink, etc. (Exactly, I mean such a gold print)
  • #2 8750994
    Janusz.P
    Photocopiers specialist
    Help: 455
    Rate: 224
    This type of printing is done using a simple black and white laser printer and then you need a laminator plus a special gold thermal transfer foil. We put the foil on a sheet of black and white print and pass it through the laminator. Then we tear off the foil in the place of the toner, the foil glued to it remains on the card and we have a beautiful gilded print.
  • #3 8753476
    ZurasGliwice
    Thank you very much. Do you know where you can get such foils? Because it's mostly black and white...
