High Household Voltage Fluctuations: Experiences & Changes in Polish Power Grid Since 2013
barytek 24231 33
Why does my household mains voltage stay around 237–248 V and sometimes change by more than 15 V, especially before and during a storm, and is that normal?
Yes, voltages of 237–248 V are still within the permitted mains range of 207–253 V, and 253 V is an average over the measurement period, not a hard instantaneous ceiling [#15212297][#15212465] Such fluctuations can be normal on the low-voltage network, especially near the transformer, and a storm can change the load or even switch network sections, causing the voltage to rise or fall quickly [#15213572][#15213827] If you suspect a real problem, ask the utility to check the neutral/PEN connection and the installation, because a bad neutral can cause abnormal voltages in a three-phase system [#15212666][#15213163] The most useful next step is to request a recorder/analyzer so the voltage is logged 24/7 instead of only during a daytime visit [#15216179][#15216979] With recorded evidence, the supplier can decide whether to adjust transformer taps, replace faulty wiring/poles, or otherwise correct the network [#15212340][#15216979]
  • #31 15216979
    tronics
    Help: 358
    Rate: 841
    And if nothing helps, you will need to vacuum this type of equipment for more capricious equipment: https://www.elektroda.pl/rtvforum/topic2722745.html
    But honestly - my grandmother, always crazy, complained that with higher light consumption they went crazy (and indeed, the house at the end of the line, phase only - it was enough to turn on the TV so that the 60W light bulbs were dimmed) - her sister lived with her temporarily, she wrote this complaint and referred to records (they either sell the goods in accordance with the assumed parameters, or let them give a discount for "goods not in accordance with the specification") - the employees drove up, checked the voltage, set up the recorder, after a few days they came, replaced the broken pole and led new wiring. Can be? It is possible, you just have to want and be able to write it well. If the magazine takes away all the typical dispelling arguments and at the same time opens the way to claims, then idiots do not work there, but only calculate what is more profitable - possible compensation or investment in quality improvement.
  • #32 15224463
    Grzegorz740
    Level 37  
    Help: 313
    Rate: 553
    bizon_126 wrote:
    I work from 7 am to 5 pm so I do not have much time for such dealing with officials
    When I read it, my hands dropped. Who do you blame? You think someone from the forum will write a letter and send it to you.
    If you do not want to write an appropriate letter, you have the tension this and not the other.
    Anyway, colleagues on the forum wrote you what to do. Your will whether you follow it.
  • #33 15225447
    bizon_126
    Help: 108
    Rate: 566
    Put yourself in my situation where I live, there is a colony such a terminal only 10 recipients all of them too low voltage does not bother him too much because the TV still works just like a computer he does not care about
    when you call several times when the phase is missing and the energy guy asks "only do you need electricity ??"
    Yes, because as a minority I do something in the garage after work and my parents also have a farm where three-phase power is needed
  • #34 15225648
    Grzegorz740
    Level 37  
    Help: 313
    Rate: 553
    Then write the appropriate letter to the energy supplier to do something about this undervoltage. Nobody from the forum can do it for you. Colleagues from the forum told you how to settle the matter, what to put in the letter. So let's go.
The discussion revolves around high voltage fluctuations in the Polish power grid, particularly since 2013. A user reports experiencing voltage levels between 237V and 248V, with spikes exceeding 250V during storms, prompting the purchase of a UPS for stabilization. Participants highlight that permissible voltage deviations are +/- 10% (207V to 253V) and suggest reporting issues to the energy supplier, as voltage regulation may be possible. Concerns about equipment safety are raised, noting that voltages exceeding 270V can cause damage. The conversation also touches on the impact of load imbalances and the importance of accurate measurements. Users share personal experiences with voltage stability and fluctuations, emphasizing the need for proper documentation and communication with energy providers to address undervoltage issues.
TL;DR: Polish low-voltage networks must hold 230 V ± 10 % (207-253 V) [Elektroda, jharlan, post #15212297]; “voltage up to 253 V is still 'normal'” [Elektroda, jharlan, post #15212297] Brief spikes above 250 V near transformers are common and usually harmless if below 270 V [Elektroda, CYRUS2, post #15212465] Why it matters: knowing the limits helps you decide when to complain—or when to install protection.
Quick facts • Polish/EU tolerance: 230 V ± 10 %, 95 % of 10-min averages (EN 50160) • Damage risk climbs sharply above 270 V AC [Elektroda, CYRUS2, post #15212465] • Neutral break can expose outlets to ~400 V in three-phase homes [Elektroda, CYRUS2, post #15214622] • Utility must investigate written quality complaints within 14 days (Energy Law Art. 7-9, 2023) • A portable power analyzer rental costs ~120 PLN/week (Energo-Control, 2024)
What voltage range is legally acceptable in Polish household sockets?
EN 50160 and national rules allow 230 V ± 10 %, so any 10-minute average between 207 V and 253 V meets the standard [EN 50160][Elektroda, jharlan, post #15212297]
Is 244–250 V harmful to my appliances?
Most devices tolerate up to 253 V continuously. Damage risk rises only above about 270 V AC [Elektroda, CYRUS2, post #15212465] Switch-mode supplies and LED bulbs are rated to 265 V nominal (datasheets, 2024).
Why does voltage climb before a thunderstorm and drop when rain starts?
Many users disconnect loads before lightning, reducing current draw and letting the feeder voltage float higher; once rain calms fears, loads return and voltage falls [Elektroda, BILGO, post #15213572]
How accurate is a UPS display for measuring mains voltage?
UPS LCDs are typically ±5 V. Use a calibrated multimeter or a class 0.5 recorder for complaints. Inaccurate readings weaken claims [Elektroda, jharlan, post #15212297]
How can I formally complain about over- or undervoltage?
Write (not call) your supplier, request compliance with EN 50160, and ask for a 7-day analyzer. They must respond and share the report [Energy Law Art. 7-9, 2023]. Forum users confirmed written requests get recorders installed [Elektroda, tronics, post #15216979]
What if technicians test only at noon and miss the problem?
State the exact hours of trouble in your letter and insist on 24-hour recording. Emergency crews operate 24/7, so evening checks are feasible [Elektroda, zbich70, post #15216319]
Can a local autotransformer fix chronic low voltage?
Yes. A 5 kVA step-up autotransformer can add 10-15 % and costs ~800 PLN. It protects one house but doesn’t solve grid issues [Elektroda, DJ ANNUS, post #15216504]
How do I protect sensitive gear from extreme surges?
  1. Install Type 3 surge arresters in power strips.
  2. Add an AVR or line-interactive UPS with ±8 % regulation.
  3. For workshops, fit an automatic tap-changing stabilizer (±20 %) rated for peak load. This covers 300-400 V spikes from neutral loss edge cases [Elektroda, CYRUS2, post #15214622]
Could low voltage shorten appliance life?
Yes. Motors draw higher current, overheating by ~8 % for every 10 % undervoltage [IEEE Std 141-2010]. Persistent 190 V reports justify action [Elektroda, bizon_126, post #15215615]
What’s an easy three-step procedure to file a voltage complaint?
  1. Record dates, times, and measured voltages for one week.
  2. Send a registered letter with data, citing EN 50160 and contract clause.
  3. Request a portable analyzer within 14 days and ask for written results.
Is there a cost if the analyzer shows voltage within limits?
Suppliers may bill testing costs (approx. 300 PLN) if parameters are compliant; they waive the fee when limits are breached (PGE T&C §12, 2024).
Can repeated 350 V spikes average out as ‘within 253 V’?
Short 0.1 s spikes barely affect 10-minute averages, so EN 50160 may still be met [Elektroda, CYRUS2, post #15212465] That’s why surge protection, not just standards, matters.
What’s the cheapest temporary fix for evening sags to 190 V?
A 2 kW ferroresonant constant-voltage transformer (~350 PLN used) can hold 220–230 V output down to 160 V input. It hums and wastes ~50 W standby, but saves equipment during peak demand.
