Poxipol Adhesive Fails on Metal Bathroom Paper Holder: Possible Solutions & Alternatives
km500 61620 15
Why does Poxipol keep failing when gluing a metal bathroom paper holder, and what adhesive or reinforcement should I use instead?
Poxipol likely failed because the joint was not ideal for this load and the surfaces were not prepared in the right way; roughen, clean, degrease, and if available use the proper activator, then keep the joint unloaded for at least 24 hours [#15253854][#15254634] For a metal part like this, one reply suggests trying a different epoxy made for metal, such as Technicoll 7706 or a similar liquid metal epoxy, which hardens after 12–18 hours and reaches full strength after about 48 hours [#15255342] Another important point is to keep the adhesive layer thin and the parts fitted as closely as possible, because thick glue layers are weaker than well-mated rough surfaces [#15255380] If glue alone is still not enough, reinforce the break mechanically by drilling two or three holes and inserting steel rods or threaded rods/screws set in epoxy, which makes the joint much stronger [#15265303][#15265922] Cyanoacrylate “drop glue” is not suitable for this kind of heavily loaded metal joint [#15278263] One user also reported that changing to a fresh glue, preparing the surface, and degreasing made the repair hold [#15575189]
  • Failed Poxipol bond prompts questions about surface preparation and screws
    #1 15253742
    km500
    Rate: 8
    My metal element broke - the bathroom paper holder (see photos)
    I decided to stick it together. I used Poxipol 2-component adhesive and after gluing I squeezed the so-called bookbinding clamp. After some time - it fell apart again.
    I decided to change the gluing surface: I drilled 3 holes in one place (so that the glue could enter them and rubbed the surface with a file - so that the glue could catch better. Unfortunately, it fell apart again
    What am I doing wrong ? Do I have to drill screws and twist screws? For aesthetic reasons, I would prefer to stick it together.
  • #2 15253803
    siewcu
    Help: 133
    Rate: 458
    Poxipol does not stick everything, you need to find an adhesive that is suitable for the material you want to glue.
  • #3 15253854
    mariuszp19
    Help: 311
    Rate: 410
    Firstly, it is just like the sower's colleague wrote earlier, and secondly, the glued surfaces should be properly prepared before gluing (roughening, cleaning, degreasing, using an appropriate activator).
  • Poxipol claims stainless steel adhesion, but activator was omitted
    #4 15254559
    km500
    Rate: 8
    From the description of Poxipol:
    .... Can be used on metal, ceramics, glass, cement, fiber cement, various types of plastic materials, etc ...
    ... Materials that can be glued with POXIPOL: metals (ferrous and non-ferrous), glass, ceramics, brick, concrete, wood, eternite....
    From the product description - it appears that it is stainless steel
    http://www.homebook.pl/produkty/4879114/dla-d...we-akoszenia-do-toalety-podajniki-papieru-uch useful-na-papier-toaletowy-stal-nierdzewna-tiger- boston-3091-09
    As you can see in the photos, I did sanding and brushing, and rubbed it with a solvent ...
    I did not use the activator....
  • #5 15254634
    telecaster1951
    Help: 829
    Rate: 818
    But here the weld cracks, not peels off the surface.
    Too much hardener, making the system crosslinked and brittle.
    Remember also that the glued elements cannot be loaded for a minimum of 24 hours.
  • #6 15254738
    Macosmail
    Help: 227
    Rate: 863
    Besides, glue holds the best as him "nima" ;-)
  • #7 15255314
    zimny8
    Help: 26
    Rate: 505
    Macosmail wrote:
    glue holds up best as "nima" ;-)
    There was an episode of "Probes" :) , two surfaces of the metal so "polished" that atomic bonds are already interacting.
    Bonding surface too small?
  • #8 15255342
    MARCIN.SLASK
    Home appliances specialist
    Help: 1038
    Rate: 2662
    You can try another glue: eg Technicoll 7706 (or similar) - liquid metal, epoxy. It is true that it is much more liquid than Poxipol, but according to I am more suitable for bonding metal.
    Unfortunately, the element would have to be disassembled and after applying the glue, grab the elements with something. The glue hardens only after 12-18 hours. Complete hardening after 48 hours.
  • #9 15255380
    Macosmail
    Help: 227
    Rate: 863
    He was there :)
    The point is that the surfaces should be as close to each other as possible, and the adhesive layer between them should be minimal. The surfaces should also be as rough as possible (the active surface increases)
    For this reason, cracks are best glued together, where everything fits together.
  • Thin epoxy layers bond better than thick layers using Technicoll 7706
    #10 15255658
    telecaster1951
    Help: 829
    Rate: 818
    Macosmail wrote:
    and the glue between them is minimal.
    So that interactions occur between the surface of the glue and the element and the element and the glue. If there is a thick layer of glue, the interactions between glue and glue are generally weaker.
    Remember, however, that it is an epoxy resin. When well prepared, it has ABS strength. It's clearly badly done here.
    MARCIN.SLASK wrote:
    Technicoll 7706 (or similar) - liquid metal, epoxy glue.
    I use this at the university: http://janasc.com/wycice_epoksydowe.html
    As for me, there is no better resin. Odorless, with the consistency of kissel. Pre-dries in 2 hours. After 24 it cannot be moved.
  • #11 15265303
  • #12 15265922
    landy13
    Help: 195
    Rate: 260
    trymer01 wrote:
    cylindrical drill tips fi3 work well as bars, it is advisable to slightly puncture their surface, e.g. with a hammer, cut the notches with a grinder, etc.
    Or use threaded rods. Eg screws without a head.
    If we also make a thread or something similar in the hole, the strength of such a connection increases many times.
  • #13 15277568
    km500
    Rate: 8
    .. and Droplet?
    what do you think ordinary glue looks like. Droplet: effects vs need to sand the surface vs strength?
    because sometimes we combine and combine and the simple solution is under our breath ... :)
  • #14 15277639
  • #15 15278263
    telecaster1951
    Help: 829
    Rate: 818
    Cyanoacrylate is not an adhesive for such applications. It is a contact adhesive that sticks to small surfaces. It is perfect for sticking gaskets to metal elements, for gluing glass splinters or small elements made of some plastics. It is absolutely not suitable for gluing heavy-duty elements.
  • #16 15575189
    km500
    Rate: 8
    Perhaps the cause was an out-of-date adhesive. I don't know, because I changed a few things at the same time:
    I bought a different glue
    I prepared the surface
    I degreased
    And so far it holds
The discussion revolves around the failure of Poxipol adhesive in bonding a metal bathroom paper holder. Users suggest that proper surface preparation is crucial, including roughening, cleaning, and degreasing the surfaces before application. The importance of using an activator is highlighted, as well as the potential issue of using too much hardener, which can make the bond brittle. Alternatives to Poxipol, such as Technicoll 7706 and other epoxy resins, are recommended for better adhesion on metal. Some users propose mechanical reinforcement methods, like drilling holes and inserting steel rods or screws, to enhance the bond strength. The possibility of using outdated adhesive is also mentioned as a potential cause of failure.
