Ultimate Speed Charger from Lidl: Compatibility with C330 Tractor Battery?
magnus27 4767 19
Can I use the Lidl Ultimate Speed charger to charge the battery in a C330 tractor?
Yes, but only very slowly: the charger’s maximum charging current is 3.8 A, so charging a large tractor battery will take a long time [#16200734] For the C330, users mention either a 12 V 165 Ah setup from two 6 V batteries or sometimes a single 12 V battery around 100 Ah, so the charging time can be roughly 24 hours for 80 Ah, about 31 hours for 120 Ah, or even 48–72 hours for the larger C330 battery set [#16200784][#16200751][#16200799] If the batteries are relatively new and functional, it should work; if they are old or heavily worn, their self-discharge/idle current can make charging ineffective [#16200784] A practical approach is to charge overnight, then try starting the tractor; after that, if it runs for a long time, the generator/alternator can help recharge it further [#16200784][#16200799]
  • #1 16200726
    magnus27
    Rate: 310
    I have the ultimate speed charger from the lidl, can I use it to charge the battery from the c330 tractor?
  • #2 16200734
    DEDMAN
    Help: 19
    Rate: 73
    Theoretically yes, but it will be a torture of 6V 165Ah, and here you have a maximum current of 3.8A, it will "take a while". Better find something more current-efficient.
  • #3 16200740
    Adam-T
    Help: 834
    Rate: 1096
    You did not provide the current efficiency of this power supply as well as the battery capacity. Generally, you can only charge when the charger is "small" and the battery "large", the charging will take much longer. Obviously, the rectifier and battery voltages must be the same.
  • #4 16200751
    nuszek
    Level 30  
    Help: 123
    Rate: 389
    Uncle gooo ...
    will answer .
    The maximum charging current is 3.8 A, I do not know how much the battery from the tractor has, but probably about 120 Ah - i.e. the charging time is about 120 / 3.8 = 31 hours, but if it is not fully discharged, you can try it the next day start the tractor.
  • #5 16200784
    Xantix
    Help: 686
    Rate: 1657
    nuszek wrote:
    The maximum charging current is 3.8 A, I do not know how much the tractor battery has, but probably 120 Ah
    By default, the toilet 330 is equipped with a 12 V 165 Ah battery (2 batteries for 6 V). At a charging current of max. 3.8 Ah, the charging time of these batteries will reach 48 hours.
    Although many users often find only one 12 V battery with a capacity of about 100 Ah (it has a single 12 V 98 Ah battery installed itself) - then the charging time will be much shorter.
    Besides, if these are already quite old batteries, they can consume quite a significant idle current (2-3 A), which can make it almost impossible to charge such batteries.
    To sum up - if they are relatively new / functional batteries, you will charge them somehow, although it will take quite a long time. However, if the batteries are old / heavily worn out, you may not be able to charge them.
    However, you can connect a rectifier - at most charge the battery with a rectifier overnight, then start the tractor (if it works) and recharge the batteries with a generator / alternator.
  • #6 16200796
    bizon_126
    Help: 108
    Rate: 566
    You're kidding, the generator has 150 W of maximum power, which can be obtained at quite high engine revolutions
    Well, unless it has an alternator, it can be done
  • #7 16200799
    rafbid
    Help: 153
    Rate: 418
    Yes, you can, from the user manual of a similar charger, it was clear that charging the 80Ah battery takes 24 hours, in practice 170 Ah 12 V the battery was charged for about 3 days. The rectifier may have a security that after a day it stops charging (I assume that you have read the operating instructions). If the battery capacity exceeds the capacity supported by the charger, then it must be turned on again after a day.
    There is nothing to worry about as the charging will take 72 hours, we do not know the algorithm that the processor of this rectifier drives
  • #8 16200849
    Xantix
    Help: 686
    Rate: 1657
    And the author's rectifier has about 50 W of maximum power. What is stronger? This rectifier or generator?
    When he starts the tractor and works with it for a long time, he will recharge it with a generator (provided that he will not use the lights and start the engine frequently).
  • #9 16200899
    bizon_126
    Help: 108
    Rate: 566
    Rather, no field work comes into play
    I have bad experiences with generators, I do not say that I will not recharge it, but it will take a while
  • #10 16200925
    rafbid
    Help: 153
    Rate: 418
    And what voltage did you get on the generator?
  • #11 16200930
    Xantix
    Help: 686
    Rate: 1657
    bizon_126 wrote:
    I have a bad experience with generators
    I am not better - where I had power generators, the battery lasted only 2 seasons. After replacing it with an alternator with a battery, I have 5 years of peace and nothing indicates that the battery will end quickly.
    bizon_126 wrote:
    I am not saying that I will not recharge, but it will take a while
    And I'm not saying otherwise. But I know I can. This is what I had to do once, because it happened that the tractor was left at the traffic lights and the battery died completely. I recharged the battery overnight with a toddler charger (max 4 A). In the morning I managed to start the tractor - I worked it all day with a front loader (you know, it worked quite high) and, surprisingly, the generator was able to charge the battery.
    For sure the alternator would do it much faster.
    And what was I supposed to achieve? Not less than 13.8 V - increasing with charging.
  • #12 16201046
    rafbid
    Help: 153
    Rate: 418
    I have never measured it exactly, for the c330 it is 400 rpm and the generator starts charging from 800 rpm after increasing the rpm, you would have to wait 10 minutes before the voltage reaches 13.8 V
  • #13 16201076
    Xantix
    Help: 686
    Rate: 1657
    rafbid wrote:
    I did not measure the idle speed for the c330 it is 400 rpm
    Not 400, but 550 rpm.
    rafbid wrote:
    and the generator starts to charge at 800 rpm after increasing the revs, one would have to wait 10 minutes before the voltage reaches 13.8 V
    Even if you had to wait these few minutes for the voltage to rise to 13.8 V, what is the meaning of it considering the fact that the tractor worked almost 9 hours almost continuously? When the engine was running continuously, the voltage remained at least 13.8 V even if the revs dropped. And it was work with a front loader, so all the time in the upper RPM range.
    I wrote about the fact that if you work with the tractor for a long time without using the lights, you can recharge the battery in a drip, even with a generator - and I am talking about this in describing my own experience.
  • #14 16228136
    magnus27
    Rate: 310
    I have a question, what voltage should a fully charged c330 battery have on the terminals after a longer stop (e.g. overnight)?
  • #15 16228155
    Xantix
    Help: 686
    Rate: 1657
    A 6 V battery, when fully charged, should have a voltage of about 6.3 V.
  • #16 16228179
    magnus27
    Rate: 310
    And two 6v batteries connected in series 12.6V should I understand?
  • #17 16228202
    Xantix
    Help: 686
    Rate: 1657
    Yes exactly.
  • #18 16228228
    magnus27
    Rate: 310
    Mine has 12.2 volts. Is it possible to determine the degree of its charge from this?
  • #19 16228234
    mczapski
    Level 40  
    Help: 468
    Rate: 1658
    My colleague, magnus27, instead of reading the manual for this rectifier, asks questions of the public. People show off elkwency not knowing the reality, i.e. what are the batteries in practice, and whether a tractor for generators or an alternator. After numerous observations in nature, it is difficult to ask about the technical condition of the machine.
    So the answer can be of course yes. But you won't get any effect if you want to charge them in 10 minutes. And I often find that charging is needed immediately before starting. And the more you can charge your batteries with this charger throughout the night, since there is a suspicion of their poor condition. Oh. Colleagues are figuring out that there are two batteries there. This is true, but the voltage of both connected in series is important for vehicles, so I do not know if there is any point in exposing it. We will soon find out that this rectifier has burned down.
  • #20 16228287
    Xantix
    Help: 686
    Rate: 1657
    You can roughly say - this voltage means that the battery has about 50-60% of the charge in it.
The discussion revolves around the compatibility of the Lidl Ultimate Speed Charger with the C330 tractor's battery. Users confirm that while the charger can theoretically charge the tractor's 12V 165Ah battery, the maximum charging current of 3.8A will result in a lengthy charging time, estimated between 31 to 48 hours depending on the battery's condition. Concerns are raised about the efficiency of charging older batteries, which may draw idle current, complicating the charging process. Users suggest that if the battery is not fully discharged, it may start the tractor the next day. Additionally, the importance of matching rectifier and battery voltages is emphasized, along with the potential for using a generator or alternator for more efficient charging once the tractor is operational. The voltage readings of the battery are also discussed, with a fully charged 6V battery expected to show around 6.3V.
