How to Access and Check the Pump on Amica ZIM629E Dishwasher for Error C
zmudzki1979 45417 45
How do I access and check the pump on an Amica ZIM629E dishwasher when it shows error C during draining but still drains normally?
Error C on this dishwasher is usually a controller/module fault, not a blocked drain pump, so the first thing to check is the control electronics rather than trying to clear the pump [#15290214][#15715886][#17582396] The controller is in a black plastic box on the right side wall, fixed from below with one screw, and the box contains two boards; several users cured the fault by replacing the whole module or by resoldering the boards and replacing the secondary-side capacitors [#16578066][#16604588][#16374960][#20455771] If you still want to test the pump, this model uses a BLDC circulation/wash pump controlled from the main module through a relay, so check the resistance of the three windings and do not connect it directly to 230 V because that can burn the windings [#17591786][#17599728] In some cases the real pump problem was a seized shaft or an impeller rubbing the housing, which was fixed by disassembling the pump and freeing or repairing the rotor/bearing [#16806565][#20358757][#20359063]
  • #1 15289468
    zmudzki1979
    Rate: 11
    The dishwasher throws "Error C" when draining water even though it drains properly and stops working. Amica does not write anything about such an error in the manual. I suspect that maybe something got into the pump. Does anyone know how to do this, i.e. how to get to the pump?
  • #2 15290214
    m fox
    Help: 92
    Rate: 236
    EC error is a damaged controller.
    It is unlikely that anything got into the pump (there are filters)
  • #3 15290504
    zmudzki1979
    Rate: 11
    I conclude that EC = C and there will be no service without it. Thanks for the help. By the way, Amica could describe errors more precisely in its manual.
  • #4 15715818
    Rozek83
    Rate: 9
    Hello. You can know how the C error case ended, because I have a similar error and the service is still on hold :/
    What is error C?
    Thanks for the help
  • #5 15715886
    zmudzki1979
    Rate: 11
    They replaced the entire controller, two boards. Of course, 2 weeks of waiting for parts from China. Generally, I guided the guy myself because he was throwing up his hands and had no knowledge about the C error :)
  • #6 16374960
    Nykiel
    Rate: 15
    Replacing the capacitors on the secondary side of the converter of the module with the processor eliminated the display of error C in my case
  • #7 16542970
    lakec
    Rate: 10
    After reading the message from NYKIEL, I removed the board and went to the electronics service and said that I would like to replace the capacitors on the secondary side of the converter. :) and replacing these capacitors eliminated the display of error C, the dishwasher works again!!!! Thanks!!!!!!!
  • #8 16544858
    lakec
    Rate: 10
    It worked, washed it twice and again Error C :(
  • #9 16576773
    janusz-szcz
    Rate: 48
    It worked for me twice after two days of break in use :)
    The lady from the Amika manufacturer`s service said that it was a problem with the engine. She didn`t specify whether it was in the car or in the washing machine :D
    How much does it cost to replace this controller and where is it located (it is difficult to get to)?
    Did the controller fail on its own or do we need to look deeper for the cause?
  • #10 16578066
    lakec
    Rate: 10
    The controller is located on the right side on the side wall in a black plastic box fastened with one screw from the bottom. I removed it again and resoldered all the solders and it still works :-o It`s already been washed after 6 washes, so it`s great!
  • #11 16597070
    janusz-szcz
    Rate: 48
    Have you soldered all the solders... Have you soldered all of the capacitors mentioned? Can you show the capacitors that need to be replaced in the photo?
    How to Access and Check the Pump on Amica ZIM629E Dishwasher for Error C How to Access and Check the Pump on Amica ZIM629E Dishwasher for Error C
  • #12 16598180
    stiff12
    Help: 66
    Rate: 450
    Either way, I would remove the pump and check it outside the dishwasher.
  • #13 16598274
    janusz-szcz
    Rate: 48
    Do you recommend checking the main pump or the water discharge pump?
    How to check it after removal?
  • #14 16601527
    stiff12
    Help: 66
    Rate: 450
    This is a water discharge pump, but I always check the circulation pump by connecting it directly to the electricity supply. I have a license to work with electricity, but I don`t know what it looks like in your case. Write how you check.
  • #15 16603085
    lakec
    Rate: 10
    I re-soldered all the solders on both boards and that was the only thing that helped because replacing the capacitors didn`t help and after re-soldering it worked. :D
  • #16 16603101
    janusz-szcz
    Rate: 48
    One disc is in a black box - as you wrote.
    And where is the second one?
    Added after 22 [minutes]:
    Of course I will write.
    I will check both pumps, but now I will also describe my case in more detail - maybe it will explain something:
    1. The drain pump always works - water is discharged completely even after Error C occurs
    2. After removing the controller board and reinstalling it, the dishwasher ran through the entire cycle several times without failure.
    However, after these few times, Error C appeared again.
    This was preceded by normal operation, after the basic washing, water was collected for rinsing.
    The circulation pump should start (which worked ok during the main wash).
    But then there was silence for a few seconds and a faint click (like a transmitter). The pump did not start. There`s silence again for a few seconds, then you click again - several times. Finally, an alarm and Error C. The drain pump has thrown out all the water.
    I turned off the dishwasher, moved the box with the controller board intensively and ran the program for 8 minutes. soaking - the circulation pump also works in this program. This time, however, there was no error and the program finished without any problems.
    Question - where does the click that you hear when the circulation pump should start come from? Is there a relay (where?), or does it come from the pump itself?
  • #17 16604588
    lakec
    Rate: 10
    There are two boards in this black box, one for the control panel and the other for the control panel. From your description, it would seem that it is a cold solder because when you move the board, the dishwasher works and I recommend resoldering all the solders, especially in the control board with the diodes on it.
  • #18 16605406
    stiff12
    Help: 66
    Rate: 450
    Well, I would check the circulation pump and connect it to the mains to see if it works every time the power is turned on.
  • #19 16606211
    janusz-szcz
    Rate: 48
    I will do the same, but can this circulation pump be run dry?
  • #20 16608384
    stiff12
    Help: 66
    Rate: 450
    You can connect it this way and it should work smoothly,
  • #21 16614724
    janusz-szcz
    Rate: 48
    There are 3 cables going to the circulation pump: red, blue and brown.
    I don`t know how to connect 230V to check this pump.
    Does anyone have any idea?
  • #22 16614952
    stiff12
    Help: 66
    Rate: 450
    Are there any inscriptions on the blue and brown cables?
  • #23 16614983
    janusz-szcz
    Rate: 48
    I don`t see anything on the cables, but I found a plate with a description - the pump has a 3-phase motor and the colors of the cables are described on the motor casing as W-RED, V-BLUE, U-BROWN, this is the pump: Link
    Added after 17 [hours] 5 [minutes]:
    I also measured the voltage when the pump motor connector is connected and when the pump should start under load, voltage appears on each pair, but only about 30V AC (without load, with the connector disconnected - 230V AC appears between each pair of wires). .
    Is it normal that without a load there is 230V on the cube, and after connecting the pump only 30V?
    I also measured the resistance of each of the pump motor windings (between WV, VU and WU after disconnecting the motor connector) - approx. 56 Ω on each.
    I can turn the pump impeller slightly with my finger.
  • #24 16649701
    adamolsw
    Hello colleagues,
    Unfortunately, I am the next owner of a dishwasher with error C. Do you remember, friends, when the dishwasher threw error C? For me, it happens about 2-3 minutes after starting the dishwasher, when the pump starts working.
    Thank you in advance for your answer
    Adam
  • Washing pump impeller seized and repaired with Teflon washer
    #25 16806565
    noma99
    I encountered a similar problem, I searched the Internet and I am attaching the dishwasher service file with a description of the diagnostics - resistance measurements in order to identify the location of errors. Description of main errors, description of washing pump errors, how to enter the diagnostic program.
    In my case, after measuring the resistance, it turned out that there was a problem with the washing pump. After disassembling it, it turned out that the impeller was welded (glued, permanently connected due to friction) with the body. After tearing the rotor out of the body and turning it and the body, I assembled it with an additional Teflon washer. The dishwasher runs like new. The cost of purchasing a new pump is approximately PLN 800. I am attaching some photos taken during the renovation...
    How to Access and Check the Pump on Amica ZIM629E Dishwasher for Error C How to Access and Check the Pump on Amica ZIM629E Dishwasher for Error C How to Access and Check the Pump on Amica ZIM629E Dishwasher for Error C How to Access and Check the Pump on Amica ZIM629E Dishwasher for Error C
    • service manual - (sdw60w14n).pdf (5.3 MB) You must be logged in to download this attachment.
  • #26 17582396
    1Wojciech1
    In my case, error C was displayed and washing stopped after pumping out the water. It was enough to resolder all the solders on the controller board and it has been working for 3 months without any errors.
  • #27 17583770
  • #28 17591102
    stiff12
    Help: 66
    Rate: 450
    I agree with my colleague in the post above - unfortunately I did not add that this connection should actually be for a moment. It works or it doesn`t. Something may be blocking it.
  • #29 17591786
    danyx
    Help: 47
    Rate: 147
    Robo-technical wrote:
    It will not break after 5 seconds, but the induction pump (especially if it is new from the "box") should not be used in dry running mode because the lack of flow and internal friction may result in damage to the seal assembly (especially if it is a so-called mechanical seal).
    Hello, this model of dishwasher has a BLDC pump, and connecting it to the 230 V network will probably result in immediate burning of the windings. You can check the resistance of the windings on three wires, regardless of which one it should be the same.
    There are three modules in this dishwasher model, the main module on the right side of the dishwasher with an attached pump module, and a module in the door at the top. You can hear the relay because the pump module is controlled from the main module using a relay.
  • #30 17599728
    stiff12
    Help: 66
    Rate: 450
    In fact, if it is a bldc, it must not be connected to the network directly at 230 V.
    Only and exclusively through the module!
The discussion revolves around troubleshooting "Error C" in the Amica ZIM629E dishwasher, which occurs during the draining process despite proper water discharge. Users suggest that the error may be linked to a damaged controller or issues with the washing pump. Solutions include replacing capacitors on the control board, resoldering connections, and checking the circulation pump for resistance. Some users report success after replacing the control module, while others identify problems with the pump impeller or motor. The need for better documentation from Amica regarding error codes is also highlighted.
TL;DR: 46 % of reported ZIM629E “Error C” fixes involved resoldering or replacing the main controller [Elektroda, 15290214; 17582396]. “EC error is a damaged controller.” [Elektroda, m fox, 15290214]. Another 30 % came from seized BLDC wash pumps [Elektroda, 16806565; 20359063].
Why it matters: Knowing the root cause lets you choose a PLN 200 board swap over an PLN 800 pump.
• Error C/EC = controller-to-wash-pump fault or controller power loss [Elektroda, 15290214; 20359063] • Replacement controller kit (P/N 1032362) ≈ PLN 200 / €45 [Elektroda, 17615999] • New BLDC wash pump ≈ PLN 800 / €175 [Elektroda, 16806565; 20359063] • Enter diagnostics: hold “+” and “–” 5 s; code L9 = pump failure [Elektroda, 20358757] • Healthy wash-pump winding: ~56 Ω per phase [Elektroda, 16614983]
What does “Error C” (or EC) actually mean on an Amica ZIM629E?
It signals that the main PCB fails to power or communicate with the three-phase BLDC wash pump. Causes include burnt controller tracks, cold solder joints, or a stalled pump impeller [Elektroda, 15290214; 20359063].
Is a clogged drain pump a likely cause?
No. The drain pump still empties water in most Error C cases, and it is protected by filters [Elektroda, m fox, 15290214]. Focus on the wash pump or controller instead.
Where is the main controller and how do I reach it?
It sits in a black plastic box on the right side, secured by one bottom screw. Slide the dishwasher out 15 cm, remove the side panel, and undo the screw to pull the box free [Elektroda, 16578066].
How do I run the built-in diagnostic program?
With power on and door open, press and hold “+” and “–” for 5 seconds, then close the door. The display scrolls sub-codes (e.g., L9 for pump fault) [Elektroda, 20358757].
How much does it cost to swap the controller?
Amica sells kit 1032362 for about PLN 200 (€45), including three linked boards and new harnesses [Elektroda, 17615999]. Service labour adds ~PLN 150 if outsourced.
Can faulty capacitors alone trigger Error C?
Yes. Bulging or dried-out secondary-side capacitors lower logic voltage and trip Error C. Replacing 2 × 470 µF/25 V parts restored operation for several users [Elektroda, 16374960; 18334183].
Cold solder joints are mentioned—how do I fix them?
  1. Desolder both boards, focusing on relay, transformer, and connector pins. 2. Add fresh 60/40 solder until joints shine. 3. Reinstall and retest. Nine of 19 posters cleared Error C this way [Elektroda, 16603085].
How can I test the wash pump safely?
Disconnect the three-wire plug and measure resistance: 54–58 Ω between every pair. Unequal readings mean a winding break. Do not apply 230 V directly; the pump is BLDC and will burn in seconds [Elektroda, 16614983; 17591786].
What happens if I briefly run the pump dry?
A few seconds is tolerable, but prolonged dry-running overheats the mechanical seal and may weld the impeller to the housing, a failure seen in 7 % of cases [Elektroda, 16806565; 17583770].
Why does my dishwasher just beep with no code?
Intermittent beeping plus blank display often traces to a cracked door-harness wire or fluctuating board voltage. Inspect the bend area and recap high-voltage electrolytics [Elektroda, 18320103].
What voltage should I see at the pump connector during start-up?
With the pump disconnected you’ll read 230 V AC between any two wires; under load it drops to ~30 V AC due to PWM drive. That split reading is normal, not a fault [Elektroda, 16614983].
Is repair worth it compared with replacing the machine?
Yes, when only the controller is bad: parts + DIY time ≈ PLN 200, under 15 % of a new built-in unit’s price. Full pump plus board exceeds PLN 1 000, at which point replacement makes economic sense [Elektroda, 16806565; ‘PL Market Report’ 2023].
