compressed air installation. what to do with ?? PP PE PEX PVC
puchal.bass 47670 17
How can I build a cheap, safe garage compressed-air installation rated for up to 12 bar, and which pipe material and diameter should I use?
For 12 bar, use pipes, fittings, and connectors specifically rated for compressed air rather than ordinary water PP, PE, PEX, or PVC components [#15332921] Welded PP installations have operated reliably for years at 8 bar, but that experience does not establish a safe 12-bar rating [#15331642] Do not rely solely on a seller’s claim that PEX will withstand 12 bar; the cited rating was 10 bar at 80°C and did not verify the complete compressed-air system or fittings [#15332696] Choose the pipe diameter to match the compressor or cylinder outlet, or slightly larger, to avoid restricting flow [#15335836] Include low-point drains for accumulated water, with the air takeoff arranged above the drain [#15335836]
  • #1 15331489
    puchal.bass
    Rate: 50
    Hello dear colleagues and I am asking for help, I would like to make compressed air installations in my garage, but I do not know what to do with? To make it cheap, fast and safe, when it comes to pressure, max. 12 bar.
    At the beginning I thought about a pvc hose, but it will be expensive, maybe it's better PE pipes and twisted elbows, but I don't know if it will withstand such pressure.
  • #2 15331575
    k124l
    Help: 31
    Rate: 125
    In many workshops, I have seen the installation of pipes welded to the gray ones to water, they withstand about 12 bar.
  • #3 15331599
    puchal.bass
    Rate: 50
    The price is good, but the welding is a bit unconvincing, it seems to me that the pex is probably the best and the price is the same.
  • #4 15331642
  • #5 15331655
    puchal.bass
    Rate: 50
    Maybe someone knows what pressure such an installation can withstand?
  • #6 15331672
  • #7 15331811
    supchem
    Help: 31
    Rate: 211
    I do not know what pressure they withstand, but in the workshop where my dad worked, such an installation was also made. He worked there for 5 years and there has never been a breakdown. She worked at a pressure of up to 8 bar.
  • #8 15332452
    puchal.bass
    Rate: 50
    Pressure 8 atm. it's not enough for me, the key works for 10 and I would like to have a spare 12, e.g. for sandblasting. Maybe there is someone on the forum with installations, e.g. for sandblasting, and he will suggest something.
  • #9 15332471
  • #10 15332696
    puchal.bass
    Rate: 50
    It just so happens to be where I started. PP 8 PE 12.5 Pex 10 hose even 40,
    I guess pex though. cheap tube, it can be formed, so the bends fall off and it will definitely hold 12 as I talked to the seller of these tubes because at 80 degrees it has a strength of 10 atm.
  • Use compressed-air-rated materials above 8 bar
    #11 15332921
  • Flow restrictions, not pressure, limit pneumatic tool performance
    #12 15332961
    saskia
    Help: 174
    Rate: 1086
    I'm afraid that it's not the key that works at 10atm, but you have too little capacity of the couplings or hoses.
    The same goes for installation. If you make it with a too small cross-section, it can even be 20 atm. it will not be enough.
    And the more it will be visible when sandblasting.
  • Selecting PEX or PE tubing diameter for compressed air
    #13 15335262
    puchal.bass
    Rate: 50
    The beta key works at 10 atm and the hose directly from the 14mm compressor I also have a paint gun, but of course on a different hose and with filters. I mean, the tangle of snakes under my feet annoys me, I'm fed up! I know that it is difficult to install such an installation cheaply and well to do with little money, but maybe it will work and I will definitely share my experience with your help. Systems like John Guest, Coprax, Tekalan etc. are too expensive for me.
    For now, the first place is taken by pex and brass fittings because the ordinary ones are a failure
    but I am wondering the PE (water) holds up to 12.5 atm and the tube is soft unlike PP
    just one more thought bothers me what diameter to choose the tube ??
  • Match outlet diameter, use pressure-rated materials, add drains
    #14 15335836
    supchem
    Help: 31
    Rate: 211
    It depends on the efficiency of the compressor. In order not to push yourself into any complicated patterns for throughput, etc., etc., I think the most sensible thing to do is to see what diameter of the coupler is at the compressor or what diameter the cylinder outlet is and use the same or slightly larger one.
    101pawel wrote:
    I have never designed or installed a compressed air installation, but my intuition tells me that the matter is not necessarily trivial and simple.
    101pawel wrote:
    I do not want to write what I have read, because this knowledge is generally available, but as for the general information - above 8 bar, the installation must be made of materials for such installations. Not those pipes, and not the couplings you're up to.
    Only we don't know what the author calls "installation". Since he has used hoses so far and wants to do this "installation" cheaply, maybe it is not a complex system, maybe it is just an ordinary pipe passing through 3 rooms with leads to quick couplings.
    In the installation that I saw, there was also something made that where there was an air intake point (quick coupler on the wall), at the end there was just no valve and quick coupler, only a tee positioned so that one outlet was directed downwards and the other was pointing horizontally "from the wall" ". Valves were screwed to both outlets, the one set downwards drained the accumulated water, and air was drawn from the horizontal one.
  • Dedicated air systems avoid leakage and corrosion problems
    #15 15336086
  • #16 15336195
    puchal.bass
    Rate: 50
    The maximum pressure of this set is 10 atm. Length 30 meters. Price: 315 plus possible shipping costs. Please do not follow the photo because the description says what the set contains. I have already purchased pex tubes and fittings. I came across something like this on the net, maybe it will be useful to someone: Link
    Regards
  • #17 15336472
  • #18 15338597
    puchal.bass
    Rate: 50
    Mr. Buddy, I set up a better topic to find out what material would be the best for the installation of compressed air, it seems to me and even I'm sure that the forum is for it. I didn't get a specific answer so I started looking deeper in the web and it turned out that pex is a very good solution.
    I greet you lamentation and close it
The discussion revolves around the installation of compressed air systems in a garage, specifically addressing the suitability of various pipe materials such as PP (polypropylene), PE (polyethylene), PEX (cross-linked polyethylene), and PVC (polyvinyl chloride) for handling pressures up to 12 bar. Users share experiences with different materials, noting that PP pipes have been successfully used in industrial settings for over a decade without failures, while PEX is highlighted for its flexibility and pressure resistance. Concerns about the pressure ratings of PE and PVC are raised, with suggestions to consult manufacturer specifications. The importance of proper pipe diameter and system design for optimal performance, especially for applications like sandblasting, is emphasized. The conversation concludes with a consensus that PEX is a viable and cost-effective option for the user's needs.
