What is the procedure for replacing the battery in the Satel integra 32 control
kc2ine 46125 15
How do I replace the battery in a Satel Integra 32 control panel, and what happens if the battery is fully discharged during a mains power outage?
You can replace the battery without a full system shutdown, but the safe procedure is to put the panel into service mode if needed for tamper protection, then disconnect the mains first and the battery second; when restoring power, connect the battery first and then the 230 V mains [#15331978][#15332086] If you do a complete power-off, the panel should start again only in that same order because the charger/protection circuitry is designed for it, and a faulty or deeply discharged new battery can otherwise risk damaging the charging system [#15332086][#15332313] Several users note that in practice the battery can also be swapped with mains still on, and the battery trouble LED may stay on for a few minutes before clearing [#15332111][#15333316] If the battery is already exhausted and the mains fails, the panel disconnects the battery at about 9.5 V and the system stops; the siren only howls if it has its own backup supply [#15332086][#15332111] Opening the enclosure without service mode can trigger the tamper alarm if that protection is enabled [#15332111][#15332917]
  • Battery replacement procedure and power-failure behavior
    #1 15331960
    kc2ine
    Rate: 20
    I just have a battery in the control panel flashing with a yellow LED and I would like to replace it myself, but I'm not sure what the procedure is. Can I do this without disconnecting the mains power? Just disconnect the battery and plug in a new one?
    By the way, the question is, what will happen if the battery is completely discharged and there is a power cut? Will the control panel simply stop and the system will be inactive, or will the siren be activated?
    thanks
    mod: suvorov
    Also worth reading:
    Satel Integra - installation and configuration of the system - selected issues
    I invite you to read the other guides, highlighted topics and articles on security systems :
    Stationary security. Alarm systems, Cameras, Intercoms, Gate and roller shutter drives, Home automation. Highlighted topics and guides.
    If you do not find the answer to your question in the above-mentioned topics, please visit the forum
    https://www.elektroda.pl/rtvforum/forum77.html
    I also encourage you to visit the General Guides section, where you will find materials from other forum sections, including those for those who are just starting their adventure with electronics. :
    https://www.elektroda.pl/rtvforum/forum510.html
  • #2 15331978
    Plumpi
    Heating systems specialist
    Help: 877
    Rate: 2690
    You must have a service password.
    Before opening the housing, you activate the service mode so that the tamper contact located in the housing does not trigger the tamper alarm unnecessarily.
    Disconnect the AC power first, and then the battery.
    You connect the other way around. Battery first, then mains power.
    You close the casing and exit the service mode.
    Battery replacement sequence and mains-disconnection question
    #3 15332003
    Stan-Mar
    Help: 96
    Rate: 139
    You close the cover and exit the service mode.
    I'm sorry to interfere, but can my colleague explain to me why he should turn off the mains power when replacing the battery. I have been replacing batteries in control panels for over 15 years and now I have found out that I was doing it wrong all the time. When replacing, I disconnect the old battery, check and clean the contacts, and then connect the new one.
    STAN-MAR ZABEZPIECZENIA Stanisław Karzecki
    Kanta 12/42, Olsztyn, 10-691
  • Battery-first, mains-second startup procedure from SATEL instructions
    #4 15332086
    Plumpi
    Help: 877
    Rate: 2690
    Sometimes it makes sense to read the manufacturer's instructions.
    5.1.2 CONTROL PANEL POWER START PROCEDURE
    1. Connect the emergency power supply cables to the appropriate battery terminals
    (red to battery positive, black to battery negative). The control panel will not start after
    connecting the battery only (without the mains power connected), and
    it will work in case of 230V voltage failure - if it was already there before
    launched.
    Note: If the battery voltage drops to approx. 11 V during the control panel operation, the control panel
    will report a battery failure. After the voltage drops to approx. 9.5 V, the control panel disconnects
    battery (system stops).
    2. Connect the ~ 230V AC mains supply - the control panel operation starts.
    The sequence of switching on the power mentioned here (first the battery, then the 230V mains)
    will enable the correct operation of the power supply and the control panel electronic protection systems, thanks to
    which avoid damage to the alarm system components caused by
    possible assembly errors. The modules should be started in a similar way
    with its own power supply.
    Note: If there is a situation where it is necessary to disconnect the power completely
    the control panel, the mains and the battery should be disconnected in turn. Power on again
    should take place in the sequence described above (battery first, and
    then 230V alternating voltage).
    After all electrical connections are made and checked for correctness,
    you can proceed to start the system. It is recommended to start working with the control panel without
    connected sirens, by loading the high-current outputs with 2.2k? resistors.
    SATEL INTEGRA 40
    The signaling devices can be connected only after the parameter programming is completed
    the alarm system being implemented.
    Recommended for systems with self-powered expansion modules
    starting the control panel first, and then the other parts of the system successively.
    This is actually an excerpt from the Integra installer manual, but exactly the same procedures were required on the lower and older models I dealt with.
    Battery replacement can proceed with mains power connected
    #5 15332111
    bartek0808
    Help: 29
    Rate: 23
    The correct procedure is as described by colleague Plumpi.
    Nothing bad will happen if you remove the old battery and connect a new one without turning off the mains power, the control panel will not detect a new battery immediately, so the failure will blink for a few more minutes. If you do not activate TS, when opening the housing you can trigger an alarm. Will the siren sound like the control panel it will turn off completely, it depends if you have a siren with support, if so, it will start to howl, if not, it will not start. After the control panel has completely shut down, the control panel does not lose its settings, you do not need to reveal anything.
    Correct Integra battery replacement power-up sequence
    #6 15332117
    sosarek
    Help: 9321
    Rate: 15545
    So read carefully - this is about starting the control panel, not replacing the battery.
    How is it supposed to exit the service mode if the control panel goes off in alarm?
    You have Specialist-Heating systems entered and I would suggest staying with it and not writing nonsense.
    bartek0808 wrote:
    the control panel will not detect a new battery immediately, so the trouble will blink for a few more minutes
    Integra recognizes almost immediately, in the old CAs the time of checking the presence of the battery was about 15 minutes.
    Z
    Pka, Poznań, 60-850
  • Disconnect mains to protect the battery charging circuit
    #7 15332313
    Plumpi
    Help: 877
    Rate: 2690
    So what if someone appreciated my knowledge in this field and gave me such a specialization at Electrode?
    I have been dealing with heating systems for about 15 years.
    Alarm installations for over 20 years.
    Electronics (including design and commissioning), industrial automation and electrics for almost 30 years.
    I have dealt with and still do professionally.
    Currently, I do not make too many alarms, because I not only deal with alarms, but I deal with installations in newly built houses comprehensively, i.e. electrical installations, automation, alarms and heating systems, and above all, linking all installations together. I often do simple home automation based on alarm systems. So I have some experience in this area.
    So please do not give yourself that kind of remark.
    Here it is more about the possibility of short-circuiting the wires and damage to the electronic system responsible for charging the battery and damage caused by a "shaky" newly purchased battery.
    As for the power outputs on the motherboard, they are protected against short circuits. Unfortunately, the battery charging system does not.
    Even when you bring a new battery from the store, you don't really know its technical condition. Unless you measure it. If you get a faulty one, e.g. with a damaged cell, or if it is old and deeply discharged, then by replacing it without turning off the mains power, there is a high probability that you will damage the battery charging system. If you do restart, disconnecting the mains power supply, connecting the battery and connecting the mains supply, the battery supervision system will not allow the charging system to be turned on and damaged, and the control panel will signal a battery failure.
  • #8 15332501
    bartek0808
    Help: 29
    Rate: 23
    Almost immediately, it does not mean immediately, so for a person who is replacing the battery for the first time, failure to disappear after replacement may be associated with additional stress, so it is probably worth informing him about it.
  • #9 15332514
    kc2ine
    Rate: 20
    thanks for the information, however, I would be in favor of dissolving my colleague Stan-Mar.
    It makes sense, after all, when the battery dies, the control panel will disconnect it, according to the instructions, anyway. And when I disconnect the battery and it starts to howl, right? the siren is supported.
  • #10 15332597
    bartek0808
    Help: 29
    Rate: 23
    Remember that opening the control panel housing without putting the system into service mode may trigger an alarm.
  • #11 15332786
    sosarek
    Help: 9321
    Rate: 15545
    The control panel should disconnect the discharged battery, but sometimes it will still try to charge it by overloading the charging system, and unfortunately I am not writing about the CA-10 but I had such cases even on some Integrals.
    Z
    Pka, Poznań, 60-850
  • #12 15332903
    kc2ine
    Rate: 20
    I do not have this protection, I have already opened the case to see what battery to buy. Is the service mode required to disconnect the battery and connect a new one? I would not like the alarm to go off,
    thanks
  • #14 15332965
    kc2ine
    Rate: 20
    sosarek wrote:
    Since you do not have sabotage, it is not required.
    thanks, and a question by the way - the suggested answer at the beginning to disconnect the mains and then the battery in my understanding would activate the siren, right?
    Switching to the service mode would do nothing to turn off the siren, because after disconnecting all the power supply, the control panel is turned off.
  • #16 15333316
    kc2ine
    Rate: 20
    Thank you for your help, the battery was replaced without disconnecting the power supply without any problems. The "failure" LED is gone.
The discussion revolves around the procedure for replacing the battery in the Satel Integra 32 control panel. Users emphasize the importance of entering service mode to prevent triggering a tamper alarm when opening the housing. The recommended procedure involves disconnecting the AC power before removing the old battery and connecting the new one, followed by reconnecting the mains power. Some users argue that it is possible to replace the battery without turning off the mains, but this may lead to temporary alerts until the control panel recognizes the new battery. Concerns are raised about the system's behavior during a power cut if the battery is discharged, with varying opinions on whether the siren will activate. Ultimately, one user successfully replaced the battery without disconnecting the power supply, resolving the flashing LED issue.
