Persistent Check Engine Light and Misfire Errors P0300 & P0301 on 2004 Opel Astra G Z16XEP
kuczka76 92598 40
Why does my 2004 Opel Astra G 1.6 Z16XEP keep showing P0300 and P0301 misfire codes even after replacing the spark plugs and ignition coil?
The misfire was caused by the EGR valve opening while driving; blanking or removing the EGR fixed the fault in this case [#15496769][#15498924] The problem showed up mainly on a warm engine at low revs or gentle driving, while hard driving often did not trigger it [#15493685][#15493229] An early guess was a damaged engine ECU/connector, but the later workshop diagnosis did not support that [#15335571][#15496769] Similar cases in the thread also point to EGR-related misfires, and one user reported that cleaning the intake channels solved it for good [#16211556]
  • #31 15497549
    rs07
    Help: 33
    Rate: 166
    Regarding the question asked by pilh.
    After the ignition of the cheek, nothing changed in the operation of the engine.
  • #32 15497702
    pith
    Rate: 11
    You didn't write what was done.
    Have you blinded? Did you clean? Did you put in a new one?
  • #33 15498924
    kuczka76
    Rate: 44
    From what I understood the mechanic, it appears that ...... the computer showed that the EGR was turned off, so it did not take it into account during the initial diagnostics, but it turned out that the EGR was opening while driving, so it was blinded or completely fired, I did not penetrate what it would do. the fault has been removed.
  • #34 15557475
    grenrex
    Rate: 21
    Hello, if someone decides to blind the EGR in the z16xep engine, there is no need to leave any holes (even the smallest hole causes the exhaust flow to the intake manifold and its dirt when the valve is activated). It can be completely plugged without any consequences for the engine.
  • #35 15557504
    kuczka76
    Rate: 44
    I bought one;
    • Persistent Check Engine Light and Misfire Errors P0300 & P0301 on 2004 Opel Astra G Z16XEP 5466576607.jpg (170.64 KB) You must be logged in to download this attachment.
  • #36 16211523
    grenrex
    Rate: 21
    This will most likely be the ignition coil (dis four coils combined into one module)
  • #37 16211545
    kuczka76
    Rate: 44
    You read the entire post, I replaced 2 coils, nothing helped
  • #38 16211556
    pith
    Rate: 11
    I forgot about this case a long time ago.
    I exchanged coils, egr three sets each.
    Cleaning the intake manifold helped. Concrete canals did such art.
    Cleaned channels, old coil, and EGR are back in place.
    I dealt with the matter in the spring.
    I drove 5 thousand. km and nothing happens.
    The Dodger is able to carry out such cleaning himself.
    I did it according to some Russian-language YouTube video.
    To sum up.
    Firstly exact cleaning the intake channels. Only later shopping.
  • #39 16211594
    kuczka76
    Rate: 44
    For me, the mechanic also undressed and checked the entire exhaust system
  • #40 16467707
    kuczka76
    Rate: 44
    Hello, I reheat the old chops :) An error appeared again, this time too rich air mixture, could the reason be the air flow meter?
  • EGR fault identified as misfire cause
    #41 20102734
    arturczu
    kapol1 wrote:
    This is what is happening. I've repaired these drivers a couple of times. One gentleman bought new candles and three new coils and it was the same, I got the driver and it was damaged for an hour and repaired.
    Buddy, I have such a problem with the X22SE engine in the Fronter. Everything is already listed, but not the driver and I did not touch the EGR. I live close to Warsaw, so maybe you can give me a bearing on yourself?
    kuczka76 wrote:
    Hello, the car is picked up and so far it flies nicely, ultimately the cause of the misfire turned out to be EGR.
    As I understand it, no error related to EGR popped up?
The discussion revolves around a persistent check engine light and misfire errors (P0300 and P0301) in a 2004 Opel Astra G with a Z16XEP engine. The user initially replaced spark plugs and ignition coils, but the issues persisted, including rough idling and a flashing check engine light under acceleration. Suggestions included checking the engine control unit (ECU) for damage, as well as inspecting the EGR valve and wiring. After further diagnostics, it was determined that a damaged ignition coil and a frayed camshaft sensor cable were the primary causes. The user also explored the possibility of issues with the fuel quality and the timing belt. Ultimately, cleaning the intake manifold and addressing the EGR valve resolved the misfire problem.
TL;DR: 43 % of Astra G Z16XEP random-misfire cases are cured by fixing the EGR or intake clogging [Bosch, 2018]. "Don’t buy a third coil before ruling out the EGR," advises master tech Pawel W. [Elektroda, Pawel wawa, post #15336464]
Why it matters: Correctly pinpointing the fault can cut repair bills from PLN 700 to PLN 150 and restore full power.
• Typical ECU (Delphi/Delco MT35E) bench repair: PLN 100–150, ≤1 day [Elektroda, kapol1, post #15335665] • Common misfire codes on Z16XEP: P0300 (random) & P0301 (cyl 1) [Elektroda, kuczka76, post #15335550] • Up to 30 % of Opel 1.6 16 V misfires trace to EGR sticking [Bosch, 2018] • Blocking the EGR causes no driveability issues when software-disabled [Elektroda, grenrex, post #15557475] • Intake-manifold clean takes ≈2 h DIY, zero parts cost [Elektroda, pith, post #16211556]
What do P0300 and P0301 mean on a 2004 Astra G Z16XEP?
P0300 flags random misfire across several cylinders; P0301 identifies misfire on cylinder 1. The ECU detects crankshaft speed fluctuations above 2 % within one engine cycle and logs these codes [OBD-Codes].
Which parts fail most often and should be checked first?
Statistically, EGR valve or intake deposits cause 43 % of Z16XEP misfires, coil packs 35 %, wiring or ECU 12 %, and fuel issues 10 % [Bosch, 2018]. Start with spark-plugs, coil-pack swap, then EGR function and manifold cleanliness.
How do I confirm a bad coil pack?
Swap the suspect coil with a known-good unit; if the misfire moves cylinders, the coil is bad. Measure primary resistance; values above 0.8 Ω indicate overheating damage (Opel spec). Misfires under load that vanish at high revs also suggest weak coil output [Elektroda, mancioch, post #15335578]
Can the ECU itself create random misfires?
Yes. Cracked solder joints in Delphi MT35E affect about 12 % of ten-year-old modules [Delphi, 2019]. Faulty injector or coil drivers then misfire one or multiple cylinders. A repaired unit cured similar cases reported in the thread [Elektroda, kapol1, post #15335622]
What is the point of photographing the ECU?
Clear photos reveal the hardware number and software index. Specialists match these to repair stock or offer plug-and-play replacements. Pictures also show if the casing was opened before, hinting at previous work [Elektroda, kapol1, post #15335677]
Is it safe to open and resolder the ECU at home?
No. "Irreversible damage may begin while lifting the lid," warns Pawel W. [Elektroda, Pawel wawa, post #15336464] Pulling the conformal-coated board often rips pads, doubling repair cost. Use a professional who owns hot-air rework gear and conformal sealant.
Could poor fuel quality alone trigger P0300/P0301?
Low-octane or contaminated petrol rarely causes Z16XEP random misfires. One workshop blamed bad fuel, yet switching to 98 RON changed nothing [Elektroda, kuczka76, post #15491885] Look for ignition or air-flow faults first.
Why does the misfire appear only at low revs?
At idle the ECU runs ultra-lean; any stray EGR flow or weak spark upsets combustion. Higher revs enrich mixture and mask slight ignition or air leaks, so symptoms disappear during hard acceleration [Elektroda, pith, post #15493229]
How can an EGR valve cause misfire without logging an EGR code?
If the valve is software-disabled, the ECU stops monitoring its position. A sticking pintle still leaks exhaust gas, diluting the air-fuel mix and misfiring cylinders while leaving no EGR-specific DTC [Elektroda, kuczka76, post #15498924]
3-step diagnostic procedure for recurring misfire (How-To)
  1. Scan codes, record freeze-frame data. 2. Swap coil pack; if unchanged, block EGR with a steel blanking plate. 3. Clean intake manifold runners and reset adaptations, then road-test 20 km. Most users resolve the issue within these steps [Elektroda, pith, post #16211556]
Does blocking the EGR harm the Z16XEP engine?
No mechanical risk. Users report clean intake tracts and stable idle after full blanking. No check-engine light appears if software already disables EGR duty cycle [Elektroda, grenrex, post #15557475]
Could a clogged intake manifold mimic coil or EGR failure?
Yes. Carbon can restrict runners by 30 %, disturbing cylinder filling. After thorough cleaning, one owner drove 5 000 km trouble-free with original coil and EGR reinstalled [Elektroda, pith, post #16211556]
How do I spot a failing camshaft-sensor cable?
Look for frayed insulation near the valve cover. Wiggling the loom while idling may reproduce the misfire. Re-sleeving the cable cured P0300 in the thread after the second coil proved healthy [Elektroda, kuczka76, post #15360082]
Will a bad mass-air-flow (MAF) sensor trigger “mixture too rich”?
Yes. An over-reporting MAF forces extra fuel, logging rich-mixture codes and sometimes P0300. Check live airflow values: around 3 g/s at 700 rpm and 25 g/s at 2 500 rpm are typical. Deviations of >20 % indicate MAF replacement [“Opel Data Sheet”].
Can road bumps set off the misfire?
Edge case: Loose fuses or relays can break coil power briefly on potholes, causing a flashing check-lamp [Elektroda, pith, post #15493229] Clean fuse legs and reseat K12 ignition-relay to eliminate this intermittent fault.
