Passat B6 1.9tdi Yellow Crossed-Out P Light: Control Module EEPROM Memory Issue & Handbrake
janas954 120222 10
Why is the yellow crossed-out P warning light on in a Passat B6 with an electric handbrake, even though the handbrake motors work and there seems to be no major fault?
The crossed-out yellow P light is most likely related to the rear brakes—especially worn pads, discs, or calipers—so check those before suspecting the control module. One reply asked specifically about the condition of the rear pads [#15357076], and the original poster later noted they were about half worn [#15357198] Another user reported the same warning with weak rear pads while the handbrake still worked normally and no other lights were on [#17043440] Other replies suggested that worn pads or a need to replace the pads and possibly discs can trigger the warning, and that hard-to-move pistons may also be involved [#17043969][#17113516] Based on the thread, the module is not the first thing to replace; inspect and service the rear brake hardware first [#15357076][#17043969]
  • #1 15356751
    janas954
    Rate: 28
    As in the topic, I have a problem with the yellow P light crossed out. The handbrake works right and left, you can hear how the motors are working and the handbrake has no biggest problem. The error that pops up is from the Control Module - damaged EPPROM memory. On the forum they write that the button from the manual blinks and there is a signal for me, only this indicator is on. My question should I mention this module or look for another reason? I will add that it has been shining for 2 weeks and as I said, there is no major problem
    Thank you in advance for all the hints and advice
  • #2 15357076
    szymon198312
    Level 30  
    Help: 126
    Rate: 890
    And what is the condition of the pads on the back?
  • #3 15357198
    janas954
    Rate: 28
    About half are bricks
  • #4 16361185
    sofix2
    Rate: 82
    Hello, I have the same problem, did the author of the thread handle it? Please let me know ...
  • #5 17043440
    migolc
    Rate: 195
    I have the same situation, the pads on the back are rather weak, is it "crossed P" shining? Manual and everything else works fine, nothing else is lit or blinking.
  • #6 17043870
    sofix2
    Rate: 82
    Unfortunately, I still drive with it. Strange errors pop up every time others are eprom are brake motors, left and right. The light popped up suddenly when I fired at -30 last year and by throwing the last breath on the tape, the aku fired, but it was a souvenir :( in the form of a lamp on the counter.
  • #7 17043969
    migolc
    Rate: 195
    For me, "unfortunately" no other errors, etc. I bought the car with broken motors from the manual, cleaned, greased, everything works beautifully, only this one icon is left. Somewhere I found info that if the pistons are hard to move, this icon will be shining. I'll try to unplug Aku for the night yet.
  • #8 17113478
    diabel325
    Rate: 87
    hello, maybe someone has already solved this problem? In my case, everything is flashing, the electric manual brake is no problem, but the question is why the yellow light is on the board, P crossed out?
  • #9 17113516
    krismon3
    Help: 7
    Rate: 59
    My car is vw golf plus and the same light is on. Hope that's enough
    replace the pads plus possibly the replacement discs.
  • #10 19508223
    Czamilek
    Rate: 21
    And how, gentlemen, is it enough to change the pads and discs? Because I have the same problem and the computer does not show any error
  • #11 21123042
    diagautob27
    Rate: 18
    the same problem
The discussion revolves around a persistent issue with the yellow "P" light crossed out on a Passat B6 1.9 TDI, indicating a potential problem with the control module's EEPROM memory. Users report that the handbrake functions correctly, and there are no significant operational issues. Several participants suggest checking the condition of the brake pads, as worn pads may trigger the warning light. Others share similar experiences with the same warning light appearing without any accompanying error codes from the computer. Some users have attempted to reset the system by disconnecting the battery, while others consider replacing brake components to resolve the issue.
