[Solved] VW Passat B6 2.0 CBAB 2008: Handling Error 16347 - EEPROM in Parktronik Module
kszychu 24033 4
  • #1 16444647
    kszychu
    Rate: 55
    Auto passat b6 cbab 2008. Parking sensors front, rear.
    I read that parking modules are flying from a flat battery.
    Error:
    16347 - Control Module - EEPROM Error
    014 - Defective.
    Has anyone done this, does the module need to be replaced or is it possible to re-encode?
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5049
    The error says about the corruption of eeprom content.
    If it doesn't affect your work, leave it.
    You can try to fix it by reading the memory contents from a good module and uploading it to the damaged one.
    Changing the encoding will not help.
  • #3 16516550
    kszychu
    Rate: 55
    Module replaced. PDC works as it should.
  • #4 16518119
    DoctorCar
    Level 19  
    Help: 37
    Rate: 121
    I've already made such patents. Reprogramming Motorola helps.
    Twice I had it so that the error was still present, it could not be cleared, but it went into a state - sporadic and parktronik works
    Regards
  • #5 17467386
    kszychu
    Rate: 55
