Audio Transmission Issue with HDMI Cable: Updated 2008 Audio Drivers Not Working
Jamus1 14742 6
  • #1 15357528
    Jamus1
    Rate: 53
    Hi
    The problem occurs when I connect via HDMI cable, the picture transmits to my TV but the sound does not...
    The sound does not come out of the computer at all.
    From the device manager I updated the audio drivers after which I got a message that the driver is current but its date is from 2008.
    What could be the problem ?
  • #2 15357553
    ValValiantThor
    Help: 160
    Rate: 150
    Specify your graphics card hardware and model
  • #3 15357662
    cycek011
    I would try to update the driver manually (download it from the manufacturer's website, whether the card or the Laptop), and not play with Windows hocus-pocus.
  • #4 15357804
    winmap
    Help: 361
    Rate: 754
    Give as above specifications
    Possible that it is just a matter of card settings.
  • #5 15358433
    mac_23
    Rate: 12
    I had a similar problem. You had to check in the properties of the graphics card to send sound.
  • #6 15359824
    adriaanos88k
    Level 19  
    Rate: 60
    On the plugged-in cable, give a screen shot of the Playback tab under "Sound". Where you have the volume in the tray, right click and select "Playback device".
  • #7 15360280
    ValValiantThor
    Help: 160
    Rate: 150
    The author doesn't seem to have time to take care of the problem. And this is no "rocket science". One has to wait for the author's move.
The user is experiencing an audio transmission issue when connecting their computer to a TV via HDMI cable, where video is displayed but no sound is produced. Despite updating the audio drivers, the user notes that the driver version is from 2008. Responses suggest checking the graphics card specifications, manually updating drivers from the manufacturer's website, and ensuring that the graphics card settings are configured to transmit audio. Additionally, users recommend examining the Playback tab in the Sound settings to verify audio output devices.
