SM3257ENLT USB Stick Data Recovery: Interrupted Copying, Shorted Legs, ChipEasy, VID=090C PID=3000
Vytautas_YT 32481 6
  • Next steps for SM3257ENLT flash recovery
    #1 16189640
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    I have a problem with the USB stick that was removed from the port while copying data. Now in normal mode the pendrive does not rise. After shorting the four legs on the memory dice (I found this way somewhere on the electrode), the memory appears in the system in gray and of course is unavailable both for opening and for formatting. However, it appears to me in the ChipEasy program, thanks to which you can read some information about it, it looks like this:
    ______________________________________________
    Logical drive: G: \ Capacity: 0.0G
    Device ID: VID = 090C PID = 3000
    Device SN:
    Device version: 1000
    Device vendor:
    Device model: USB MEMORY BAR
    Protocol: USB2.0
    Max power: 100mA
    Partition type: Device active:
    Aligned state: Misaligned
    Controller: SMI
    Controller model: SM3257ENLT
    Firmware: ISP NONE
    Tools: http://www.upan.cc/tools/mass/SMI/
    OS Version: Windows 7 Professional Service Pack 1
    Update Status: The current version is the latest version!
    I downloaded the program for SM3257ENLT controllers. After running this software, the pendrive is detected by it under the item Port 1. Question to the more experienced in this topic. What's next? What do I have to do next to resurrect (try) this memory?
  • #2 16190036
    pidar
    Help: 1569
    Rate: 3590
    bzyniu28 wrote:
    I downloaded the program for SM3257ENLT controllers. After starting this software, the pendrive is detected by it under the item Port 1.
    Add a dump from this program.
    What memory is used there (how many "GB" has a flash drive?) -> read subtitles.
    ChipGenius will show something more :?:
    http://www.mydigit.cn/mytool/ChipGenius.rar
  • #3 16191504
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Oto screen z programu o którym pisałem:
    Pendrive ma 8GB, na pamięci pisze:
    X424140401
    SDTNRGAMA-008G
    DP0622184
    A ChipGenius podaje takie informacje:
    Description: [G:]Urządzenie pamięci masowej USB(USB MEMORY BAR)
    Device Type: Mass Storage Device
    Protocal Version: USB 2.00
    Current Speed: High Speed
    Max Current: 100mA
    USB Device ID: VID = 090C PID = 3000
    Device Vendor: Silicon Motion,Inc.
    Device Name: SM3255AA MEMORY BAR
    Device Revision: 0100
    Product Model: USB MEMORY BAR
    Product Revision: 1000
    Controller Vendor: SMI
    Controller Part-Number: SM3257ENLT - ISP NONE
    Flash ID code: 45DE9493 - SanDisk SDTNRGAMA-008G - 1CE/Single Channel [MLC-16K] -> Total Capacity = 8GB
    Tools on web: http://dl.mydigit.net/special/up/smi.html
  • #5 16191869
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Dude beautiful Thanks.
    The program you sent me was found in the same way as the one I used at the beginning. With the difference that in the first one after clicking the start was Fail and the one performed Bad removal, formatting and Pen Alive.
    Thanks again ;)
  • #7 16192332
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Info po naprawie z GetFlashInfo:
    Volume: G:
    Controller: Silicon Motion SM3257 ENBA
    Possible Memory Chip(s):
    SanDisk SDTNQFAMA-008G
    SanDisk SDZNQFAMA-008G
    SanDisk SDTNQGAMA-008G
    SanDisk SDYNQFAMA-008G
    SanDisk SDYNQGAMA-008G
    Memory Type: MLC
    Flash ID: 45DE9493 7650
    Flash CE: 1
    Chip F/W: ISP 140630-AA-
    MP: N0725V1
    MPTOOL Ver.: 2.05.36
    PTEST Date: 2014-05-05
    VID: 090C
    PID: 1000
    Manufacturer: SMI Corporation
    Product: USB DISK
    Query Vendor ID: SMI
    Query Product ID: USB DISK
    Query Product Revision: 1100
    Physical Disk Capacity: 8095006720 Bytes
    Windows Disk Capacity: 8078200832 Bytes
    Internal Tags: QT2R-T99J
    File System: FAT32
    Relative Offset: 28 KB
    USB Version: 2.00
    Declared Power: 500 mA
    ContMeas ID: 30CB-01-FF
    Microsoft Windows 7 SP1 x64 Build 7601
    http://www.antspec.com/usbflashinfo/
    Program Version: 8.7.0.597
The discussion revolves around a USB stick identified as USB MEMORY BAR, which became unresponsive after an interrupted data transfer. The user attempted to recover the device by shorting the memory chip's legs, which allowed the device to be recognized in the system but rendered it inaccessible for formatting. The device details include VID=090C, PID=3000, and it utilizes a Silicon Motion controller model SM3257ENLT. Various recovery tools and software, such as ChipEasy and ChipGenius, were suggested to gather more information and potentially recover the data. After using recovery tools, the user reported partial success in accessing the device, with details about the memory chip and its specifications being shared. The final recovery status indicated a capacity of approximately 8GB and a FAT32 file system.
