Casting Aluminum Plate Surface at Home: Even Spread on Uneven Mold & Properties After Melting
franz87 92466 18
Can I melt aluminum at home and cast only a thin, even layer onto an uneven surface, and will the remelted aluminum keep its original properties?
No—you cannot reliably melt aluminum at home and pour a thin, even layer onto an uneven surface; aluminum must be heated above its melting point of about 660°C, it oxidizes easily, and thin-surface copying is normally done by other methods, not by pouring molten aluminum [#5871054] Cast parts with 1–1.5 mm walls are usually die cast, because sand molds do not allow such thin walls, and making that kind of mold is beyond normal home methods [#5874125] The mechanical properties after remelting are not the same by default; they depend on the alloy, and good castability often means using aluminum alloys such as ZNAL or silumin instead of pure aluminum [#5871054] For a motorcycle cover, the thread suggests non-casting alternatives such as making the shape in plaster, reinforcing it with glass cloth and epoxy resin, then sanding and painting it [#5871596] Another practical option mentioned is having the part made by a casting plant or fabricating it from sheet metal and TIG welding it [#5874125][#5878856]
  • #1 5870589
    franz87
    Rate: 82
    Hello everyone. I need to make a cast of a certain aluminum plate. I admit that I have never done it. Of course I read similar topics on the Internet. I found 2 people who reportedly melted alu at home (with a burner) But I have a few questions that I found the answer. that aluminum melts at a temperature close to 660'C, as I do not have a suitable furnace, I would try to melt the alu in a cast iron crucible under a gas or electricity burner. heat such a metal so that at 180 degrees the alu finally melts. I hope some of you have done something similar before. My casting is a bit different. My point is to only cast the surface of the casting - not the whole thing! Will the molten aluminum decompose evenly on the "not flat" surface, or is it rather impossible? The last question - does this aluminum have the same properties as before melting?
    Greetings
    Please use the "Spelling" button before posting. Spelling errors will not be tolerated, regulation point 15.
    Do not delete moderation entries!
    Please correct it.
    [_P_]
  • #2 5871054
    Rzuuf
    Help: 1355
    Rate: 1700
    Hello!
    First thing: in order to melt anything you MUST heat it above the melting point. ATTENTION! Aluminum must be melted in a protective atmosphere because it oxidizes easily!
    Second case: obtaining a thin layer of molten and then solidified metal on an uneven surface is possible using the spray metallization method, but for this purpose other metals are used, not aluminum.
    Third case: the mechanical properties of castings depend on the composition of the cast metal, usually good mechanical properties conflict with castability, therefore, for aluminum castings, alloys of the ZNAL (pressure cast) or SILUMIN type are used. You can read about the properties of these alloys in Wikipedia.
    Copying the surface of metal objects is possible in a slightly different process:
    - you imprint the copied object in plaster;
    - after removing the item, you pour Wood's alloy on it (you can buy it at the Institute of Non-Ferrous Metals). After removing the "pattern", you hang the casting for electroplating and you get a thin shell of electroplated copper;
    - now you melt Wood's alloy in hot water, and fill the empty "shell" with, for example, epoxy resin or other liquid, polymerizing material;
    - after the polymer has hardened, you can now paint the object with the car paint "silver metallic".
    To strengthen such epoxy castings, you can also use "reinforcement" with glass fiber or steel inserts.
  • #3 5871534
    franz87
    Rate: 82
    Thanks for the comprehensive answer. Maybe I will describe what the problem is. So I have a certain form. Rounded. There are edges in some places. The surface is quite large. (Photo attached) I can see that the alu melting at home is not that easy. At the beginning I wanted to punch this form out of 1mm-1.5mm sheet metal, but I quickly came to the conclusion that it was bordering on a miracle. Then there was an idea for a casting. It is also not easy to make. Now I have a new idea. I don't know if it is, but I think there is something like plasticity between the solid and the liquid. Tell me what your view on this matter is. Maybe it's a strange case, but I do. I take it quite seriously. It's a cover from a motorbike. They've already shot me 3 and I'm thinking what to do here ...
    :arrow: https://www.elektroda.pl/rtvforum/viewtopic.php?p=3080068#3080068
    In accordance with point 15 of the regulations, please correct the post.
    Use the button Casting Aluminum Plate Surface at Home: Even Spread on Uneven Mold & Properties After Melting before posting.
    Please correct!
    I remind you of the moderator's recommendation!
    • Casting Aluminum Plate Surface at Home: Even Spread on Uneven Mold & Properties After Melting kingway-hooligan-50_1278.jpg (56.56 KB) You must be logged in to download this attachment.
  • #4 5871596
    Rzuuf
    Help: 1355
    Rate: 1700
    Impress the mold in the plaster, impregnate the plaster with paraffin, and then form this cover with a glass cloth and liquid epoxy resin.
    When it hardens, you need to sand it with sandpaper, then fill it and paint it with varnish.
    Papping on the plaster is an artistic job + burner, and the result does not have to be so beautiful.
    The atom won't touch it!
  • #5 5873783
    franz87
    Rate: 82
    I hear they did just that.
    But it would be original metal :)
    Maybe make some form and put it into some plant where aluminum is being cast?
  • #6 5873877
    Sobota
    Help: 54
    Rate: 72
    It would be original metal :)
    Can he make a form somehow and put it into some plant where aluminum is cast?
    In factories, they make molds themselves, but if you do the mold right, they probably won't get angry ;-)
  • #7 5874058
    franz87
    Rate: 82
    Do you know plants that specialize in castings?
    It would be difficult to make such a form yourself, but for sure much cheaper and xD satisfaction
    The thickness of this casing is 1-1.5mm, so you would have to make one casting and another one 1-1.5mm thicker, pour the molten metal in between.
    If I were able to make such a casting, I would most likely give it to a plant for further processing
  • #8 5874119
    Faces
    Help: 145
    Rate: 157
    Yes, I know.
    Technocast from Kędzierzyn-Koźle.
  • #9 5874125
    Rzuuf
    Help: 1355
    Rate: 1700
    Castings with a wall thickness of 1 - 1.5 mm are made as die castings in a die, because sand casting molds do not allow for such thin walls with this size of the object. The technology of such a mold is completely beyond the reach of "home methods", unless you have a numerically controlled milling machine and workshop experience in a tool shop.
    You might as well try to make a mold (die) for stamping on the press, then the wall thickness of 1mm is not a problem, because it is pressed from such a sheet.
    I used to read about the possibility of forming objects without a die, with a die only, using explosives.
  • #10 5875091
    Sobota
    Help: 54
    Rate: 72
    With the use of explosives? You have to do them first :-D Could you elaborate on it?
  • #11 5875283
    Rzuuf
    Help: 1355
    Rate: 1700
    These were research topics carried out some 40 years ago by the Military University of Technology. You can search their library.
  • #12 5875361
    Faces
    Help: 145
    Rate: 157
    Probably about shaped charges.
    Primary shaped charges are used to pierce thick armor. "Modified" are used for cutting steel (eg when dismantling bridges etc.).
    With proper construction, they can probably be used to form objects, but that is a completely different topic.
  • #13 5875412
    Rzuuf
    Help: 1355
    Rate: 1700
    These were not shaped charges.
    The charge exploded in a vessel (barrel) of water and there was an object at the bottom to be molded. Formation was due to the shock wave in the water. This method was also used to achieve a composite of, for example, two sheets of materials that cannot be welded or soldered together, such as copper and aluminum.
  • #14 5875510
    slu_1982
    Help: 47
    Rate: 339
    Hmm. Now it is done with petn water only transmitting impact. Kumule cuts and holes. Now there are pools and molds for this. It wasn't only used experimentally, it is still used today. And about MW, look for google and I do not wish you good luck, because they will not be useful because I assume that no one will synthesize MW here :D Regards In general, the topic of pressing with MW is quite interesting, artificial diamonds with MW are made, appropriate chambers where the pressure does not escape, and high temperature.
  • #15 5876235
    submariner
    Level 32  
    Help: 51
    Rate: 268
    artificial diamonds explosive method? :) what sizes are you talking about? - diamond dust?
    you can bond metals with explosives dry, but it is unprofitable - for joining a few-centimeter plates, 2-3 cm, you need a hexogen layer with a thickness of 30-40 mm depending on the type of metals - it is very loud and very expensive.
    The liquid forming method is used to stamp thick sheets and I've never heard of joining unless it's impossible.
    Alumina can be sprayed, in principle, even on paper, of course in a protective atmosphere, a few years ago in the Warsaw IMP, such services were performed and they were quite cheap.
  • #16 5877008
    Chris_W
    Help: 386
    Rate: 1051
    Explosive forming also uses ammonites - and this can be done for pennies. But treating broken members costs a lot ...
  • #17 5877211
    slu_1982
    Help: 47
    Rate: 339
    Hmm poultry? for the war industry, 1 kg of sea trout is PLN 2 .. no PLN 1.30 Buying in dark spheres about PLN 20 / kg but it is worth the life of people who choose it from misfires :| And ammonites are pennies and the availability is even easier, but ammonites are not that cool ...
  • #18 5878856
    franz87
    Rate: 82
    Such a cover is when you want to make aluminum, it is better to weld the pieces where and what you can pat, sand the butt and even you can polish it
    A colleague at work made a fuel tank for his Suzuki he polished and it looks like from the factory you can not see anywhere that it was connected urzywal all a piece of pipes, hammered sheet, etc.
    welding performed by the tig method.
    Well, that would be a good idea, I understand my friend made a form of concrete or plaster and welded the pieces? Strange that it had such an effect!
    PS: Do you know something like that? How is the soldering paste - so that the solder "catches" faster, is it something like that for alu?
  • #19 5880255
    _PREDATOR_
    Help: 1864
    Rate: 2315
    Failure to follow the moderator's instructions, in accordance with the forum regulations, qualifies the topic for closure.
    ELMAX
    Małe Przedmieście 20/4, Olesno, 46-300 | Tel.: 535 XXX XXX (Show) | Company Website: http://ftp.interka.pl/~elmax/about.php
The discussion revolves around the challenges of melting aluminum at home for casting purposes. The main concern is achieving the necessary temperature of approximately 660°C using a gas or electric burner, as well as ensuring a protective atmosphere to prevent oxidation. Various methods for creating molds and casting aluminum are explored, including the use of plaster molds, epoxy resin, and the possibility of outsourcing to specialized casting plants. The participants also discuss the mechanical properties of aluminum castings, the feasibility of achieving thin wall thicknesses (1-1.5mm), and alternative methods such as explosive forming. The conversation highlights the complexity of home aluminum casting and the potential for professional assistance in achieving desired results.
