Sony PS4 - does not enter safe mode, cannot install the system, error
nicekt 16182 15
Why won't my PS4 enter safe mode or accept DualShock pairing, and how can I fix the SU-41283-8 system installation error?
A faulty BT/Wi‑Fi module on the PS4 motherboard can prevent DualShock pairing and cause the install problem, and replacing that module fixed the console in this thread [#16847676][#16924473][#16971136] If the pad works only over USB but not wirelessly, the module or its firmware section is the likely cause; one suggested check was to plug in a USB keyboard to verify the USB ports, then read the flash chip with a programmer if needed [#16847676][#16851972] The board uses one of two BIOS chips, MX25L25635FMI or MX25L25635FZ2I, and the dump can be unpacked with PS4AC1D Tools [#16851972] The final advice was that the firmware was OK and the BT/Wi‑Fi module itself had to be replaced [#16924473]
  • Safe mode failure and SU-41283-8 install error
    #1 16846347
    nicekt
    I have a problem with the PS4 model CUH-1216B. First, the blue screen crashed - connect the dualshock with a USB cable and press the PS button. After connecting it rains with a cable it did not respond to the PS button. I suspected that the system or disk was down. I checked the disk and it's ok. It doesn't go into this console to enter safe mode. When I hold the power button the console after the second beep just turns off instead of entering this mode. I had a second disk so I formatted it on FAT32 and put it in the console. I downloaded the latest update from the site and uploaded it to a USB stick. The console after the installation installed the system but there was still the same problem - the blue screen and plug it in and press PS, which the console did not respond to. So I decided to try installing the system again. Safe mode still did not work, so again the format to force the system installation. Well, now it looks like that when you try to install SU-41283-8 error crashes. I have not found any description of this error or the inability to enter safe mode.
  • #2 16847323
    Spox_2
    Help: 25
    Rate: 84
    What software version are you uploading?
    Full update or just update?
  • #3 16847502
    nicekt
    Latest from sony- 5.01. File downloaded from the reinstall system section, so I guess it's full. The file has over 900MB. Earlier, as there was a 4.7 system and I inserted another disk, it installed the system from this file, but then there was the blue screen. Now it is no longer installed on any disk because of an error.
  • #4 16847529
    Spox_2
    Help: 25
    Rate: 84
    Show a picture with a blue screen because I admit I never met it on PS4 :)
  • #5 16847563
    nicekt
    Something like the picture. I did not respond to pressing the PS. Now I can't install the system on any of the discs because this error pops up SU-41283-8. Sony PS4 - does not enter safe mode, cannot install the system, error
  • #6 16847676
    Spox_2
    Help: 25
    Rate: 84
    aaaaa,
    That is the start screen :)
    In this case, I connect a usb keyboard to check if the USB ports are working.
    If so, the screen will display a message about the connected accessory.
    If the DualShock 4 pad does not connect to the console, there are 2 reasons:
    1. Damaged BT / Wifi module on the PS4 console mainboard (BGA component). We often exchange them. They fall like flies.
    2. Injured firmware and bt / wifi module section.
    In both cases, you need to disassemble the consoles and take action.
    It's always better to start with bone reading and firmware analysis
    Do you have BGA equipment / bone programmer?
  • #7 16847878
    nicekt
    The pad connects because as a formatted disk I put the pad I can confirm the installation of the system, press the PS etc. Only when it starts to install, this error crashes and now there is nothing to install at all. Unfortunately I don't have a programmer. Yes, I have a soldering station.
  • #8 16851916
    nicekt
    Which bone should be read and analyzed? Alternatively, where can you get the batch from this bone to program it properly?
  • #9 16851972
    Spox_2
    Help: 25
    Rate: 84
    With Pad it's like this:
    In recovery it always works as it is connected on a USB cable.
    As the BT / WiFi module (or its firmware) is whacked, the pad does not connect to the console wirelessly. It cannot be paired.
    Read bones before the universal programmer that supports them.
    I have a Vellon VP-990 in the company and even copes with it.
    There are 2 types of bios in PS4.
    MX25L25635FMI
    MX25L25635FZ2I
    You need to read and unpack using the PS4AC1D Tools application.
  • #10 16860965
    nicekt
    Okay, I read the bone, made an extract and I have the file C0020001 only mine has 432 158 kb. I can't find a replacement file with this size anywhere. Can I exchange with any available on the internet? Alternatively, can I ask you to analyze it if there is any error in the file or to replace the wifi / bt chip?
    • C0020001.bin (422.03 KB) You must be logged in to download this attachment.
    Spox_2
    Help: 25
    Rate: 84
    Firmware is ok.
    You must replace the BT / Wifi module. Don't move without it.
    I take the systems (BT modules for SAC-001) from the store www.konsolowo.pl
    Ask there and you'll know everything.
  • #12 16924827
    nicekt
    I ordered from the Chinese. I couldn't find one anywhere.
    Spox_2
    Help: 25
    Rate: 84
    One piece or maybe more?
    What is the cost
  • #15 16925370
    nicekt
    Unfortunately, only art. $ 8 with shipping, so thirty-several zlotys. As I was looking for it wasn't on the allegro. It will be cheap but you have to wait.
  • #16 16971136
    nicekt
    The deal has come today. Soldered. The console flashes like new. Thanks a lot.
The discussion revolves around a Sony PS4 model CUH-1216B that fails to enter safe mode and displays a blue screen error when attempting to install the system. The user confirmed that the hard drive is functional and attempted to install the latest firmware (version 5.01) from a USB stick, but encountered error SU-41283-8 during installation. Responses suggest potential issues with the Bluetooth/Wi-Fi module, which may be damaged, preventing the DualShock 4 controller from connecting wirelessly. Recommendations include checking USB ports with a keyboard, reading the console's firmware, and replacing the faulty module. The user successfully sourced a replacement module and reported that the console was restored to working condition after soldering the new part.
TL;DR: If a PS4 (CUH‑1216B) won’t enter Safe Mode and throws SU‑41283‑8, the expert says there are 2 reasons—“They fall like flies.” Replace or reflash the BT/Wi‑Fi module, then reinstall via USB. [Elektroda, Spox_2, post #16847676]
Why it matters: This FAQ helps DIY repairers fix Safe Mode and reinstall failures tied to PS4 Bluetooth/Wi‑Fi hardware/firmware faults.
What does PS4 error SU-41283-8 mean during system install?
In this case it appeared alongside a Bluetooth/Wi‑Fi module fault. The console reached the “Connect DualShock 4” screen, then installs failed with SU‑41283‑8 until the BT/Wi‑Fi module was addressed. The expert advised hardware replacement over firmware swap. [Elektroda, Spox_2, post #16924473]
Why won’t my PS4 enter Safe Mode and instead powers off after the second beep?
That symptom matched a system stuck at the blue “Connect DUALSHOCK 4” screen with underlying module trouble. The user reported shutdown after the second beep rather than Safe Mode entry. Hardware or firmware issues in the BT/Wi‑Fi section can block recovery. [Elektroda, nicekt, post #16846347]
Does a DualShock 4 always work over USB in recovery?
Yes. The expert clarified that in recovery, a DS4 connected by USB works even if wireless pairing fails. This helps you proceed with a reinstall or with diagnostics when the BT/Wi‑Fi radio is defective. [Elektroda, Spox_2, post #16851972]
How can I quickly test if my PS4 USB ports respond on the blue screen?
Plug in a standard USB keyboard. If the ports are fine, the screen shows a message about the connected accessory. If nothing appears, investigate power or port faults before software steps. This isolates input issues from radio problems. [Elektroda, Spox_2, post #16847676]
What are the common causes when a DualShock 4 won’t pair wirelessly?
The expert lists two causes: a damaged BT/Wi‑Fi module on the mainboard, or corrupted firmware for that section. Quote: “They fall like flies.” Replace the module or reflash after reading the BIOS. [Elektroda, Spox_2, post #16847676]
Which BIOS chips should I read if I suspect firmware corruption?
PS4 boards commonly use MX25L25635FMI or MX25L25635FZ2I. Read the chip with a supported programmer and unpack using PS4AC1D Tools for analysis. This step checks integrity before hardware swaps. [Elektroda, Spox_2, post #16851972]
What programmer and software were confirmed to work for PS4 BIOS dumps?
A Vellon VP‑990 handled the readout, and PS4AC1D Tools unpacked the data for inspection. This pairing enabled verifying the firmware region tied to BT/Wi‑Fi behavior. [Elektroda, Spox_2, post #16851972]
My dump produced a C0020001 file of about 432,158 KB—can I replace it with any file from the internet?
No. The expert reviewed the firmware and said it was OK; the fix was to replace the BT/Wi‑Fi module. Swapping random images introduces new faults and won’t solve radio hardware failure. [Elektroda, Spox_2, post #16924473]
What BT/Wi‑Fi module variant should I look for on a PS4 with this fault?
For boards using that radio, the expert referenced modules marked for SAC‑001. Matching the correct module variant avoids pairing and boot issues after replacement. [Elektroda, Spox_2, post #16924473]
How do I replace the PS4 BT/Wi‑Fi module? (3-step quick guide)
  1. Disassemble to the mainboard and locate the SAC‑001 BT/Wi‑Fi module.
  2. Desolder the faulty module and solder in a matching replacement.
  3. Reassemble and reinstall the system from the full PUP via USB. “Don’t move without it,” advised the expert. [Elektroda, Spox_2, post #16924473]
Where can I buy the replacement BT/Wi‑Fi module?
The expert sourced BT modules for SAC‑001 from a console parts shop and suggested contacting them for stock details. Any reputable console-parts vendor with SAC‑001 should work. [Elektroda, Spox_2, post #16924473]
How much does a replacement BT/Wi‑Fi module cost?
One user purchased a module from China for about $8 including shipping. Expect lower prices but longer delivery times compared with local shops. This cost point guides budget decisions. [Elektroda, nicekt, post #16925370]
Will replacing the BT/Wi‑Fi module actually fix install loops and Safe Mode issues?
Yes. After soldering the new module, the user reported the console worked “like new,” confirming successful boots and installs. This field result validates the diagnostic path. [Elektroda, nicekt, post #16971136]
What is the PS4 “Reinstall System Software” file and when should I use it?
It’s the full PUP (about 900 MB) used when swapping drives or rebuilding the OS from scratch. The user previously installed 4.70 to a new disk using the full file. Use it after hardware fixes. [Elektroda, nicekt, post #16847502]
Edge case: my PS4 accepts the DS4 over USB but still fails install—what next?
That exact scenario occurred here. USB control worked, yet installs failed with SU‑41283‑8 until the BT/Wi‑Fi module was replaced. Proceed to module diagnostics or swap. [Elektroda, nicekt, post #16847878]
