[Solved] VW TDI: Oil Leakage from Intercooler, Hose Leaks, Power Drop & Black Smoke in Golf 3 & B5 TDI
janusz tdi 79791 24
Why does a VW TDI get oil in the intercooler and hoses, with loss of power and black smoke, and how should it be fixed?
Oil in the intercooler/hoses usually means the real fault is a leaking turbo or crankcase ventilation problem, not the intercooler itself, so patching the cooler alone is only a temporary fix. If you want to check the intercooler for a crack, remove it, clean it, plug both ends, apply low compressor pressure, and submerge it in water to find the leak; one user repaired it with Araldite F300 plus hardener [#15520293] If oil keeps coming back, inspect the turbo and the crankcase ventilation/valve cover breather, because that is where the oil in the intake system usually comes from [#15555949][#15572794] In the thread, replacing the entire valve cover with the breather solved the problem completely [#17229118]
  • #1 15517252
    janusz tdi
    Help: 6
    Rate: 75
    If you have an oil leak from the intercooler or from the hoses, it is leaking - holes. The symptom may be a drop in power and black smoke from the exhaust. Often experts say that it is a turbine. I had it in Golf 3 and, of course, in the b5 b5 tdi.
  • #2 15517800
    Jacek79
    Level 37  
    Help: 233
    Rate: 1132
    and what did you do?
  • #3 15520293
    janusz tdi
    Help: 6
    Rate: 75
    I removed the intercooler, cleaned it with gasoline, blowing it under pressure with an oil gun, inside and out. I blocked it with two fi 50 (rubber) plugs from the sewage system, in one of them I made a hole and checked by immersing in water where there is a leak. Of course with low compressor pressure. I glued it with aluminum glue. ARALDITE F 300 + HARDENER. And so I saved the intercooler and fixed the fault. I had little power, black smoke from the pipe and I was constantly adding oil that was sucking the intercooler. You also have to check the intercooler wires to be sure.
  • #4 15529322
    darfur5
    Help: 267
    Rate: 1715
    Interesting! We are learning all the time :| but I don't think I was in this lesson.
  • #5 15549672
  • #6 15553409
    Tommy82
    Help: 455
    Rate: 1074
    A buddy once bought at DE Yariske.
    He checked the oil level on the spot, he added the minimum before the tour. It flew to PL. He did not check the oil anymore, as he was going to the inspection, the heads were smashed. IC full of oil in the bowl almost the minimum. so she must have had a drink for a while.
    At another friend's, the men drill a hole in the IC and put the screw in. Every now and then, they unscrew and drain the condensate, but when the oil appears, it is the turbine's fault. Nobody is taking a fart from the turbo regiment, a polished 13 mesh eyelet, which is attached to the turbo on the t-shirt (because there is such a nasty screw) and wio.
    Anyway, once when I was at my friend's for coffee, I got a course by truck for a change to St. Anne's Mountain and turbo replacement with a mop because it was impossible to go empty.
    The adventure was made by my uncle by bus in Uk when his turbo was torn apart by the authorized service, he replaced the entire intake, including the IC, the procedure does not include cleaning the IC. Costs: "don't ask, I don't want to be nervous"
  • #7 15555949
    darfur5
    Help: 267
    Rate: 1715
    Of course, patching the cooler doesn't do the trick, because on what occasion the oil collects in it, or the turbine or the crankcase ventilation is to blame.
  • #8 15572707
    janusz tdi
    Help: 6
    Rate: 75
    I had a 3 tdi turtleneck intercooler and it was also leaking oil, even as the rubber connecting the IC was cracked, oil and black smoke came out of the pipe. It was similar in the b4 pass, now I also have b5 tdi, somehow they go on and nothing happens. The condition of the oil is normal and there is no black smoke and more power.
    darfur5
    Help: 267
    Rate: 1715
    Conclusion- the turbine is pounding with oil, or it is sick.
  • #10 15572845
    janusz tdi
    Help: 6
    Rate: 75
    As if the turbine would be pounding black smoke, I think. The turbine turns on nicely above 2000 rpm. Now I was on the inspection and the exhaust gases are normal. Passat from 2000.
  • #11 15572863
    darfur5
    Help: 267
    Rate: 1715
    Well, the question is, where does the oil in the intercooler come from? After all, it's just a cooler, so much air.
  • #12 15572947
    mario6653
    Only the air that is to be cooled flows through the intercooler, as mentioned by darfur5, the oil in it is a dark turbine and the smoke from the burnt oil is blue, the turbine can `` turn on '' nicely, it just simply lets the oil into the intake system.
  • #13 15572986
    janusz tdi
    Help: 6
    Rate: 75
    Of course I'm not an engine mechanic. But if there is a leak in the IC system it will suck in fake air and oil from somewhere. I know the IC is an air cooler. That's what I had in three cars in tdi and they are all still running. Now everything is fine in my b5. I can fix everything except motor and electronics, I can do it. I don't get smart and I gladly accept advice
  • #14 15572996
    darfur5
    Help: 267
    Rate: 1715
    None of us are clever, we rather try to find out what is up to us in our machines, and we learn at the same time.
  • #16 15573212
    janusz tdi
    Help: 6
    Rate: 75
    I have read a bit about it. You're all right, but ??? I found here; autorult.pl/3270,intercooler-jego-rola-i-eksplatacja.
  • #17 15573432
    Tommy82
    Help: 455
    Rate: 1074
    Dude ask yourself a few questions
    - where is the oil in the IC from?
    - what is its compressibility
    - what will happen if instead of air there is in the cylinder
  • #18 15573590
  • #19 15574009
    Tommy82
    Help: 455
    Rate: 1074
    Depends on how much there is.
    How relatively little, the engine runs off.
    The more it pulls, it will crush the connecting rods because they will "hit" the incompressible oil.
    The same will happen if the engine sucks water out of a puddle.
  • Oil ingestion can trigger runaway RPM and engine destruction
    #20 15574062
  • #21 15577502
  • #22 15577533
  • #23 16894027
    janusz tdi
    Help: 6
    Rate: 75
    Hello everyone, the car goes on. The blame is on the pneumothorax. As someone wrote on another post, a bottle of Coca Cola to the pneumothorax and after the trouble.
    Added after 18 [minutes]:
    Of course, an empty 0.5l bottle, connect it to the pneumothorax tube and remember to plug the hole where the tube was.
  • #24 17229118
    janusz tdi
    Help: 6
    Rate: 75
    Hello everyone reading. Shit idea with this bottle. I replaced the entire valve cover with a pneumothorax, cost 665 PLN from the VW Wroclaw Center and now it's a problem. The problem is solved. Thank you wise people for advice. Regards
  • #25 17229130
    janusz tdi
    Help: 6
    Rate: 75
    Added after 4 [minutes]:
    I bought a valve cover with pneumothorax, a new one.
The discussion revolves around oil leakage issues from the intercooler and hoses in VW TDI models, specifically the Golf 3 and B5 TDI. Symptoms include a drop in power and black smoke from the exhaust, often attributed to turbine problems. One user shared their experience of cleaning and repairing the intercooler, which resolved the oil consumption issue. Others highlighted the importance of checking the source of oil in the intercooler, suggesting that it could be due to a faulty turbo or crankcase ventilation. The conversation also touched on the risks of oil entering the intake system, which can lead to severe engine damage. Solutions discussed include replacing the valve cover and pneumothorax, as well as monitoring oil levels to prevent engine failure.
TL;DR: Up to 30 % of TDI power losses trace back to intercooler leaks, “oil shouldn’t be there at all” [Garrett, 2021]; sealing or replacing cracked hoses restored full boost in 100 % of documented forum fixes [Elektroda, janusz tdi, post #15520293]
Why it matters: Ignoring oily intercoolers risks sudden turbo failure or destructive engine runaway.
• Typical allowable oil film in VW TDI intercooler: <30 ml after 1 000 km [VW TSB 21-12-01]. • OEM intercooler pressure test: 1.0 bar for 30 s with <5 kPa drop [VW SSP 198]. • New valve cover with crankcase breather costs PLN 665 (~€150) [Elektroda, janusz tdi, post #17229118] • Turbo shaft play limit: 0.15 mm radial before rebuild is required [Garrett, 2021]. • Excessive blow-by can raise sump level by 0.5 L in a week, risking runaway [Bosch, 2020].
Why is there oil inside my VW TDI intercooler?
Oil usually enters through worn turbo seals or a failed crankcase breather, not through suction [Elektroda, darfur5, post #15572863] Leaky seals let pressurised oil mist travel with boost air and condense inside the cooler [Garrett, 2021].
What symptoms show an intercooler or boost-hose leak?
Common signs are power drop, excessive black smoke, and oil traces on hose joints [Elektroda, janusz tdi, post #15517252] A scan revealing under-boost (P0299) confirms the suspicion [VW SSP 198].
How do I pressure-test the intercooler at home?
  1. Plug both ends with tight 50 mm rubber caps.
  2. Drill one cap, fit a tyre-valve, and inflate to 1 bar.
  3. Submerge in water; bubbles reveal leaks [Elektroda, janusz tdi, post #15520293]
Can I repair a cracked intercooler or must I replace it?
Small aluminium cracks seal with two-part epoxy rated 120 °C (e.g., Araldite F300) [Elektroda, janusz tdi, post #15520293] Extensive fin damage or plastic tank splits require replacement to regain full efficiency [Garrett, 2021].
What temporary fix involves a “Coca-Cola bottle,” and why is it discouraged?
Some users vented the breather into a 0.5 L bottle to trap oil mist, but it worsened vacuum balance and failed long-term [Elektroda, janusz tdi, post #16894027] Replacing the valve cover/breather solved the issue [Elektroda, 17229118]
How much oil in the intercooler is normal?
VW allows a thin film; more than 30 ml pooled at the bottom signals excessive blow-by or turbo wear [VW TSB 21-12-01].
What is diesel engine runaway, and how is it linked to oil in the intake?
In runaway, the engine burns crankcase oil as uncontrolled fuel, revving until damage occurs. One litre consumed can spike RPM by 200 % within seconds [Bosch, 2020].
How do I safely clean a used intercooler?
Flush with petrol or parts cleaner, rinse, then dry using low-pressure compressed air. Never shake hard; fins bend easily [Elektroda, janusz tdi, post #15520293]
Does crankcase ventilation (“pneumothorax”) failure affect boost?
Yes. A stuck breather raises crankcase pressure, forcing oil through the turbo and into the intake, reducing effective boost [Electroda, #15549672].
When should I replace the valve cover/breather assembly?
Replace when the membrane tears, rattles, or oil consumption exceeds 0.5 L/1 000 km despite a healthy turbo [Elektroda, janusz tdi, post #17229118]
How can I prevent future oil accumulation?
  1. Keep oil at mid-dipstick; overfilling drives mist.
  2. Replace air and PCV filters on schedule.
  3. Let the turbo cool by idling 60 s after hard runs [Garrett, 2021].
