How many watts of power will I "get" from the 16A protection
b-nm 61728 5
  • #1 15528395
    b-nm
    What power (? W) can be connected to the 3-phase protection with 16-amp automatic devices? ... maybe some calculation?
    lukiiiii
    Help: 82
    Rate: 392
    3 X 230V x 16A = 11040W cos fi=1
  • #3 15528475
    b-nm
    b-nm wrote:
    What power (? W) can be connected to the 3-phase protection with 16 Ampere automatic devices? ... maybe what's the calculation?
    ... (3-phase 16A socket) - and the power of the 3-phase motor?
    fiodorus
    As a colleague lukiiiii wrote. If it is a domestic installation (e.g. in the countryside), it also results from the power allocation for the building / farm agreed with the Energy Company. If you want to add something to the existing installation (and used in the building / apartment), however, you must take into account that already operating devices / equipment already consume some of this power. Although this is rarely the case, the old installations were mostly made of aluminum cables, which today are mostly replaceable.
    elvis13
    Help: 18
    Rate: 77
    The 16A socket can withstand a motor whose rated current is max 16A.
    For 16A and cos phi 0.8, the motor power is about 8kW
    And what engine can start on a 16A fuse, it depends on the fuse characteristics: B, C, D, gG ...
    Because it depends on what starting current the fuse will withstand. And the inrush current depends on many factors.
    Is it about a specific engine? Engine nameplate available?
  • #6 15528973
    b-nm
    Thanks for your help, I made sure that it is about strapping the folding machine.
    Power requirement 6 kW (drive, glue heater, etc.).
    Thanks greetings!
