Office Word 2007 - Outer and inner margins, top and bottom, how to set
Jerry111222333 33816 1
  • #1 15535482
    Jerry111222333
    Hello all. I am aware that my question belongs to the trivial category, however, I would like to ask how to set margins in the bag, namely: inner margin - 3 cm, outer margin - 2 cm, top and bottom - 2 cm. I know that you have to give it to non-standard ones, but then I have no idea ... in the tab many pages should be standard, but then I have no idea which margin is internal and which external, if only left top and bottom right. Could you please help me?
  • #2 15535514
    masterten
    Help: 268
    Rate: 284
    Custom and you have to select "mirrored" then you will have internal / external.
    I would like to add that if you have a cover page, you can have different settings for the first page, but if, for example, you want to have a one-sided table of contents, then there are more combinations.
    Same as with margins, it is with page numbering (different on even and odd, different on the first page ...)
