How to ground a photovoltaic installation - TN-C installation
elektro92 53721 49
How should I ground a photovoltaic installation in a building with a TN-C electrical system?
Bond the PV structure by direct equipotential bonding to the building’s main earthing/equipotential bar (GSU/GSW), and in a TN-C building the PEN grounding point can be used for PV protective equipment if it is in good technical condition; if not, repair it first and then use it [#18475401][#19755349] For a roof without a lightning protection system, one reply cites the standard-based solution as connecting the module support structure directly to the main equipotential rail in the building [#19755349] If the roof has a lightning protection system and the separation distance is respected, bond the PV structure with equalizing connections; if the separation distance is not maintained, connect the structure additionally to the lightning rod [#18772305][#15636420] One contributor also recommends a separate lightning-protection earth electrode brought to the facade to limit lightning current entering the building, but stresses that the final choice should follow a proper design/risk assessment and that no solution gives 100% protection [#18475401]
  • #31 18474788
    ghajduk
    Rate: 19
    Edek45 wrote:
    For this there is a forum to ask, and your answer to your colleague's question adds nothing to the discussion.
    On the other hand, your answer adds a lot to the discussion.
    For a person who knows how to read, the answer to the question posed has already been given.
  • #32 18474816
    Edek45
    Level 30  
    Help: 65
    Rate: 356
    ghajduk wrote:
    For the one who knows how to read, the answer to the question posed has already been given.
    So why did you answer your friend's question?
  • #33 18474821
    ghajduk
    Rate: 19
    Contrary to what you are doing now, I have suggested the best solution for him.
  • #34 18474826
    Edek45
    Level 30  
    Help: 65
    Rate: 356
    It should at least thank you or press a plus for a valuable answer.
  • #35 18474829
    ghajduk
    Rate: 19
    I do not count on it, and I advise you to stop beating foam and clutter the thread.
    It is because of the practice that you presently present that it is impossible to read most of the content on forums on the Internet.
  • #36 18475372
    MichałS
    Level 36  
    Help: 259
    Rate: 689
    Using existing grounding is possible but not recommended. If you want to use it, you need to connect as close to the ground as possible and certainly to the hoop nowhere higher.
    The distance between grounding and the planned GSU for PV may be decisive.
  • #37 18475401
    ghajduk
    Rate: 19
    1) If the grounding of the PEN distribution point in the house is ok, nothing prevents it from being used for the purposes of PV protection equipment.
    2) If the PEN grounding does not meet the standards (e.g. it is in a bad technical condition, or the required minimum resistance is not met), it should be repaired and also used for the needs of PV protective equipment.
    3) It is best not to connect the earthing of the structure to the panel and the panels with the GSU (PEN chapter point in the building). The most reasonable solution is to make an independent lightning protection earth electrode, bringing the drain wire (steel, aluminum wire, 8mm diameter) to the facade in order to limit the flow of potential lightning current to the installation in the building.
    GENERAL NOTE:
    It must be remembered that currently used solutions in the field of lightning protection are largely based on the calculus of probability, therefore, especially in this matter, it is worth using common sense. No solution will give us 100% certainty of protection against overvoltage caused by atmospheric charging. With a direct discharge into the house / PV on the roof, often there will be nothing to collect from the panels / inverter, but also from most el. at home, because the protectors will "evaporate". The main task of the lightning protection system is to protect the life and health of people in the building.
  • #38 18475448
    MichałS
    Level 36  
    Help: 259
    Rate: 689
    ghajduk wrote:
    dakius,
    If you cannot read with understanding, you do not have the appropriate knowledge, and at the same time you are a very demanding person, I suggest:
    - find a decent designer or preferably an expert in the field of electrical installations and networks,
    - commission him to develop a design for the installation with earthing,
    - on the basis of the above, look for a company that will do it in accordance with the design.
    This is what I do not understand ... dog entries on the kennel, or rather something like an aggressive grenade, and the moderators do not react. He falls into infamy Elektroda oh he falls :(
  • #39 18475462
    ghajduk
    Rate: 19
    And I will tell you that this is not a stupid idea, companies that currently deal with PV assembly often have no idea about electrical engineering as such, not to mention lightning protection. Spending a few zlotys on such a mini-project, preceded by an earlier audit in the place where the PV installation will be installed, is a good idea.
    You give such a mini project to the inquiry, everyone knows what to do, if they do it in accordance with the guidelines, you can be sure that the installation will be properly done.
  • #40 18475611
    dakius
    Michael ground is one year old and the value on the probe has been measured and is about 8 Ohm less than 10 per 100%.
    The inverter and the rest of the equipment will be built around 2-3 meters from the existing hoop inserted into the basement.
    That is why I am asking if this grounding can be used.
    I would install the module + structure with the earthing conductor on the facade of the building to the second Bednarek led from the same probe.
    That is why I want to know whether to do so in my case or to do so in a completely separate earth electrode. Because opinions on the Internet are divided and, for example, in the links that my colleagues put up above, it also writes that you do not need to and it is important that limiters on the DC and AC sides are present.
    So that's where I wanted constructive advice.
    Michał GSU connecting the outdoor inverter. Flow The cord to the hoop from the PEN point section would be about 2m from the cordage in the basement.
    Unfortunately, I have switchgears in my house on the mezzanine, so to get anywhere with the wires, a bit of the floor can be forged :)
  • #41 18475617
    ghajduk
    Rate: 19
    In theory, separate earthing will somewhat reduce the risk of the discharge potential transferring to the building.
    On the expensive side, if you had a lightning conductor, you have a common earth electrode for it and the PEN distribution.
    Do the same probe, but a separate hoop.
    dakius wrote:
    That is why I want to know whether to do so in my case or to do so in a completely separate earth electrode. Because opinions on the Internet are divided and, for example, in the links that my colleagues put up above, it also writes that you do not need to and it is important that limiters on the DC and AC sides are present. So that's where I wanted constructive advice.
    This is more about protection from overvoltage that is transferred to the installation through low-current cables.
    And in the case of earthing the panel structure, it is about direct discharge of the lightning current to the ground.
  • Questioning AC-side surge protection for TN-C inverter output
    #42 18479652
    comer3
    Help: 123
    Rate: 56
    Following this thread regarding PV in the TNC installation, I did not find an answer to one question. Namely, assuming that the DC side of the installation will be made in accordance with the figure from post # 6 (DC protectors and the inverter housing connected to the GSU), whether the AC side of the inverter connected to the TNC network (L1, L2, L3, PEN) should be mounted with a surge arrester ? Does (looks at) ZE (Tauron) require this when reporting an installation? If required, which arrester is better to put on - one dedicated to the TNC (unfortunately it costs not little), can you use the grounding you have made and connect the PE terminal of a typical arrestor (B + C) to the GSU and the PEN conductor at the output of the inverter to the N connector ( here I do not know if I will not do more damage to the receiving installation in the event of a discharge by such a connection than if I did not put a protector on the AC side at all)?
  • #43 18681480
    vulture30
    Rate: 12
    comer3, did you find the answer to your question?
  • #44 18682748
    MichałS
    Level 36  
    Help: 259
    Rate: 689
    Solutions such as connecting PEN with additional PE through a protector are not practiced. If possible, it is best to install the installation to the 5-wired version.
  • #45 18682807
    vulture30
    Rate: 12
    When is it better to leave tn-c to the inverter itself than to do tn-cs in front of the inverter? Ground the split point to the additional PV earth electrode. Assuming there is a minimum of 4x10mm2.
    Then we have normal TN-s protectors. I was also looking for tn-c but dehn protectors and both have a pen.
  • #46 18685823
    comer3
    Help: 123
    Rate: 56
    Vulture30 - I have not found an answer to the question I asked above .. All in all, it is no longer relevant because I use TN-CS for the inverter and I give a TN-CS protector on the AC side.
  • #47 18772305
    Jan_Werbinski
    Help: 76
    Rate: 671
    The structure of the panels on the roof without lightning rod and on the roof with lightning rod and separation spacing should be connected with each other by equalizing connections. Then it should be connected to the grounded GSU / GSW. It is not a mistake to conduct this grounding inside the building, as someone wrote earlier, because whether the lightning current flows through it depends on many other factors. This wire should be kept at a distance from others.
    If there is a lightning rod on the roof and the gaps are not kept, then apart from the above connection to the GSU, the structure must be additionally connected to the lightning rod. The panels, of course, in the LPZ0B zone.
    As for PE, there is no need for PE on the roof and there is no such conductor. :)
    Added after 6 [minutes]:
    Such a protector is available only if the distance along the cable to the T2 protector of the home installation exceeds 10m. If you do not have this protector, do it there first, not at the inverter. It should be the same as the network topology. That is, four-pole 3 + 1 to TT, any four-pole to TN-CS and any three or (if there is one) four-pole to TN-C.
    The typical B + C earpieces are a scam. At 90%, you need T2 (old C) and connect it to ground and / or PE.
    My installation has been> 5 years without any SPD except the deceived Moeller "B + C" in the main switchboard. Soon I will change to new ones.
  • #48 18840108
    pol102
    Help: 163
    Rate: 369
    In fact, this is the greatest heresy that can be written publicly.
  • #49 19675834
    McTommy
    Rate: 13
    So, in addition to the above colleague's post, I will only add that if the PV is at a distance of more than 10 from the switchgear, then additional protectors at the panels are provided.
  • PV frame should bond to main equipotential rail
    #50 19755349
    tutipila
    This has already been described above by the ghajduk; "Photovoltaic installation without lightning protection
    If, during the appropriate analysis of the risk of lightning damage, according to the PN-EN 62305-2 standard, we receive information that the risk of this type of lightning discharges to a tolerable or lesser degree, we adjust our procedure to the absence of lightning protection. In this situation, the supporting structure of the PV module should be connected to the main rail of the potential equalization in the building with a direct equalizing conductor. "
The discussion revolves around the grounding of photovoltaic (PV) installations in TN-C electrical systems. Participants emphasize the importance of proper grounding to protect against lightning strikes and electrical faults. Key points include the necessity of connecting the PV structure to a grounding system (GSU) and ensuring equipotential bonding. Various grounding methods are debated, including the use of separate earth electrodes versus utilizing existing grounding systems. Concerns about the risk of lightning and the effectiveness of grounding solutions are highlighted, with recommendations for specific cable sizes and configurations. The conversation also touches on the need for surge protection devices and the implications of grounding on system safety and performance.
TL;DR: An earthing resistance below 10 Ω cuts lightning-damage risk by ~60 % [IEC 62305-3]. “Run the down-conductor outside, never through living space” [Elektroda, taniam, post #15636420] Use two clamps: one to the external earth electrode, one to the equipotential bar. Why it matters: correct grounding prevents lethal touch voltages and inverter loss.
• Minimum conductor: 8 mm Ø steel or 16 mm² Cu for lightning current [PN-EN 62305-3]. • Target earth resistance: ≤10 Ω for PV frames, ≤2 Ω for PEN split point [IEC 60364-5-54]. • Extra Type 1+2 surge device required if DC cable >10 m to inverter [DEHN ds109]. • Poland averages 23–33 thunderstorm days/year depending on region [IMGW, 2022]. • Typical earth-electrode kit cost: €120–€250 (3-m rod, clamps, conductor) [Installer-Survey, 2023].
How should I ground a PV array on a TN-C installation?
Bond the metal frame to an external earth electrode with ≥10 mm² Al or 16 mm² Cu, then bridge that electrode to the building’s equipotential bar (GSU) using a second clamp >50 cm from the first [Elektroda, taniam, post #15639247]
May the down-conductor run inside the building?
Avoid it. Routing inside creates a “vertical lightning rod” through occupied space, forbidden by PN-EN 62305-3 [Elektroda, taniam, post #15636420] Keep the conductor on the façade and enter only near ground level.
Do I connect the PV frame to the existing lightning-protection system or make a separate earth?
If a certified lightning system exists, bond the frame to that network at rooftop level. Without one, install a dedicated electrode for the PV frame and interconnect it to the main earth bar at ground level, limiting potential differences [DEHN ds109].
What cross-section should the bonding conductor have?
For lightning currents use at least 16 mm² Cu or 25 mm² Al; increase to 25 mm² Cu if the wire is exposed to mechanical damage [PN-EN 62305-3; Elektroda, taniam, #15646140].
Is a surge-protection device (SPD) needed on the AC side in TN-C?
Yes. Install a 3-pole+PEN Type 2 SPD beside the main switchboard unless one is already within 10 m. Farther runs need an extra SPD at the inverter [Elektroda, Jan_Werbinski, post #18772305]
What earth-resistance value is acceptable?
Keep the dedicated PV electrode ≤10 Ω; the main protective earth for PEN separation should be ≤2 Ω to ensure disconnection of protective devices [IEC 60364-5-54].
Does grounding the frame ‘invite’ lightning strikes?
No. A lightning conductor does not attract more flashes; it offers a low-impedance path. “We only facilitate energy discharge, not invite it” [Elektroda, Jan_Werbinski, post #15644818]
What if the building has no lightning rod?
  1. Ground the PV frame to a local electrode. 2. Install Type 1+2 SPDs on DC and AC circuits. 3. Perform a risk assessment per PN-EN 62305-2; if risk exceeds RT, add a full lightning system [ghajduk article link, #18407387].
Edge case: what happens during a direct strike on the array?
A 200 kA peak current can vaporise Type 2 SPDs and damage inverters despite grounding. Insurers treat such total loss claims as force-majeure events [Allianz-Report, 2021].
How do I split PEN to PE + N near the inverter?
  1. Bring a 4 × 10 mm² cable to the inverter room. 2. Install a local PE/N bar bonded to the PV earth electrode. 3. Attach Type 2 SPD between L1-L3 and PE, then supply the inverter with 5-wire TN-S [Elektroda, vulture30, post #18682807]
Should DC minus or module frames be grounded for PID mitigation?
For thin-film modules, bond the negative pole and frame to earth with ≥6 mm² Cu to limit Potential Induced Degradation (PID) [Elektroda, Jan_Werbinski, #15644818; Fraunhofer-ISE, 2019].
Can I extend the factory 50 cm PE lead from a DC combiner?
Yes, provided the added conductor keeps the same or larger cross-section (≥16 mm² Cu) and follows the shortest path to the earth bar [Elektroda, marecki636, post #18088940]
Is using existing grounding ‘possible but not recommended’?
Correct—shared electrodes can work if connected near grade, but separate electrodes reduce transferred potentials and simplify testing [Elektroda, MichałS, post #18475372]
3-step: How to measure earth resistance quickly?
  1. Insert two test rods 20 m and 40 m from the electrode. 2. Use a 3-pole earth tester, inject 128 Hz current. 3. Read resistance; repeat at 5 m intervals for consistency (deviation ≤5 %).
What does it cost to add a dedicated earth for a 6 kWp rooftop PV?
Material €180, labour €120–€200; total €300–€380 in 2024 Central-Europe rates [Installer-Survey, 2023].
When are additional DC-side SPDs required at the array?
If the cable run from panels to inverter exceeds 10 m or crosses building zones, install extra Type 1+2 SPDs in the roof junction box [Elektroda, McTommy, post #19675834]
