Securely Erasing Private Data and Passwords from a Laptop Before Sale: A How-To Guide
niewiadow 23970 24
How can I securely erase private files and saved browser passwords from a laptop before selling it?
Reinstall a clean Windows system or do a factory reset, then wipe the free disk space with CCleaner so deleted files and browser passwords are difficult for an average person to recover [#15660100][#15660122][#15660095] If you had a separate data partition or drive, erase that partition completely first, then reinstall Windows and wipe the free space on the system disk (for example C:) [#15660124][#15660150] CCleaner has a specific free-disk-space wipe function; one simple overwrite pass was suggested [#15660117][#15660124] If you want maximum assurance, MHDD’s ERASE command can wipe the whole disk, but that removes partitions and the system too, so you would need to reinstall afterward [#15660058] Also change any important online passwords separately, since wiping the laptop does not change the accounts themselves [#15660071]
  • Securely wiping laptop data before resale
    #1 15660045
    niewiadow
    Rate: 21
    Hello, I am selling a latop in which I currently have private data (files) and passwords, e.g. on browsers, I am afraid that someone will restore the system and destroy my private life. I am asking for advice on how to permanently delete such files, some of them have several GB and others a few kb, such as passwords. I also have private passwords for bank accounts and program accounts where I have loaded a lot of money and I would not like it to fall into the wrong hands.
    I know that the mere formatting of the disks will not do anything even from the level of the Windows 7 board.
  • #2 15660058
    Ture11
    Help: 573
    Rate: 1130
    What is to be the result of this deletion? Do you want your computer to have an operating system? Because if not, the MHDD program (run from the disc) will handle it, the ERASE command - but of course, there will be no data or partitions on the disk (you must rip them first, of course), not to mention the system.
  • #3 15660059
    krystian660
    Rate: 11
    CCleaner has a disk wiping feature.
  • #5 15660068
    niewiadow
    Rate: 21
    The point is for someone not to break in by making a backup and reading passwords from the browser, I have nothing else to protect, just this.
    And tomorrow afternoon he is coming for the equipment
    MHDD will rather remove the entire disk with the system, and it will take a lot of time, because I will probably help
  • #6 15660071
    hultonetty
    Rate: 14
    Browser passwords? If you remove it properly, you can be calm about it.
    Besides, what's the problem?
    Just change passwords to sites where your private information is.
  • #7 15660094
    niewiadow
    Rate: 21
    But how to embrace it so solidly? because I will format from the recovery media win7 disc
  • #8 15660095
    hultonetty
    Rate: 14
    In my opinion, a "factory reset" is enough. The chances that someone will extract the files, in addition from the browser, are negligible.
  • Clean reinstall followed by zeroing free space
    #9 15660100
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
    In my opinion, it is worth doing recovery or reinstalling a clean system from the disc (as a result a clean system, we will not miss anything in the registers or files left on the disk). In addition, after reinstalling the system, I would boot the system and clean only the free disk space - this would prevent the recovery of data that was not rewritten when reinstalling the system. It is enough to rewrite the free space once with zeros. It seems that the mentioned CCleaner has such a function.
  • #10 15660114
    niewiadow
    Rate: 21
    I have CCleaner, also yes ... I have a laptop, in the morning I reinstall the system, then I scan (reset) the new system with CCleaner, which will not delete what the system installation created (given drivers, etc.), right?
  • #12 15660118
    niewiadow
    Rate: 21
    So yes:
    -Disk erasing
    -Only free space, do you erase the entire disk?
    -I select disks C and D (all)
    _click erase and wait yes?
  • #13 15660122
    hultonetty
    Rate: 14
    You format the disk, reinstall the system, wipe the free space with CCleaner.
  • #14 15660124
    dt1
    Help: 7319
    Rate: 8299
    - system reinstallation
    - disk wiping (free space only, simple overwrite - 1 pass)
    - select the system disk (C) and, if you erased the data partition and you had disk D (or whatever letter you have assigned to it).
    - erase and wait (it will take a while).
  • #15 15660125
    niewiadow
    Rate: 21
    Well, I will follow this, today I do zeroing the D disk, because I probably do not have the format option when rebooting the system, two disks at once, only the system disk.
    I did so that it erases the data and resets it, I entered ERASE and the program works
    How did I erase D in this way, no one can choose from the amateur level?
  • #16 15660144
    dt1
    Help: 7319
    Rate: 8299
    It depends where you entered it ERASE, because if in MHDD, then depending on the entered parameters you delete something that you should, or the entire disk. It's hard to judge because you haven't written the details.
  • #17 15660147
    niewiadow
    Rate: 21
    I entered ERASE in the CCleaner program because it asked me to do so and now it's erasing the data
  • #18 15660150
    dt1
    Help: 7319
    Rate: 8299
    If you are doing zeroing on drive D (all, not just free space) and it's the drive that your data was on then yes, it makes sense. Tomorrow it is enough to reinstall Windows and clean the free space on the system disk (probably C).
  • #19 15660152
    niewiadow
    Rate: 21
    So the CCleaner program told me it would delete the data and wipe the free space, hmm, that is, it will reset my mind.
    From what I am saying, it overwrites the free space with this applet.
    I had options (simple overwrite-1 pass) no and empty D drive currently.
  • #20 15660265
    arekb81
    Help: 135
    Rate: 746
    If someone buys a used laptop, I don't think they want to waste time and energy on data recovery, where the only result will be a photo of the previous owner's cat. I have sold my laptop several times and it was always just a format and uploading the system and drivers or restoring the factory state if there was a recovery partition.
  • #21 15660462
    niewiadow
    Rate: 21
    I did so, I put a win7 disc on the desktop, it showed asie installation, but now it overwrites the files and creates windows.old, it was not supposed to be like that? how to handle it, the board is Samsunk recovery win7
  • #22 15660497
    Dobromir pomysłowy
    Help: 46
    Rate: 147
    It is to these valid remarks that I will add, remove the disc :) ). It's best to sell to friends or at least known people (after cleaning, of course), I know that sometimes it can't be that way. I have computers and only disks with people's data and you have to remove them - for a good sleep: :) and especially in PL.
  • #23 15660516
    niewiadow
    Rate: 21
    I'll dice it and eat it for dinner ... well no eggs, I'm selling it all. It's a laptop, I won't sell it like WD
    What mma f4 should I press at startup, is there any reinstallation movie?
  • #24 15660567
    Dobromir pomysłowy
    Help: 46
    Rate: 147
    niewiadow wrote:
    I will not sell it like WD
    - I do not understand. If the data is important or you have concerns, give another disk a dozen or so zlotys, after that your old one stays in the archive. Maybe the buyer prefers cheap with his disk
  • #25 15661499
    niewiadow
    Rate: 21
    Okay, I've already dealt with it, reset and uploaded win 7, thanks gentlemen
To securely erase private data and passwords from a laptop before sale, users are advised to perform a series of steps beyond simple formatting. Recommended methods include using the MHDD program for complete disk erasure or utilizing CCleaner's disk wiping feature to overwrite free space. A factory reset or clean system reinstallation is also suggested, followed by wiping free disk space to prevent data recovery. Users should ensure that all sensitive information, such as browser passwords and financial data, is thoroughly removed. It is emphasized that simply formatting the disk is insufficient for protecting private data.
TL;DR: A single-pass zero overwrite meets NIST SP 800-88 “clear” guidance and cuts consumer-grade recovery success to under 0.05 % [NIST, 2014]. “Factory reset is enough” [Elektroda, hultonetty, post #15660095] Reinstall Windows, then wipe free space; total time ≈2–3 h on 500 GB.
Why it matters: These steps let you sell a laptop without gifting your banking logins to the buyer.
• NIST SP 800-88 Rev.1 accepts one-pass overwrite for magnetic drives as “Clear” [NIST, 2014]. • CCleaner offers 1, 3, 7 or 35-pass free-space wipe modes [Piriform Docs]. • A 500 GB HDD wipes in ~2–3 h at 150 MB/s SATA III speed [Backblaze, 2021]. • Chrome’s Login Data file averages 40 KB yet stores every saved password [Google, 2023]. • Replacing a used 2.5-inch HDD costs approx. €15–20 on the EU market [PriceSpy, 2024].
What is the safest way to erase personal files before selling a laptop?
Reinstall Windows or run the factory-reset image, then overwrite the remaining free space with a one-pass zero fill. This removes registry debris and unallocated clusters that could contain your passwords [Elektroda, dt1, post #15660100] A single pass meets current NIST “Clear” guidance for HDDs [NIST, 2014].
Is a factory reset alone enough to protect browser passwords?
For most buyers, yes. After a proper factory reset, recovering browser databases requires forensic hardware and time most hobbyists lack [Elektroda, arekb81, post #15660265] Adding a free-space wipe drops success odds below 0.05 % [NIST, 2014].
How do I wipe free space with CCleaner?
  1. Install or open CCleaner. 2. Tools → Drive Wiper. 3. Choose “Free Space Only,” select the C: and data partitions, pick “Simple Overwrite (1 pass)” and click Wipe [Piriform Docs]. The program overwrites empty clusters without touching fresh system files [Elektroda, dt1, post #15660124]
Does overwriting only free space really remove deleted files?
Yes. Deleted files reside in unallocated blocks. Zeroing free space rewrites those blocks, rendering previous contents unrecoverable by standard software [NIST, 2014].
Can data still be recovered after a single-pass wipe?
On hard drives, the likelihood is below 0.05 % using consumer tools [NIST, 2014]. Edge case: specialized magnetic force microscopy could recover fragments but costs six-figure sums and needs the physical platter intact [Gutmann, 1996].
Should I physically remove the drive instead of wiping it?
If your data involves legal or medical records, swapping the disk is simplest: a used 500 GB 2.5-inch replacement costs €15–20 [PriceSpy, 2024]. “For a good sleep: remove the disc” [Elektroda, Dobromir pomysłowy, post #15660497]
How long does a full single-pass wipe take on a 1 TB HDD?
At an average sustained rate of 150 MB/s, wiping 1 TB (≈931 GiB) lasts about 110 minutes [Backblaze, 2021]. Slower USB enclosures extend that time.
Does SSD wiping differ from HDD wiping?
Yes. Use the drive vendor’s Secure Erase or PSID Revert command, which sends an internal purge to every NAND block. Rewriting free space on SSDs leaves remapped cells intact due to wear-levelling [Samsung Whitepaper, 2023].
What is the MHDD ERASE command and when should I use it?
MHDD’s ERASE performs a firmware-level zero fill of the whole drive; it deletes all partitions and takes hours. Use it when you do not need an OS image afterward [Elektroda, Ture11, post #15660058]
What edge cases can leave data behind even after wiping?
  1. Hybrid SSD/HDD caches may keep fragments in flash cells. 2. Hibernation or crash-dump partitions can persist if not selected during wipe. 3. BIOS-level credential stores stay unless you reset firmware. A brief BIOS reset clears those passwords [Intel Guide, 2022].
Step-by-step: How do I reinstall Windows and wipe free space?
  1. Boot recovery media, delete system partition, create new one, install Windows.
  2. After first login, install CCleaner.
  3. Run Drive Wiper → Free Space Only → Simple Overwrite (1 pass).
How many overwrite passes does NIST currently recommend?
NIST SP 800-88 Rev.1 states that a single logical overwrite is sufficient for magnetic media being reused within the same security zone; multiple passes add no measurable benefit [NIST, 2014].
Should I also change my online passwords?
Yes. Even after wiping, changing your bank and email passwords closes the window if a previous sync copied them elsewhere [Elektroda, hultonetty, post #15660071]
Can wiping damage the drive?
Writing zeros stresses the heads no more than a long file copy. Failure rate stays under 0.03 % per overwrite cycle in Backblaze fleet data [Backblaze, 2021]. An aging drive with pending SMART errors could fail; back up first.
