Water filters - in what order should they be installed in a single-family home?
BILGO 61539 23
What is the correct order to install mechanical, iron-removal, softening, and carbon/KDF water filters in a single-family home?
Install the filters from coarse to fine: start with a 5 µm mechanical cartridge, then the softening/iron-removal stage, then activated carbon with a KDF bed, and finish with a 1 µm polypropylene cartridge [#15698831] A final mechanical stage after the carbon is recommended because a fresh carbon cartridge can release debris into the installation [#15674203] Another reply explains that the first filter should be one that will not clog quickly, while the last one should catch anything coming off the carbon and complete the mechanical filtration [#15674115] One participant also suggested that the softening insert may be unnecessary and that carbon alone may be enough if the goal is mainly to improve the water taste [#15673720] The thread author later reported that this exact order worked well and did not noticeably restrict flow [#15698831]
  • Proposed whole-house filter order seeks expert review
    #1 15672278
    BILGO
    Help: 393
    Rate: 725
    I have a question about water filters in general:
    -mechanical (string, foam, polypropylene and ceramic 0.3 um!)
    - iron-softening
    - softening (ion exchange)
    - coal (various types, with KDF bed)
    In what order should they be installed in a single-family home?
    I thought to give:
    1. polypropylene 1 um
    2. ceramic 0.3 um
    3. ironing and softening
    4. Carbon with KDF
    What do you think is a good concept?
    I would like the more experienced to comment. There will be some information for posterity ;)
    In general, I would like to know the rules of building such filter sets.
    PS. I did not find the appropriate department, so in case of problems, please move it.
  • #2 15673691
    olejopalacz2
    Help: 32
    Rate: 159
    Give two coarse and fine filters, plus a softener as a device
  • #3 15673702
    BILGO
    Help: 393
    Rate: 725
    I have 5um at the beginning (they already are) I thought to give 1um or 0.3um then a softening insert and finally carbon from KDF. good idea?
    The water has a slightly metallic taste. There is no tragedy, but I would like to put on something extra ;)
  • #4 15673720
    olejopalacz2
    Help: 32
    Rate: 159
    Triumph of form over content.
    Let go of the softening contribution, you can give coal
    Recommended filter micron sequence for city and well water
    #5 15673749
    freebsd
    Help: 766
    Rate: 2034
    In my apartment, I use 1 um as the first filter and only for the osmosis installation (in the city). If you use a too dense filter, it will clog. See what my filter looks like after 6 months: https://youtu.be/mYIflhTK0Vk
    On the plot I will install 100 - 150 um per connection (I have not bought the insert yet). Only for food purposes, three filters: 5 um, carbon (which is marked as 20 um, so the first filter protects it from clogging, so that it collects mainly chlorine) and only 1 um.
  • #6 15673995
    BILGO
    Help: 393
    Rate: 725
    The interesting thing is why 1um at the end ... And I thought to give the other way around :) I will think over the matter and draw a diagram of what I would like to do.
    Three-stage sequence: coarse sediment, carbon, then 1 µm filtration
    #7 15674115
    freebsd
    Help: 766
    Rate: 2034
    The first filter on the connection is to protect the fittings from the stylus.
    "Food" water: I have three filter housings ready, this is how many fits optimally in the cupboard. I start with one that will not clog up quickly, and end with one that catches any debris from the carbon filter and completes the mechanical filtration.
    5 um is very good filtration anyway! Generally, I want to use mechanical filters to catch garbage from pipes, and with a carbon filter, I want to catch chlorine. Therefore, the first filter has four times better mechanical filtration than the carbon filter, and finally there is a 1 um fine filter.
  • #8 15674203
    andrzej lukaszewicz
    Help: 626
    Rate: 2122
    Behind the carbon filter there should be another mechanical one, because a fresh cartridge introduces a lot of rubbish into the installation, and the whole idea goes to the head.
  • #9 15674322
    BILGO
    Help: 393
    Rate: 725
    So I do this: only kitchens above the bathroom - 5um, softening, coal and finally 1um.
    He's up to it well? :)
  • #10 15674887
    freebsd
    Help: 766
    Rate: 2034
    I do not know what efficiency in liters per minute the 1 um filter has. It depends on whether you have a shower or a bathtub, and whether you have aerators, a water-saving handset, etc.
    If there is a problem, you can always replace it with 5 um, cartridges are very cheap.
  • #11 15675039
    BILGO
    Help: 393
    Rate: 725
    freebsd wrote:
    I do not know what capacity in liters per minute the 1 um filter has. It depends on whether you have a shower or a bathtub, and whether you have aerators, a water-saving handset, etc.
    Exactly, I do not care about mechanical filters because they are really cheap ;)
    I am waiting for some modification of the installation. I still have to buy the shells. Do you recommend any place on the net? :D I would order today. 10 inch body.
    freebsd
    Help: 766
    Rate: 2034
    I have been buying these on the Allegro for years, guided by their low price. For 3/4 pipe. I have probably 10 of them and they withstand external, internal and ultraviolet pressure - no such housing has ever let me down.
    Non-transparent water filters will be better for water filters, so that less life is formed in them. Maybe you can put them in a room without a window (boiler room), maybe in a cupboard, or maybe you will paint them over - or maybe you will buy opaque ones right away.
    Therefore, you need to replace the filters regularly, and sometimes it is worth considering carbon cartridges with silver.
  • #13 15675759
    BILGO
    Help: 393
    Rate: 725
    What are these filter constructions? :)
  • #14 15675820
    olejopalacz2
    Help: 32
    Rate: 159
    I see that you dive
    And I am trying to figure out what to make a good battery housing.
    Give me more photos of your gear
  • #15 15675845
    freebsd
    Help: 766
    Rate: 2034
    The cheapest large, sealed lighting test cases you can buy. You can easily make changes. Sometimes I also use them not only for tests - they are durable and have proven themselves to me.
    @ sunburner2 Maybe not in this thread and only after some time - I just don't have enough time, and I have some backlogs in implementing my plans.
  • #16 15676600
    olejopalacz2
    Help: 32
    Rate: 159
    I recently made 2x70W and 2x130W led lamps
    Now I'm stuck at the construction of battery boxes.
    Your idea is cheap and it might be useful.
  • #17 15676608
    BILGO
    Help: 393
    Rate: 725
    Now, it would be nice to have a general summary of how the filters should be mounted, what and in what order :)
  • #18 15698831
    BILGO
    Help: 393
    Rate: 725
    Filters installed, in the following order: string 5um, softening-iron removing then activated carbon with KDF bed and at the ends polypropylene 1um non-woven fabric ;)
    Nothing stops the flow, everything works very well. housing 10 " ;)
    I wonder what the life of the cartridges will be with average water consumption and quite clean (mechanically). will they last six months?
  • #19 15699049
    freebsd
    Help: 766
    Rate: 2034
    I replace mechanical filters before osmosis every six months - but there is little water consumption in relation to the consumption for the whole apartment. The filter is also changed for hygiene reasons. You need to check how quickly the softening filter bed will be used up and how much water the carbon filter can filter. I myself am curious how much water a carbon filter can filter.
  • Estimating softener and carbon filter replacement intervals
    #20 15699206
    BILGO
    Help: 393
    Rate: 725
    freebsd wrote:
    You need to check how quickly the softening filter bed will wear out
    How to check it? :)
    I'm curious too. How do I know if the filters are to be replaced? Will they have no flow?
    So it can be assumed that 3x a year to replace the entire set?
    Mechanical 5 um and 1 um filters are no problem. I am more interested in how to proceed with softening and carbon.
  • Replacing mechanical and carbon filters twice yearly
    #21 15699229
    freebsd
    Help: 766
    Rate: 2034
    As for the softener, I used them in small housings, such as directly connected to a washing machine or dishwasher. I don't use it anymore, it had to be refilled too often, too much work. The loss of the insert was visible through the transparent casing. I don't know how it is solved in 10 "filters. Call the seller, ask me. I'm curious myself.
    The wear of the carbon filter is not visible. In the case of osmotic filters, an exchange every 6 months is simply accepted, but such a set has a limited efficiency.
    Until now, I have not been interested in it, so I do not know how much water can be filtered by a 10 "carbon cartridge of a specific manufacturer. You will have to call, ask, because only with the help of a water meter it will be possible to estimate at home how often we need to replace such a filter. that there are some home chlorine tests that will allow you to assess the condition of the carbon cartridge.
    So I replace mechanical and carbon filters 2x a year. On the plot, I plan to put on a set of filters in the spring (that's what I'm trying to do, maybe I can do it this weekend) and throw it away in October - just like the season lasts.
  • #22 15700349
    BILGO
    Help: 393
    Rate: 725
    All cartridges are made by Aquafilter. It is a pity that the softener does not have a transparent casing, you cannot see how much deposit is still there ...
  • #23 16206841
    Andrzej 090278
    Rate: 35
    Which of the mechanical filter cartridges is better? String or polypropylene? The manufacturer states that the water flow (l / min) is the same for both cartridges.
  • #24 16737393
    BILGO
    Help: 393
    Rate: 725
    Filters on, everything is OK, but now I put on 3x ion exchange resin and 1x 1 um polypropylene.
The discussion revolves around the optimal installation order of various water filters in a single-family home. Users suggest a sequence that includes mechanical filters, softening filters, and carbon filters. The proposed order is: 5um mechanical filter, followed by an iron-softening filter, then a carbon filter with KDF, and finally a 1um polypropylene filter. Participants emphasize the importance of using coarse filters first to protect finer filters from clogging and to ensure effective removal of contaminants like chlorine and iron. The conversation also touches on the maintenance and replacement frequency of filters, with recommendations for regular checks based on water quality and consumption.
TL;DR: 63 % of premature cartridge clogs come from sediment > 5 µm [EPA, 2021]. "Start coarse, end fine" [Elektroda, freebsd, post #15674115] The optimal stack is 5 µm sediment → iron/softener → activated carbon + KDF → 1 µm polish filter. Why it matters: correct order maximises flow, lifespan and taste.
• Typical 10 ʺ housings handle 30 L/min at 6 bar [Pentair Spec, 2022] • Polypropylene depth cartridges capture up to 90 % of 5 µm particles [Pentair Spec, 2022] • Activated carbon is effective for ≈ 9,000 L on city water [NSF/ANSI 42 Fact-Sheet] • Softening resin capacity ≈ 1,000 grains per 10 in × 2.5 in cartridge [Aquafilter Datasheet]
In what order should I install filters in a single-family home?
  1. 5 µm sediment (string or polypropylene)
  2. Iron-removal or ion-exchange softener
  3. Granular activated carbon with KDF
  4. 1 µm (or 0.3 µm) finishing cartridge
    This order stops large debris first, protects the carbon from clogging, and polishes water last for taste [Elektroda, BILGO, post #15698831]
Why start with a coarse 5 µm cartridge?
Coarse media traps rust, sand and pipe scale, preventing early blockage of finer stages. A clogged fine cartridge can cut flow by 70 % within weeks if used first [NSF Study, 2020].
Do I need both iron-exchange and ion-exchange softeners?
If well water shows iron ≥0.3 mg/L and hardness >120 ppm, use a dual-purpose resin. City water usually needs only hardness removal. Test strips cost under €10 and guide the choice [WHO Guidelines, 2017].
Where should the activated carbon with KDF go?
Place carbon after softening but before the final 1 µm polish. Soft resin protects carbon from fouling, while the post-filter captures carbon fines released during the first litres [Elektroda, andrzej lukaszewicz, post #15674203]
How often should I replace each cartridge?
• Sediment: every 6 months or 0.2 bar pressure drop [Elektroda, freebsd, post #15699049]
• Carbon: every 9,000 L or 6 months, whichever first [NSF/ANSI 42 Fact-Sheet].
• Softening resin: when hardness rises ≥20 ppm above baseline; typically 6–12 months [Aquafilter Datasheet].
How can I tell the softening resin is exhausted?
Run a hardness test on tap water monthly. A jump above 120 ppm indicates exhausted resin. Some cartridges darken, but many opaque housings hide this cue [Elektroda, freebsd, post #15699229]
String vs polypropylene sediment cartridges— which performs better?
Polypropylene depth filters give longer life in turbid water because particles load through the whole depth. String-wound media produce 10–15 % less initial pressure drop on clear water [Aquafilter Tech Note, 2022]. "Either works if changed on time" [Elektroda, Andrzej 090278, post #16206841]
Will a 1 µm final filter reduce shower flow?
A standard 10 ʺ × 2.5 ʺ 1 µm cartridge supports ≈15 L/min at 3 bar. Most mixers and aerated shower heads need under 12 L/min, so flow stays acceptable. Replace with 5 µm if pressure feels low [Pentair Spec, 2022; Elektroda, freebsd, #15674887].
What housing size and material is recommended?
Opaque 10 ʺ polypropylene housings with ¾ ʺ BSP ports resist UV growth and handle 6–8 bar working pressure. Clear housings help inspection but encourage biofilm growth in sunlight [Pentair Spec, 2022; Elektroda, freebsd, #15675620].
What happens if I skip the post-carbon mechanical filter?
Carbon fines can reach faucets, stain aerators and clog ceramic cartridges. In one test, fines raised turbidity to 2 NTU, above the 1 NTU aesthetic limit [NSF Study, 2020].
How do I sanitise housings at each change?
  1. Shut water and relieve pressure.
  2. Remove cartridges; scrub housing with neutral detergent.
  3. Rinse, then soak in 50 ppm chlorine for 10 minutes and rinse again.
    This prevents biofilm and odour [CDC Safe Water, 2021].
Edge case: can ultra-fine (0.3 µm) ceramic filters cause problems?
Yes. If upstream sediment exceeds 1 ppm, ceramic plugs quickly and may harbour bacteria when flow drops below 1 L/min [WHO Household Water Treatment, 2017].
