Unscrewing Narur Water Filter: Seeking Suitable Key for KEL 161016 Cartridge Replacement
Htomas 22953 6
  • #1 16714397
    Htomas
    Rate: 152
    Friends have 2 such filters. Apparently they can't be unscrewed to replace the cartridge. On the net I found that there are special keys in DIY stores. But what key would fit? The filters have inserts with the designation KEL 161016.
  • #2 16714410
    Foxtrott
    Help: 253
    Rate: 944
    Search alledrogo "water filter key". Also order new O-rings and refills.
  • #5 16714436
    1 PAWEL
    Help: 674
    Rate: 1364
    Always replace, old seals are deformed.
    Check the diameter at home.
  • #6 16714440
    Foxtrott
    Help: 253
    Rate: 944
    The basic question when they were last unscrewed = exchanged cartridges, since you have difficulty unscrewing it can be thought that a long time ago or someone too tightened - in both cases the rubber O-ring could lose its properties and thus problems with tightness.
  • #7 16717698
    Htomas
    Rate: 152
    Apparently it was 2 years ago. The universal key bought in the supermarket for PLN 10 turned out to be a bit too small. I think these are some very old filters. However, I found a chain there, through which the eye could be threaded M6 screw. I wrapped the serrated part of the filter with a chain, turned the screw firmly and after pulling the chain the filter finally gave way. O-rings turned out to be OK, after inserting new string inserts and screwing the filters everything is OK, water flows better and nothing leaks :D
The discussion revolves around the difficulty of unscrewing Narur water filters to replace the KEL 161016 cartridges. Users suggest searching for a suitable water filter key, specifically a 10-inch filter wrench, and emphasize the importance of replacing old O-rings to maintain proper sealing. One user shares their experience of using a chain and an M6 screw to successfully unscrew an old filter after two years of being tightly sealed. After replacing the cartridges, they confirmed that the water flow improved and there were no leaks.
