Unlock Port 25565 on UPC Router for Minecraft Server: Fix FAILED TO BIND TO PORT Issue
patrykdens 12417 13
How can I make Minecraft server port 25565 work on a UPC router when the server shows “FAILED TO BIND TO PORT”?
Set the PC’s correct local IP address in the router’s DMZ, then restart the UPC router by fully power-cycling it; if it still fails, check that the system firewall or antivirus is not blocking the connection and, if needed, contact UPC [#15698630] [#15699169] [#15698582] [#15702236] One reply also noted that Wi-Free was not relevant here for the 10 Mbps service [#15699805] [#15699937] A later workaround reported by another user was to forward external port 80 to internal port 25565, and leave `server-ip=` empty or set it to the machine’s local LAN address [#20979453]
  • #1 15698401
    patrykdens
    Hello, I have been struggling with this problem for a long time ... namely, I would like to just play a game with a friend in which the server in this case minecraft port 25565 is used. In the server files "FAILED TO BIND TO PORT" pops up I tried various guides but to no avail. Could someone direct me what and where to enter so that the port 25565 would simply work and the server did not display a message about the problem with ports?
    Unlock Port 25565 on UPC Router for Minecraft Server: Fix FAILED TO BIND TO PORT Issue Unlock Port 25565 on UPC Router for Minecraft Server: Fix FAILED TO BIND TO PORT Issue Unlock Port 25565 on UPC Router for Minecraft Server: Fix FAILED TO BIND TO PORT Issue
  • #2 15698582
    jimasek
    Help: 3783
    Rate: 2682
    Do you only have a vendor modem-router or some other device? Communication can also be blocked by a system firewall or some anti-virus.
  • #3 15698630
  • #4 15699072
    patrykdens
    I only use the router
    Added after 7 [minutes]:
    jurek.adam wrote:
    Most likely to use DMZ on comp. where do you play. Sometimes it requires a restart of the UPC router for it to take effect.
    I did and reset the modem but still the same
  • #5 15699169
  • #6 15699805
    KOCUREK1970
    Help: 3867
    Rate: 5500
    patrykdens wrote:
    How to unblock port 25565 on the UPC router
    And the Wi-Free service is active - if so - turn it off (in My UPC).
  • #7 15699917
    patrykdens
    Will you tell me where I can check if it is active? My internet speed is 10mb and access to wi-free is only from 30; /
  • #8 15699937
  • Disabling UPC VPN service enables port forwarding
    #9 15699966
    KOCUREK1970
    Help: 3867
    Rate: 5500
    jurek.adam wrote:
    Besides, it has no influence on port management, because it is a separate VPN.
    As I have mentioned many times - it may not matter (in your opinion), but deactivating this service results in port forwarding (this is my experience in this matter).
    If in the future you will have higher speed - then:
    KOCUREK1970 wrote:
    disable (in My UPC).
    You set up an account with them there - you get a password by letter (this was the case with me 10 years ago) - and you have the whole spectrum of what you have for services.
  • Requesting DMZ settings and ipconfig output
    #10 15699985
  • Disabling the router service restores port forwarding
    #11 15700027
    KOCUREK1970
    Help: 3867
    Rate: 5500
    jurek.adam wrote:
    therefore the other versions are simply someone else's placebos.
    No placebo - only organoleptically proven effectiveness of disabling this service.
    jurek.adam wrote:
    I just know how a separate VPN, which is Wi-Free, works and that the redirects do not hit it, because they are made by the firewall on this router
    But why in this version it doesn't work - and when the service is deactivated, everything starts to work.
    It doesn't matter what should work - just what works.
  • Requesting DMZ and ipconfig details for port diagnosis
    #12 15702131
    patrykdens
    jurek.adam wrote:
    It doesn't hurt to turn it off, but it won't help either. I just know how a separate VPN, which is Wi-Free, works and that the redirects do not hit it, because they are done by the firewall on this router.
    Wi-Free can negatively affect wifi, not port management through your local firewall.
    And here there is no Wi-Free at all, because it starts at 30 Mb / s.
    @patrykdens
    Show what you set in the router's DMZ and the result from ipconfig / all with comp. which port is to be open.
    I set up the address of the computer in the DMZ Unlock Port 25565 on UPC Router for Minecraft Server: Fix FAILED TO BIND TO PORT Issue
    and in cmd it looks like this:
  • #13 15702236
  • Port 80 forwarding works around blocked 25565
    #14 20979453
    nudeskialika
    UPC blocked external port 25565, I don't know if it was on the router or somewhere else. The only way that worked was to forward port :80 -> :25565
    It says in port forwarding
    This function allows you to configure services in the local network such as **web servers**, FTP servers, e-mail servers, etc. in a way that allows them to be obtained from the Internet
    So by setting the port to 80 minecraft impersonates the HTTP server and suddenly it works.
    Btw. in server.properties the server-ip= attribute should be left empty or possibly set to the address of the machine in the local network.
The discussion revolves around resolving the "FAILED TO BIND TO PORT" issue when attempting to set up a Minecraft server on a UPC router using port 25565. Users suggest checking for potential conflicts with system firewalls or antivirus software, and recommend configuring the router's DMZ settings correctly. It is noted that a router restart may be necessary for changes to take effect. One user mentions that UPC may block external access to port 25565, proposing a workaround by forwarding port 80 to 25565, allowing the Minecraft server to function as an HTTP server. Additionally, it is advised to leave the server-ip attribute in the server.properties file empty or set to the local machine's address.
