Cleaning CPU: Using Evina Nail Polish Remover with Aqua, Acetone, Vitamin F & Flower Extract
Bartasek94 21969 9
Can I use Evina nail-polish remover containing water, acetone, vitamin F, and flower extract to clean old thermal paste from a CPU?
You can use it cautiously on the CPU, but it is not the preferred cleaner because acetone is very strong and may damage plastic, while the vitamin F or flower extract may leave an oily residue [#13240598] Isopropanol or pure alcohol is recommended for cleaning computer components [#13235707] Pure technical acetone is also available, but it should be kept away from plastics and used carefully [#13240006] If using the remover, apply it only to remove the paste residue, avoid soaking the CPU, and wipe away any residue afterward [#13240598]
  • #1 13235396
    Bartasek94
    Rate: 10
    Is the evina nail polish remover with the composition, and I quote: aqua, acetone, vitamin F and flower extract suitable for cleaning old prock paste?
    Regards.
    ValValiantThor
    Help: 160
    Rate: 150
    So.
  • #3 13235707
    Dra98
    Help: 1321
    Rate: 1076
    It should not be used to clean the CPU or other computer components mainly because of acetone.
    Isopropanol or pure alcohol is best.
  • #4 13235753
    ValValiantThor
    Help: 160
    Rate: 150
    Isopropanol is known to be useful, and why not acetone for cleaning the CPU?
    Source and contraindications, please?
  • #5 13239991
    termit202
    Help: 23
    Rate: 12
    Because, in addition to acetone, it contains flower extract and vitamin F ...
  • #6 13240006
    elessar87
    Help: 198
    Rate: 88
    It is good for initial cleaning, but buying a half-liter bottle of technical acetone in a hardware store costs 4-5 zlotys, so you can jerk off. Well, unless this flower extract has some effect on improving cooling efficiency, I would like to pay you back.
    Isopropanol is used to clean the electronics. There is no flower extract there.
  • #7 13240158
    Bartasek94
    Rate: 10
    Yeah .. the problem is I asked in different stores and people have no idea what's going on ...
  • #8 13240527
    elessar87
    Help: 198
    Rate: 88
    Depends where you ask. It should be in good computer stores. The internet is full of offers. I once acquired this specificity on the website. I needed it now and the guys poured me a jar for the usual "thank you".
  • #9 13240593
  • Acetone removes thermal paste without harming CPU dies
    #10 13240598
    ValValiantThor
    Help: 160
    Rate: 150
    Well, explain me what it will do?
    First you wrote that acetone is harmful, now that flower extract and vitamin F. Stop overdoing it. I will tell you what it looks like.
    Acetone, it can damage the plastic (hence the caution), it will not damage the cpu, after all, he only wants to remove the paste residue. Unless she bathes him in acetone.
    As for the extract, it depends on what it is, it can only leave an oily trace, which we simply wipe off. I will stop fiddling anymore. I use isopropanol on a daily basis, and when it is not there, I use a remover and 400 processors have already passed through the remover and each WORKS. Some have been working for years.
    Don't make it unknown, because it's impossible to read. Give me facts, not rumors? Where are these sources and contraindications? There are 2 chemists around me and neither of them says what you say.
    The downside to acetone is that it is very strong.
The discussion centers around the suitability of Evina Nail Polish Remover, which contains aqua, acetone, vitamin F, and flower extract, for cleaning old thermal paste from CPUs. Responses indicate that while acetone is effective for cleaning, it poses risks to plastic components and may not be ideal for electronics. Isopropanol is recommended as a safer alternative for cleaning CPUs. Some participants argue that the additional ingredients in the nail polish remover could leave residues, while others share personal experiences of using acetone without issues. The consensus leans towards using isopropanol for electronic cleaning due to its effectiveness and safety.
