Automatic Transmission Oil Change for Hyundai i40 2014 at 172000km - Guidance Needed
bobinski 24993 4
  • #1 16762387
    bobinski
    Help: 6
    Rate: 27
    Can I change the oil in the automatic transmission (static or dynamic)?
    Mileage 172000 km, 2014
    Mostly highway, max. Two passengers.
    In the instructions is that you can every 90000km, but the authorized service advises against.
  • #2 16762817
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    Please replace statically. You won't change the oil filter, it is built into the chest.
  • #3 16763417
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    Because he cannot or does not cut off the branch on which he sits. The chest will fall, it will be a profit.
    You only need to follow the recommended oil and quantity very carefully. Another might spoil it quickly
  • #4 16770995
    andexp
    Help: 57
    Rate: 278
    Only dynamically. Static replacement is fiction and asking for trouble in the future, especially in crates where oil has never been changed and with high mileage.
  • #5 16775580
    Michal_WWL
    Help: 76
    Rate: 284
    Static exchange is certainly safer. You need equipment and skills for dynamic use. A small delay in topping up and you can break the crate. Probably why not everyone undertakes it. A medium-skilled amateur will make a static exchange even at home under the block.
    As for fiction, I will disagree. I know a few mechanics who are behind this exchange method, but they advise against dynamic exchange. I exchange static in a car already 3 and (knock) everything works. If someone has a crate, any exchange would not help.
