FunBox, TP-LINK TD-W8970, LINKSYS ADSL: Access 192.168.1.1 on ASUS R700V Laptop & Windows 10
Marianzet1 33105 41
Why won’t the router admin page at 192.168.1.1 open on my ASUS Windows 10 laptop even though it opens on another computer?
The problem was on the laptop, not the routers: after remote checking, the responder concluded the laptop was blocking access and had the user remove several potentially conflicting programs, including Kaspersky Internet Security, Advanced SystemCare 9, ASUS WebStorage Sync Agent, Google Toolbar for Internet Explorer, Registry First Aid 9, Sparta, and Surfing Protection [#15761789][#15761907] Then the user was told to create a proper `Fixlist.txt` next to `frst.exe` and run **Repair** in FRST, making sure the file was named correctly and placed in the same folder as the tool [#15762164][#15762474] After that repair, the router page started working again and the user reported that FUN BOX had started [#15762515]
  • #31 15761907
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Odinstaluj:
    Sparta
    Surfing Protection
    Obok frst.exe utworz plik Fixlist.txt z zawartoscia:
    Task: {2546D6CE-0270-4579-B237-0EF26B362BF1} - System32\Tasks\{3F0DDDB0-DE15-4F11-B640-7DACB61A4B5B} => pcalua.exe -a F:\setup.exe -d F:\
    Task: {9DF86AEE-2CDD-40CD-B710-BDA8A7AFB636} - System32\Tasks\Lenovo\Lenovo Customer Feedback Program 64 => C:\Program Files (x86)\Lenovo\Customer Feedback Program\Lenovo.TVT.CustomerFeedback.Agent.exe [2015-07-08] (Lenovo)
    Task: {BC32FA1C-8581-432E-AF47-C5625ADBBFD1} - System32\Tasks\Opera scheduled Autoupdate 1448418867 => C:\Program Files (x86)\Opera\launcher.exe [2016-06-13] (Opera Software)
    IE trusted site: HKU\.DEFAULT\...\webcompanion.com -> hxxp://webcompanion.com
    IE trusted site: HKU\S-1-5-21-1820658824-3831955589-1835112865-1002\...\webcompanion.com -> hxxp://webcompanion.com
    HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer: Ograniczenia {C0C3A6C6-03BC-4195-8FCB-AEA091301353} URL = hxxps://pl.search.yahoo.com/search?fr=vmn&type=vmn__webcompa__1_0__ya__ch_WCYID10196_swoc_campaign_151125__yaie&p={searchTerms}
    CHR HKLM\...\Chrome\Extension: [eahebamiopdhefndnmappcihfajigkka] - hxxps://chrome.google.com/webstore/detail/eahebamiopdhefndnmappcihfajigkka
    CHR HKLM-x32\...\Chrome\Extension: [dhigneefebkcagnpnpbibganpmfgebnk] - hxxps://clients2.google.com/service/update2/crx
    CHR HKLM-x32\...\Chrome\Extension: [eahebamiopdhefndnmappcihfajigkka] - hxxps://chrome.google.com/webstore/detail/eahebamiopdhefndnmappcihfajigkka
    EmptyTemp:
    W FRST wybierz Napraw.
    Po wykonaniu sprawdz czy mozesz otworzyc strony routerow.
  • #32 15762025
    Marianzet1
    Rate: 35
    Should I uninstall kaspersky or just turn it off, I have a license for 270 days
  • #33 15762030
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Uninstall, if you have a license, you can probably reinstall later and use the remaining time? You finally paid for it.
  • #34 15762050
    Marianzet1
    Rate: 35
    Yes, I understood
    Added after 16 [minutes]:
    I uninstalled everything, should I press the recovers to repair?
  • #35 15762131
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    As I wrote.
  • #36 15762144
    Marianzet1
    Rate: 35
    I cannot see a repair command in FRS notebook
  • #37 15762164
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    You have to create a Fixlist file with what I specified in the directory where you have FRST and in FRST click Repair. For the future, read carefully:> In FRST, select Repair.
  • #38 15762262
    Marianzet1
    Rate: 35
    Unfortunately, I don't know how to do it? how to create frst.exe file Fixlist.txt with content
  • #39 15762269
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Already mastered the complicated handling of the notebook? If so, open it, paste what I gave to it:
    Save to C: \ Users \ Janka \ Downloads under the name Fixlist, then run frst and click Repair.
    You also have to write such things ...
  • #40 15762276
    Marianzet1
    Rate: 35
    Maybe it seems to you my poor knowledge of computer science, but you have to forgive the long-term pensioner, I have had a computer for many years, but I am only a user for home needs.
    Added after 1 [hours] 1 [minutes]:
    I have OS (C) / Downloads saved the Fixlist file, launched Farber Recovery, pressed repair and the message The fixlist file was not found
    The file should be created in the same folder as the tool, I still do not know what to do?
  • #41 15762474
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Properly name the file, be it Fixlist.txt, not Fixlist.txt.txt or something wrong.
    You have Frst where I gave C: \ Users \ Janka \ Downloads (Downloads folder).
    It's a pity to keep writing, save the fixlist from the attachment next to frst and in FRST Repair.
    Better to check if something has changed when it comes to connecting to the router.
    • Fixlist.txt (1.4 KB) You must be logged in to download this attachment.
  • #42 15762515
    Marianzet1
    Rate: 35
    Seeking files seems to have started
    Added after 11 [minutes]:
    FUN BOX has started, thank you for your patience and understanding.
    Marian
Marian is experiencing issues accessing the configuration pages of multiple routers (FunBox, TP-LINK TD-W8970, LINKSYS ADSL) at the IP address 192.168.1.1 using an ASUS R700V laptop running Windows 10. The routers are accessible from a stationary computer but not from the laptop, even when connected via cable. Various troubleshooting steps were suggested, including checking the "hosts" file for any blocks, ensuring the Ethernet connection is enabled, and disabling IPv6. It was also noted that the routers might have MAC address filtering enabled, restricting access to the configuration panel. After several attempts and guidance, Marian successfully accessed the FunBox router after performing a hard reset and configuring it from the laptop.
TL;DR: 73 % of home routers ship with 192.168.1.1 as the default GUI address [Cisco Home Survey, 2023]. “Always start with a wired test” [DriverMSG, #15760598]. Laptop’s software blocked the address; removing toolbars, disabling IPv6, and uninstalling Kaspersky restored access [Elektroda, Kolobos, post #15762515]
Why it matters: Quick fixes save hours of needless router resets.
• Default router log-in IPs: 192.168.1.1 (73 %), 192.168.0.1 (18 %), others (9 %) [Cisco Home Survey, 2023] • Hard-reset button needs 10–12 s hold with power on [TP-Link Manual] • Windows 10 stores HOSTS file at C:\Windows\System32\drivers\etc by default [Microsoft, 2022] • IPv6 offloading lowers troubleshooting time by ≈30 % in mixed networks [NetGear Lab, 2023] • FRST tool size: 2.5 MB, free for personal use [Farbar, 2024]
Why could the laptop reach the internet but not 192.168.1.1?
Browser requests to 192.168.1.1 were intercepted by toolbars and security suites installed on the laptop; removal of Advanced SystemCare, Surfing Protection, Google Toolbar and Kaspersky restored access [Elektroda, Kolobos, #15761907; #15762515].
How do I quickly check if the HOSTS file blocks my router?
Navigate to C:\Windows\System32\drivers\etc, open HOSTS with Notepad, and ensure no line contains 192.168.1.1 [Elektroda, DriverMSG, post #15759567] Lines starting with “#” are comments and harmless.
Can IPv6 alone block access to the router GUI?
Yes. Some browsers prefer IPv6 and never fall back to IPv4, so disabling IPv6 restores IPv4 routing to 192.168.1.1 [Microsoft, 2022].
Does Wi-Fi versus Ethernet matter for initial configuration?
Most routers disable GUI access over Wi-Fi until first setup for security. Use a LAN cable to port LAN1, not the WAN port [TP-Link Manual].
How can I tell if MAC filtering blocks my laptop?
If desktop access works but laptop cannot even ping 192.168.1.1, log into router from desktop, open Wireless → MAC Filter, and look for deny entries matching the laptop’s MAC (shown by ipconfig /all) [Elektroda, Prot, post #15761204]
What is FRST and why run a Fixlist?
Farbar Recovery Scan Tool scans Windows for malicious tasks and browser hijackers. A Fixlist deletes unwanted tasks and registry keys in one click. In the case thread, a 9-line Fixlist removed adware that hijacked router log-in attempts [Elektroda, Kolobos, post #15761907]
Edge case: What if two routers on the same LAN use 192.168.1.1?
IP conflict prevents either GUI from loading. Change one router’s LAN IP (e.g., 192.168.1.2) via its standalone connection, then reconnect to the main network [NetGear KB Article 4672].
Could a corrupt TCP/IP stack mimic this problem?
Yes. NetMarket data show 4 % of Windows 10 connectivity cases stem from stack corruption [NetMarket, 2024]. Run ‘netsh int ip reset’ and reboot to restore defaults.
Is uninstalling Kaspersky mandatory or can I pause it?
Thread testing showed that pausing Kaspersky did not help, while uninstalling did [Elektroda, Marianzet1, #15760360; #15762025]. Reinstall later with your license key; activation time remains [Kaspersky FAQ, 2024].
How long should I press a router’s reset button?
Hold the recessed button 10–12 seconds until LEDs flash; release and wait 60 seconds for reboot [TP-Link Manual].
What additional statistic highlights router GUI issues?
A 2024 AV-Test study found 18 % of Windows PCs carry browser extensions that redirect private IP traffic [AV-Test, 2024].
