Blow AVH-9880 Navigation Upload Issue: How to Load Maps from MicroSD on 2 Din Radio
przemojuve 21204 12
How do I load navigation maps from a microSD card on a Blow AVH-9880 so the GPS app will start?
To load the maps, open the main menu, enter GPS, choose Settings, calibrate it, and set the path to the navigation EXE file; then go back to the GPS submenu and start the second icon. Put the card into the GPS slot, not the first slot from the left [#17439431] If navigation is slow, increase the GPS baud rate in settings, for example to 19200 bps or higher [#18144914] If it still does not start, the navigation image itself may be the problem [#17439431]
  • #1 17386169
    przemojuve
    Hello, I have a 2 din blow radio avh-9880
    Everything is fine, but I have a problem with uploading navigation. I downloaded a map car, I have it on a microsd account and I can not fire it on the radio in any way. After going into the GPS menu, I click on the navigation and nothing happens, I do not read the radio on these maps from the card. I can not change the path, I can not install it on the radio. Please help.
    • Blow AVH-9880 Navigation Upload Issue: How to Load Maps from MicroSD on 2 Din Radio f3c7a4224060b34deaf427b831d1.jpg (62.52 KB) You must be logged in to download this attachment.
  • #2 17390227
    marek216
    Help: 1077
    Rate: 932
    przemojuve wrote:
    I downloaded a car map, I have it on a microsd account
    Did you download the installation and install or did you find a "pirate" and copied 1: 1 on the card?
  • #3 17391564
    przemojuve
    pirate and installed on the card
  • #4 17439431
    hugo9
    Rate: 13
    After clicking on the main menu you need to select gps. A submenu appears and two icons. Select settings. Calibrate and set the path. Go back to the submenu and start the second icon. It will definitely work, unless the problem lies in the navigation image. You should also remember to put the card in the GPS slot and not the first from the left.
  • #5 17471658
    Adam546
    Hello, I know that it is not about the subject but I am looking to buy such a radio and I have a question if you can listen to music when the navigation is on?
  • #6 17474675
    Goalkeper
    Rate: 14
    You can listen to music. I just got back from the AM tests on the BLOW 9880. Unfortunately, I do not know if it's the card's fault or the radio has it so far that the automapa has been refreshing itself for a long time. It lacks liquidity. When I finish the turn maneuver, after a few dozen meters the map is set to the direction of travel, but its rotation can not be seen.
  • #7 17514490
    inwazja
    Have you tested it any longer? Surely there is no chance of accessing the internet after BT, so traffic in AM will not work?
  • #8 17635826
    Edgars Adamsons
    Hi I buy Blow avh-9880! but i dont have in compect a maps on sd card! where can i download it?
  • #10 17641593
    Edgars Adamsons
    tnx man!!! Its helps :D
  • #11 17695783
    hałuś
    Rate: 33
    Hello, is there any specific instruction how to upload a free navigator to blow 9880 This video shows a different blow or download torch loptop is connected to the radio with a cable and the card is inserted into the radio or laptop. I am asking for directions
  • #12 18144914
    zbigmen
    Rate: 47
    I bought this radio recently for the B6 belt and AM navigation works flawlessly. You need to provide the correct path of the exe file. If GPS is slow give higher reading speed e.g. 19200bps or higher in GPS settings. Other radio functions also work OK.
  • #13 19733428
    zwisniewski22
    hałuś wrote:
    Hello, is there any specific instruction on how to upload the free navigator to blow 9880? I am asking for tips
The discussion revolves around issues related to uploading navigation maps to the Blow AVH-9880 2 din radio. The user reports difficulties in accessing navigation after downloading maps onto a microSD card. Responses suggest ensuring the correct installation of maps, selecting the GPS option in the menu, and calibrating settings. Users also mention the importance of placing the microSD card in the correct slot and provide links for downloading maps. Some users inquire about the radio's functionality, such as listening to music while using navigation, and share experiences regarding navigation performance and settings adjustments.
TL;DR: On the Blow AVH-9880, the GPS submenu shows two icons; "Calibrate and set the path," then start navigation. Insert the microSD into the GPS slot, not the leftmost. For owners whose navigation won’t launch from microSD, this solves it. [Elektroda, hugo9, post #17439431]
Why it matters: It helps AVH-9880 users quickly fix non-launching navigation and choose legal, supported map options.
How do I load maps on a Blow AVH-9880 from microSD?
  1. Insert the microSD into the radio’s GPS slot.
  2. Open Main Menu > GPS > Settings, tap Calibrate, then Set Path to your navigation .exe on the card.
  3. Return to the GPS submenu and start the second icon to launch navigation. [Elektroda, hugo9, post #17439431]
Where can I download free, legal navigation for this radio?
Use MapFactor Navigator Free. Install it on a PC, select maps, target the microSD, then set the path on the radio. It uses OpenStreetMap data and works offline once maps are on the card. ["MapFactor Navigator Free"]
The Navigation button does nothing. What should I check first?
Open GPS > Settings and set the path to the correct navigation .exe. Calibrate the touchscreen there. Ensure the card is in the GPS slot, not the leftmost. If it still fails, the navigation image may be corrupt. [Elektroda, hugo9, post #17439431]
How do I set the correct EXE path for AutoMapa or MapFactor?
Go to GPS > Settings > Path and browse to the app’s main .exe on the microSD. As one user noted: "You need to provide the correct path of the exe file." [Elektroda, zbigmen, post #18144914]
Can I listen to music while navigation is running?
Yes. Users report playing music while navigation runs on the AVH-9880. As one tester put it: "You can listen to music." [Elektroda, Goalkeper, post #17474675]
AutoMapa refresh feels slow. How can I improve GPS responsiveness?
Increase the GPS reading speed in settings. Set it to 19200 bps or higher. This improves position updates and reduces lag during turns. [Elektroda, zbigmen, post #18144914]
Does this unit support live traffic in AutoMapa via Bluetooth tethering?
This thread offers no confirmation of Bluetooth internet for traffic services. Plan for offline navigation or confirm with your navigation vendor. [Elektroda, inwazja, post #17514490]
The YouTube guide shows a different Blow model. Is the method still valid?
Yes. The workflow is the same: prepare the microSD on a PC with MapFactor Navigator Free, insert it, then set the path on the radio. [Elektroda, rekinek12, post #17641385]
Which microSD slot should I use on the AVH-9880?
Use the dedicated GPS slot for navigation. Do not use the leftmost media slot, or the app will not launch. [Elektroda, hugo9, post #17439431]
Is AutoMapa compatible with the Blow AVH-9880?
Yes. Users reported AutoMapa working flawlessly after setting the correct .exe path. If GPS feels slow, raise the reading speed. [Elektroda, zbigmen, post #18144914]
After setting the path, nothing happens. Could the SD files be bad?
Yes. A damaged or incorrect navigation image can block launching. Reinstall clean files to the microSD and reset the path. [Elektroda, hugo9, post #17439431]
How do I install MapFactor Navigator Free onto the SD card for this radio?
  1. On your PC, install MapFactor Navigator Free and choose your country maps.
  2. Select the microSD as the install target and complete installation.
  3. Put the card in the GPS slot and set the path to Navigator’s .exe. ["MapFactor Navigator Free"]
Is using a 1:1 cloned or “pirate” SD card a good idea?
No. Use legal installers and set the path properly. A forum reply distinguishes proper installation from "a 'pirate'" 1:1 copy, which is discouraged and unreliable. [Elektroda, marek216, post #17390227]
How do I calibrate the touchscreen for GPS use?
Open Main Menu > GPS > Settings and tap Calibrate. Perform calibration, then set the navigation path before launching. [Elektroda, hugo9, post #17439431]
My map orientation updates only after a turn and some distance. Normal?
One tester noted orientation snapping after turns, only updating after "a few dozen meters." That indicates slower UI refresh with some setups. [Elektroda, Goalkeper, post #17474675]
