BOSCH AL2215CV Battery Charger Diagram: PCB2005 REV1, 1607502155-B, 18V/1.5Ah
ojciec10 26967 4
  • #1 15859564
    ojciec10
    Rate: 113
    I am looking for a diagram of a battery charger for a BOSCH Al2215CV screwdriver.
    The printed circuit board has a description of PCB2005 REV1. Below the PCB is the designation 1607502155-B.
    The charger is designed for 18V / 1.5 Ah batteries.
  • #3 15859662
    ojciec10
    Rate: 113
    The primary page is similar. I am more interested in the secondary side.
    • BOSCH AL2215CV Battery Charger Diagram: PCB2005 REV1, 1607502155-B, 18V/1.5Ah post-14197-0-88691800-1450809791.jpg (137.86 KB) You must be logged in to download this attachment.
  • Inverter remains inactive after replacing burnt components
    #4 15873259
    ojciec10
    Rate: 113
    Unfortunately, the schematic is missing. R4, R5, R6, the keying transistor F3NK80Z converters, diodes in the rectifier bridge and the V8 diode were burnt in the charger. Despite the replacement of components, the charger still does not work. Does anyone have any suggestions why the inverter does not start? After disconnecting the secondary taps of the transformer and loading it with a small bulb, the voltage on the secondary side does not appear. What is the working principle of the charger inverter?
    Should the top contacts of the battery and the bottom contacts of the battery have the same potentials? (are they duplicated). After connecting the meter to the charging contacts - no voltage. The screwdriver works normally on the upper contacts.
    The integrated circuit is mounted on the secondary side of the inverter:
    075022221
    7B416277
    V6 G4 PHL
    What's with the layout? There is no information on google
    In addition, the following system works on the secondary side:
    LM324AN
  • #5 18856590
    mąci
    Rate: 90
    Are the resistor values really correct?
    According to me:
    R4 - 39 k?
    R5- 2.9 ? or 3.9 ? (I don't know if the first strip is red or brown)
    R6 - 20 ?
