Should I replace a car tyre immediately if it has a sidewall bulge, or is it still safe to drive on?
Replace the tyre immediately and do not drive the car until it has been changed [#15859841][#15859898] A bulge means the tyre structure has been damaged, the cords/wires have cracked, and the air pressure is pushing out a weak spot, so the tyre is disqualified for use [#15859841][#15859898] The same replies also note that this tyre has virtually no tread left, so if the other tyres are in similar condition they should be replaced too [#15859898] One reply says the front axle tyres should be replaced immediately, while the rear tyre shown may still have legal tread but already shows ageing and should be checked by a tyre shop/vulcaniser [#15860072][#15859908]
  • #1 15859835
    damian8063
    Rate: 8
    Good afternoon, I have recently noticed that I have a bulge on one tyre at the front of my car (Mazda 323F BA) as shown in the photo. Should I replace this tyre immediately or is there nothing to panic about?
    • Bulge on a car tyre 20160809_142400.jpg (1.54 MB) You must be logged in to download this attachment.
  • #2 15859841
    boysmen1991
    Replace immediately.
    As you can see, the tyre is not of the first youth. The wires have cracked and the air pressure in the tyre has made a bulge. The tyre is weak at this point and for your own safety and the safety of others it is best to replace it immediately. Driving with a tyre like this causes vibrations which are transferred to the suspension and driving comfort.
  • #3 15859851
    płetwa
    Help: 165
    Rate: 551
    This tyre, even without the bulge, could only be disposed of, replaced immediately!
    What kind of diagnostician allowed this car to be driven!
  • #4 15859883
    damian8063
    Rate: 8
    płetwa wrote:
    This tyre and without this bulge was only suitable for disposal, immediate replacement!
    What kind of diagnostician allowed this car to run !
    As I wrote I only saw it about 2 days ago. Before that I doubt that it would have been there already, because I would have noticed when washing the rims for example. Does the tyre really look that bad?
  • #5 15859888
    freebsd
    Help: 766
    Rate: 2033
    If the rest of the tyres are of the same vintage then you have all four to replace. How did this car pass the inspection? Also check the spare wheel.
  • #6 15859890
    andrzej20001
    Help: 1578
    Rate: 6669
    Tyre dump.
  • #7 15859898
    freebsd
    Help: 766
    Rate: 2033
    damian8063 wrote:
    Does this tyre really look that bad?
    Damian, take very seriously the need for immediate replacement of this tyre. Do not operate the vehicle until it has been replaced. The bulge disqualifies this tyre immediately(!), but there is another problem. There is virtually no tread on this tyre. If the others are in the same condition, you need to replace them too.
  • #8 15859904
    damian8063
    Rate: 8
    I am attaching a photo of the rear ones, I think they are in better condition than the front ones. Is it enough for me to replace the 2 at the front or are the ones at the rear also to be replaced?
    • Bulge on a car tyre 20160810_113238.jpg (519.02 KB) You must be logged in to download this attachment.
  • #9 15859908
    freebsd
    Help: 766
    Rate: 2033
    damian8063 wrote:
    that they are in better condition than those at the front.
    They are in better condition. The best thing you can do is drive up to a vulcanising shop, let them have a look, give their opinion. They will check the exact depth of the tread, for example.
  • #10 15859910
    damian8063
    Rate: 8
    I will replace the front ones for sure, post above I added a picture of the rear one. I think they are in better shape. Please feel free to evaluate.
  • #11 15859919
  • #12 15859973
    andrzej20001
    Help: 1578
    Rate: 6669
    Have you seen the president in a 4 ton. car ? How was the gunshot he had ? The tyre is your and others safety on the road.
  • #13 15860042
  • #14 15860072
    Waldemar z Kaszub
    Help: 111
    Rate: 469
    damian8063 wrote:
    Is it enough if I replace the 2 at the front or do the ones at the rear also need to be replaced?
    Tyres from the front axle absolutely to be replaced immediately. The tyre in the photo from the rear axle still has tread that is within the prescribed height. However, it shows significant signs of rubber ageing. These tyres certainly bear the year/week of manufacture markings. So think about replacing them in the near future too. If the car is already "old" and you do not intend to use it for a long time, go to the vulcanisers and ask for used ones in good condition. It's always cheaper and they will replace them straight away.
  • #15 15860080
    freebsd
    Help: 766
    Rate: 2033
    I urge you to buy new tyres. You can now buy good tyres at very decent prices.
  • #16 15860317
A user reported a bulge on the front tyre of their Mazda 323F BA and inquired about the urgency of replacement. Responses overwhelmingly advised immediate replacement due to safety concerns, as the bulge indicates structural weakness and potential failure. Several contributors noted that the tyre's age and condition, including tread depth and signs of rubber aging, necessitate replacing all tyres if they are similarly worn. Recommendations included consulting a vulcanising shop for a thorough inspection and considering the purchase of new or quality used tyres, especially if the vehicle is older.
