Peugeot 308 - P1351 Error: Preheating & Holding Relay Circuit - No Disturbing Signals Detected
rastafaragoth 66954 3
  • Asks whether asymptomatic P1351 preheating fault requires repair
    #1 15869021
    rastafaragoth
    Rate: 11
    Hello, I connected my 308 to the computer and the P1351 error appeared Circuit of the preheating and holding relay. I do not feel any disturbing signals, the car fires normally and does not lose power. I connected it because of the radiator fan speed 2 when the air-conditioning was started, but there was only this error. On the forum I read that usually with this error there is a problem with firing and smoke from the exhaust. I don't have anything like that. Should something be done about it? Should the subject be left until specific symptoms appear? Regards
  • #2 15869126
  • #3 15869137
    ociz
    Help: 1379
    Rate: 3486
    General error regarding glow plug heating. It may even be one candle out of order. The longer you ride with one, the greater the chance that it will break when you try to unscrew it.
  • #4 16582614
    rastafaragoth
    Rate: 11
    Generally, it turned out to be a problem with the glow plug, but as it is only 1, I did not replace it and it runs without problems also in winter.
