Connecting DVI-D Cable to DVI-I Socket on Graphics Card for Asus VG248QE Monitor 144Hz
sdernax 11691 4
  • #1 15874308
    sdernax
    Hello, could I connect the DVI-D cable to the DVI-I socket on the graphics card? because I am going to buy an asus VG248QE monitor and I want to get 144hz and it is possible via DVI and DP
  • DVI-I accepts DVI-D digital signals across manufacturers
    #4 15874335
    Piotr2608
    Help: 851
    Rate: 4487
    It does not matter what manufacturer the card is made of. The DVI-I and DVD-D standards are the same for everyone :)
    The DVI-D connector on the graphics card carries only digital signals, while the DVI-I connector carries both digital and analog signals. It can send a digital signal (to digital displays such as flat panel LCD monitors) and an analog signal (to older monitors such as CTR) using a DVI to VGA adapter. A graphics card with a DVI-I connector has more pins than a DVI-D connector. Additional pins on the DVI-I connector carry an analog signal that the DVI-D connector does not have
    ZimTech Piotr Zimny
  • #5 15874359
    Robert B
    Help: 2027
    Rate: 1412
    The DVI-I socket outputs digital and analog signals. If the TV is to operate on a digital signal, you can connect it with a DVI-D cable.
