Benq XL2411Z - Monitor does not show 144hz after changing cable
dabek11 23454 14
Can I get 144 Hz on a BenQ XL2411Z from a Radeon RX Vega 64 by using a DVI-D↔DP adapter or a DP-to-DVI-D cable, or will the adapter limit the refresh rate?
No: this monitor reaches 144 Hz only through DVI-D Dual Link, so HDMI will stay at 60 Hz and a passive DVI-D↔DP adapter or simple cable will not be enough [#17328654][#17328644] The forum answer recommends a DVI-D Dual Link cable and notes that the manual explicitly says to check that the DVI-D Dual Link cable is connected, the GPU supports 144 Hz, and the game supports 144 Hz [#17328654] If you want to use the Vega 64’s DisplayPort output, you need an active DP-to-DVI-D Dual Link converter, not a passive adapter [#17328720][#17328644] Even then, results are mixed: one user found a branded Dell BizLink active adapter that exposed 120/144 Hz, but it also caused flickering/black screens and later artifacts at 144 Hz [#18219609]
  • #1 17328380
    dabek11
    Hello, I have a problem of this type that I bought a new card, namely the Radeon RX Vega 64 and it has only HDMI and Display port. I also have a BenQ XL2411Z 144hz monitor, but the only connectors it has are DVI-D and HDMI, although by connecting it to the HDMI input, I can only view the image at 60hz and here is my question. If I buy a DVI-D to DP adapter, will I be able to reach 144hz again or the adapter may be a limiter? What will the situation look like if I buy a DP -> DVI-D cable? I am open to any suggestions.
  • #2 17328596
    kk.2000
    Help: 91
    Rate: 90
    My friend,
    1.Start by using an HDMI cable, due to the lack of (expensive) adapters and a higher color depth than DVI.
    2.What type of DVI-D socket do you have built-in? Is it DVI-D DL or SL? This is a big difference in the standard - also in the transfer frequency.
    3. I understand that you have set your graphics driver to display frequencies not supported by the monitor, or the monitor drivers are loaded to Win 10?
  • #3 17328644
    mahoney92
    Buddy, if you want to get 144hz without problems, it's just changing the monitor to one with DP. Adapters are worth nothing, you would have to have active ones, 1 are expensive and 2 are frequency issues, sometimes you can reach 120hz. Of course I am talking about dp to dvi-d dual link.
  • #4 17328654
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Higher color depth? :) Has a colleague read the specification of both standards? :) DVI-D to HDMI vias are not too expensive. In fact, you do not even need vias, you can buy the cable itself, no electronics is needed in this case.
    There is a Dual Link in this monitor of course, as this monitor supports 144Hz only via the DVI socket. It will not support 144Hz via HDMI and it is even described in the equipment manual (it's strange that the author did not look at it - although who would want to rummage in this unnecessary waste paper) :)
    No additional drivers are required for 144Hz support, system PnP is sufficient.
    Excerpt from the manual:
    If 144 Hz is not available in your menus, check the following:
    o make sure the DVI-D Dual Link cable is properly connected to your computer and the monitor
    o make sure your GPU supports 144 Hz
    o make sure your game supports 144 Hz.
    I would start by buying a cable HDMI DVI DUAL LINK - after entering such a phrase on Allegro, there are several to choose from. HDMI version 1.3 / 1.4 can theoretically handle 1920x1080 / 144Hz. The cheapest cables for a fifth fall out and these dual link costs somewhere between PLN 20-30. Three-digit cables are not needed, an honest dual link cable should theoretically be enough.
  • #5 17328688
    mahoney92
    Theoretically, you won't get 144hz on this transition. DVI-D DL MA 25 pin and 5 dates and HDMI 19 and 4 dates. There must be all 5 for DVI to reach 144HZ. I did the same thing at home, I ended up changing monitors.
  • #6 17328720
    dt1
    Help: 7315
    Rate: 8292
    Here you are right (HDMI has three TMDS channels by spec). It would be possible to look for a DP to DVI-D converter that would fully handle 1920x1080 / 144Hz.
  • #7 17328724
    kk.2000
    Help: 91
    Rate: 90
    Yes, buddy, he read the specification and it shows that DVI has a color space only RGB and HDMI also YCbCr 4: 4: 4.
    dt1 wrote:
    (it's strange that the author did not look into it - although who would want to rummage in this unnecessary waste paper) :)
    If the author had looked, he would not have asked the question ... ;-)
    We know the theory, but in practice we are dealing with Winzgroza 10!
    Yes, I am not saying that there is a problem here, but it is worth telling a colleague where to look for problems, or - this is the case - simply raise the topic without an answer.
    And with these "cables" it is a great lottery. I've already tested a few and the seller's theories are only half the same as the pest's practice. You are right that you can try - which I didn't think of.
    And with these "cables" it is a great lottery. I've already tested a few and the seller's theories are only half the same as the pest's practice. You are right that you can try - which I didn't think of. Having my experience, I would not try to look for an adapter with the FHD * 144Hz declaration. It's cheaper than replacing the monitor.
  • #8 17328796
    mahoney92
    Not even adapters, but an active converter. It all depends on the author, whether he wants to spend senseless money on shipping cables, returns, etc., or he just prefers to bet on a 100% reliable solution that will definitely work, i.e. changing the monitor. I know from my own experience that none of the converters work as we would expect, I had several and none of them reached 144, and it was hard by 120.
  • #9 17328908
    dt1
    Help: 7315
    Rate: 8292
    But YCbCr 4: 4: 4 and 4: 2: 2, which can achieve 12 or 16 bit depths, are not used in PC graphics cards, and 10 bit depths handle both standards equally well. PC graphics cards typically use 8bit / channel, some cards may use 10bit. For AMD cards:
    AMD's 10-bit Display Support
    AMD's most recent series of workstation graphics cards give full support to various types of 10-bit displays including all of the models mentioned above. The communication interface can currently be single link DVI, dual link DVI, and DisplayPort depending on the input / output ports configuration of the monitor and the graphics card.
    HDMI hasn't even been mentioned, so I'm not sure if it's possible to get more than the standard 8bit / channel with HDMI (but that would be a limitation on the graphics card, not the standard).
    Anyway, it does not matter much, because the matrices in cheap consumer monitors will not be able to display differences greater than 8 bit / channel, and usually even 6bit / channel. Therefore, I was wondering which specifications my colleague was reading - only standards (which in the case of PCs support both 10 bit), matrices or graphics processors, because each of these elements will introduce a different limit ;)
    It is a pity that the author chose a 144Hz monitor without Display Port - in my opinion this is a mistake, but the purchase has already been made. HDMI itself in the graphics card is version 2.0, so it would support 144Hz, but apparently in the monitor it is already a standard version below 1.3, because in principle from version 1.3 it was possible to theoretically support 1080p / 144Hz.
  • #10 17329013
    kk.2000
    Help: 91
    Rate: 90
    dt1 wrote:
    But YCbCr 4: 4: 4 and 4: 2: 2, which can be 12 or 16 bits deep, are not used on PC graphics cards ...
    It's interesting what you write, because I'm using 4: 4: 4.
    This is due to the best gradation of shades that I am allergic to when viewing photos.
    The colleague did not write that this was his last monitor in his life, so before he changed it, I recommended him to find a solution via HDMI, clearly justifying my suggestion. I myself use the highest possible color depth, because maybe the LED matrix itself cannot reproduce too much, but the processing electronics probably can, since I can see the difference.
    This is the last post to defend my suggestion ;-)
    PS. dt1: your comments are very valuable! I appreciate the electrode for a large number of professionals in the subject.
  • #11 17329133
    dabek11
    When it comes to HDMI cables, I have already tried different variants. When it comes to people who recommend buying a new monitor, I would like to note that on average I am smiling to change the monitor for PLN 1400 for a new one and I would really care more about some other cheaper solution =)
  • #12 17329142
    dt1
    Help: 7315
    Rate: 8292
    This is what the discussion forum is all about - to exchange views without insults at the same time :) I am also eager to learn something new all the time.
    For my part, it was a simplification - this format is not the most commonly used, because there is usually no need to do so, taking into account that LCD matrices typically use 6, sometimes 8-bit depth of the displayed image. I have encountered 10 bit in some medical and professional monitors only, so the 4: 4: 4 compression in theory should not have any advantage over the other formats that offer the depth that allows you to take full advantage of the possibilities used in the matrix monitor (it is known that sending information about the image in the format distinguishing between 16 bits on each component makes little sense if the matrix is able to display 262k colors, which is 6bits / channel).
    Which does not change the fact that the viewing experience may be different, I do not know the details of the exact impact of the compression standard used on the displayed image :)
  • #13 17329170
    kk.2000
    Help: 91
    Rate: 90
    dt1 wrote:
    ... I do not know the details of the exact influence of the compression standard used on the displayed image :)
    My guess is that you wrote so.
    Apart from the fact that the matrix itself will display 8 bits, take into account that it does not display full black and full white.
    I recommend 4: 4: 4 when someone wants to enjoy their photos on the big screen. Natural photos always have some tonal transitions. In order for the gradation boundaries not to be arrogant or even visible, we need to choose the highest possible depth. Fortunately, many graphics cards can display more than RGB.
    By the way, I think that the introduction of higher depths than 8 bit - i.e. a change in the standard in HDMI - is caused not so much by the desire to increase the processing power of procks and file sizes, but by the requirements of the recipients of the format.
    I know for most people there is no difference between a 128kbs MP3 and a CD, but there are also quite a few people who clearly hear the difference and most young people feel it.
  • #14 17329289
    mahoney92
    I searched the net and found an active adapter that will handle 144hz on this transition, it's called Dell BizLink. Personally, I did not have it and did not test it, but due to the fact that it is a branded adapter, it should work. After entering the first link in the search, the price is about PLN 150 plus shipping. The choice is yours.
  • #15 18219609
    wl.przemek
    Rate: 29
    It turned out that this model of the monitor is slightly "neutered" :not: and 144Hz can only be achieved by connecting DVI-D at both ends.
    Trying to deal with the problem, a friend suggested to try an "active adapter", ie DP + USB (power) ---> DVI-D and a cable on both ends with DVI-D.
    DisplayPort to DVI-D Dual Link Adapter
    Benq XL2411Z - Monitor does not show 144hz after changing cableDisplayPor...dapter.png (163.25 kB)You must be logged in to download this attachment.
    After connecting, to my surprise, the monitor options showed a higher value, i.e. 120 / 144Hz, but a strange flashing bar, a few mm on the right side of the monitor did not look good and after turning on any program a black screen appeared and blinked.
    So, not entirely convinced about the "magic" adapter :crazyeyes: , I kept looking and it turned out that the monitor drivers were missing, after installing the problem disappeared and maybe this entry will help someone :spoko:
    greetings :wink:
    ... update , because it turns out that it works stably at 120Hz and 144Hz is the native value and after some time I have artifacts on the screen ... hmm, but 2x more damage is also no yes
The discussion revolves around the issue of achieving 144Hz refresh rate on a BenQ XL2411Z monitor after the user upgraded to a Radeon RX Vega 64 graphics card, which only has HDMI and DisplayPort outputs. The monitor supports 144Hz only via DVI-D. Users suggest that using a DVI-D to DisplayPort adapter may not guarantee 144Hz due to potential limitations, and recommend using a DVI-D Dual Link cable instead. Some participants mention that active adapters could work, but experiences vary, with some reporting issues like screen artifacts. The importance of ensuring the correct monitor drivers are installed is also highlighted, as this can affect refresh rate settings.
TL;DR: 144 Hz on the BenQ XL2411Z works only via Dual‑Link DVI; “this monitor supports 144Hz only via the DVI socket.” To regain high refresh from a DP/HDMI‑only GPU, use an active DP‑to‑Dual‑Link‑DVI adapter; HDMI won’t do 144 Hz here. [Elektroda, dt1, post #17328654]
Why it matters: This helps XL2411Z owners with DP/HDMI‑only GPUs restore 120–144 Hz without wasting money.
Why did 144 Hz disappear after switching to HDMI or DP on my Vega 64?
Because XL2411Z delivers 144 Hz only via DVI‑D Dual Link. Your GPU lacks DVI, so HDMI/DP alone won’t restore it. As one expert put it, “this monitor supports 144Hz only via the DVI socket.” Use an active DP‑to‑Dual‑Link‑DVI adapter from the GPU. [Elektroda, dt1, post #17328654]
Can a simple HDMI‑to‑DVI cable unlock 144 Hz on the XL2411Z?
No. HDMI carries three TMDS channels and cannot create Dual‑Link signaling needed for 1080p at 144 Hz. Passive HDMI‑to‑DVI cables only remap pins and keep HDMI’s limits. You need an active conversion to Dual‑Link DVI to reach high refresh. [Elektroda, dt1, post #17328720]
Will a passive DP‑to‑DVI cable work for 144 Hz?
No. You must use an active DP‑to‑DVI‑D Dual Link converter. Passive adapters won’t change the signal type or bandwidth. Users commonly see only 60 Hz with passive parts, while good active units sometimes reach 120 Hz. [Elektroda, mahoney92, post #17328644]
Which active adapter is reported to work for 1080p 144 Hz?
A Dell/BizLink DP‑to‑DVI‑D Dual Link active adapter has been reported as suitable. It’s a powered adapter designed for Dual‑Link DVI. Expect a typical street price around PLN 150 plus shipping. Availability varies by region and seller. [Elektroda, mahoney92, post #17329289]
My active adapter shows flicker, a side bar, or black screen. How can I fix this?
Install the official BenQ XL2411Z monitor driver so Windows reads a correct EDID. One user eliminated flicker and black screens that way. Their system then ran stably at 120 Hz. However, 144 Hz still produced artifacts over time on that setup. [Elektroda, wl.przemek, post #18219609]
How do I enable 120–144 Hz on Windows after connecting the adapter?
  1. Connect a powered DP‑to‑DVI‑D Dual Link active adapter and a genuine Dual‑Link DVI‑D cable.
  2. Install the BenQ XL2411Z monitor driver, then reboot.
  3. In Windows or AMD Radeon Settings, select 120 or 144 Hz for 1920×1080. [Elektroda, wl.przemek, post #18219609]
Do I need special drivers for 144 Hz on this monitor?
Windows PnP often works, but missing monitor drivers can cause odd behavior. Install the BenQ XL2411Z driver if 144 Hz is missing or unstable. One report showed flicker disappeared and 120 Hz became stable after installing the driver. [Elektroda, wl.przemek, post #18219609]
Is HDMI 2.0 from my Vega 64 enough for 144 Hz on the XL2411Z?
The GPU’s HDMI 2.0 can output high refresh, but this monitor’s HDMI implementation blocks 144 Hz. The model’s design ties 144 Hz to Dual‑Link DVI only. Therefore, HDMI from the Vega 64 won’t deliver 144 Hz to this panel. [Elektroda, dt1, post #17328908]
What refresh rate can I expect if 144 Hz keeps failing?
Plan on 120 Hz as a stable fallback when using an active DP‑to‑Dual‑Link‑DVI adapter. One user reported stable 120 Hz and recurring artifacts at 144 Hz over time. This outcome is a realistic ceiling with certain adapters and systems. [Elektroda, wl.przemek, post #18219609]
Do Dual‑Link DVI cable quality and labeling matter?
Yes. Users report a lottery with so‑called Dual‑Link cables. Some labeled cables fail to sustain the required bandwidth at 144 Hz. Buy from reputable sources, and be ready to exchange if performance is unstable. [Elektroda, kk.2000, post #17328724]
Could forcing unsupported refresh rates in drivers cause issues?
Yes. Ensure your GPU isn’t set to a frequency the monitor doesn’t support on the chosen input. Also verify that proper monitor IDs or drivers load in Windows. These checks can prevent blank screens or instability. [Elektroda, kk.2000, post #17328596]
Will a DVI‑D to DisplayPort adapter help instead?
No. You need DisplayPort output converted to Dual‑Link DVI input, not the reversed direction. Look specifically for a DP‑to‑DVI‑D Dual Link active converter. That path has been confirmed as viable for this monitor. [Elektroda, dt1, post #17328720]
Is there any benefit to HDMI over DVI for color formats here?
On PCs, the panel bit‑depth and pipeline limit real gains on this monitor. Workstation cards and specific interfaces support 10‑bit, but consumer use is usually 8‑bit. Prioritize stable high refresh over color format tweaks in this case. [Elektroda, dt1, post #17328908]
Should I just replace the monitor with a DisplayPort model?
It’s the most reliable route if you demand guaranteed 144 Hz. Active converters vary by unit; several users topped out near 120 Hz. A monitor with native DisplayPort removes adapter uncertainty and potential artifacts. [Elektroda, mahoney92, post #17328644]
