Connecting Samsung SyncMaster 931bw Monitor to MSI GTX 660 Gaming via VGA-DVI-D Adapter
mati98151 8892 16
Can I connect a Samsung SyncMaster 931BW monitor to an MSI GTX 660 Gaming with a DVI-D dual-link port using an adapter?
Use a DVI cable instead of a VGA-to-DVI-D adapter, because DVI-D carries only digital video while VGA is analog, so a passive adapter will not work [#16810137][#16810275] The thread notes that the Samsung SyncMaster 931BW has a DVI input, so the simplest solution is to connect it directly with a DVI-D cable [#16810275][#16810513][#16810572] Several replies say adapters are unnecessary and that a DVI cable is cheap and easy to buy [#16812288] If you insist on using the VGA input, you would need a proper converter rather than just a simple adapter, but the recommended route is direct DVI connection [#16812288]
  • #1 16810127
    mati98151
    Rate: 8
    Hello. Goes to connect the monitor with vga input to graphics cards with dvi D dual link input using an adapter.
    The graphics card is msi gtx 660 gaming rated Monitor Samsung SyncMaster 931bw Connecting Samsung SyncMaster 931bw Monitor to MSI GTX 660 Gaming via VGA-DVI-D Adapter
  • #2 16810137
    daminek1234
    Help: 61
    Rate: 88
    I doubt it. Dvi-d only gives a digital signal, while VGA transmits analog.
  • #4 16810513
    mati98151
    Rate: 8
    So it's best to buy a dvi d cable
  • #5 16810572
    daminek1234
    Help: 61
    Rate: 88
    Yes. Why combine? Is the entrance? Is. Does this match on the card? Yes. Just make sure it is a dvi-d cable.
  • #6 16811801
    mati98151
    Rate: 8
    I have a problem with getting such a cable. Behind is a displayport cable for dvi d. The graphics card has a displayport port, and the dvi monitor has d. Would it work?
  • #7 16812191
    Kasek21
    Help: 4981
    Rate: 3547
    mati98151 wrote:
    Would it work?
    It should be like that.
    What could be the problem with buying a DVI cable?
    What difference does it buy DVI-I, after all, it has only additional pins.
  • #8 16812217
    daminek1234
    Help: 61
    Rate: 88
    It won't connect unless it breaks the pins.
  • #9 16812238
    Kasek21
    Help: 4981
    Rate: 3547
    Why not connect? The card and the monitor have DVI-I and there is no problem.
  • #10 16812241
    daminek1234
    Help: 61
    Rate: 88
    The DVI-I to DVI-D cable will not connect, because where will the additional pins come in?
    The DVI-D cable for the DVI-I input is already connected.
  • #11 16812262
    Kasek21
    Help: 4981
    Rate: 3547
    PS. The cable costs a few to several zlotys and is available EVERYWHERE!
  • #12 16812272
    daminek1234
    Help: 61
    Rate: 88
    mati98151 wrote:
    connect the monitor with vga input to graphics cards with dvi D input
    I return honor, I suggested the first post.
  • DVI-I supports analog and digital signals
    #13 16812288
    Kasek21
    Help: 4981
    Rate: 3547
    Don't pay anything because you would have to salute.
    DVI-I connector - can send both digital and analog signals.
    The card and the monitor have DVI-I connectors so no matter what cable it purchases, it will work.
    To conclude: Adapters are not needed (unnecessary cost) - go to the store or buy a DVI cable on the allegro.
    Of course, you can use the DVI-> D-Sub adapter and connect the card with the monitor with a D-Sub cable - but it is always an analog image so in principle it is worse than digital, although with this monitor and using a good D-Sub cable you will not feel the difference.
  • #14 16812505
    mati98151
    Rate: 8
    I have already used the Dvi I and HDMI connectors on the card. The problem is getting a dvi d to dvi d cable. The seller recommended a displayport to dvi d cable.
  • #15 16813042
    Kasek21
    Help: 4981
    Rate: 3547
    You haven't written about several monitors.
    Of course, this choice may be the best because either both DVI sockets or one of them + HDMI work interchangeably.
    For Eyefinity ie 3 monitors there is usually DVI + HDMI + DP.
  • #16 16814900
    mati98151
    Rate: 8
    It would work such a combination of displayport cable for hdmi and then adapter with hdmi to dvi d. I ask because ordering dvi d cable for dvi seems to make no sense to me, due to the future the displayport cable for hdmi can always be useful someday.
  • #17 16814983
    Kasek21
    Help: 4981
    Rate: 3547
    mati98151 wrote:
    This connection would work with a displayport cable for hdmi and then an adapter with hdmi to dvi d.
    Nobody will answer you until you check it yourself.
The discussion revolves around connecting a Samsung SyncMaster 931bw monitor, which has a VGA input, to an MSI GTX 660 Gaming graphics card that features a DVI-D dual link output. Users express skepticism about using a VGA-DVI-D adapter due to the difference in signal types (analog vs. digital). It is suggested that a direct DVI-D cable is the best solution, as both the monitor and graphics card have DVI-I connectors, which can transmit both digital and analog signals. Some participants mention the possibility of using a DisplayPort to DVI-D cable, but emphasize that a DVI-D to DVI-D cable is preferable for optimal performance. The conversation highlights the importance of ensuring compatibility between the connectors and the types of signals being transmitted.
TL;DR: Use 1 direct DVI cable to link the MSI GTX 660 to the Samsung 931BW; “Adapters are not needed.” [Elektroda, Kasek21, post #16812288]
Why it matters: This FAQ helps PC builders connect a VGA-era monitor to a GTX 660 without image loss, confusion, or wasted adapters.
Can I connect a VGA‑only monitor to a DVI‑D port with a cheap adapter?
No. DVI‑D outputs only digital video, while VGA needs analog. A passive adapter cannot convert formats. You would need an active converter, which adds cost and complexity. “DVI‑D only gives a digital signal.” [Elektroda, daminek1234, post #16810137]
Does the Samsung SyncMaster 931BW actually have DVI?
Yes. The 931BW includes a DVI input and supports 1440×900 native resolution. Use a DVI cable from the GPU for the sharpest image. This avoids analog signal loss and simplifies setup. ["Samsung SyncMaster 931BW specs"]
What’s the simplest working cable for GTX 660 → 931BW?
Use a direct DVI cable between the card and the monitor. “Adapters are not needed.” This gives a clean digital path and avoids compatibility issues. [Elektroda, Kasek21, post #16812288]
Should it be DVI‑D or DVI‑I cable?
Either will physically work if the connectors match; the link used is digital. The key is that the GPU and monitor DVI ports align. If the socket is DVI‑D, use a DVI‑D cable for a guaranteed fit. [Elektroda, Kasek21, post #16812241]
Will DisplayPort to DVI‑D work from the GTX 660?
Yes, a DP→DVI‑D cable can work because the card supports digital output over DP. This is handy if your DVI ports are occupied, as noted by the forum guidance. [Elektroda, Kasek21, post #16812191]
Can I chain adapters (DP→HDMI, then HDMI→DVI‑D)?
Chaining may work, but failures are common. Signal integrity and handshake issues can appear. The forum could not confirm such a chain and advised testing. “Nobody will answer you until you check it yourself.” [Elektroda, Kasek21, post #16814983]
Is VGA (D‑Sub) acceptable if I already have that cable?
You can use DVI→VGA with the right hardware, but it yields an analog image. The expert noted digital is preferable, though differences may be small on this monitor with a good cable. [Elektroda, Kasek21, post #16812288]
Quick how‑to: connect GTX 660 to 931BW the right way
  1. Power off PC and monitor.
  2. Plug a DVI cable from the GTX 660’s DVI port to the 931BW’s DVI input.
  3. Power on and set the monitor to DVI input; select 1440×900 in Windows. [Elektroda, Kasek21, post #16812288]
What if both my DVI and HDMI ports are already in use?
Use the GTX 660’s DisplayPort with a DP→DVI‑D cable to the 931BW. This avoids reconfiguring other displays and keeps a digital path. [Elektroda, Kasek21, post #16813042]
Why didn’t my DVI‑I to DVI‑D cable physically fit?
A DVI‑I plug has extra analog pins that a DVI‑D socket lacks. The reverse—DVI‑D cable into DVI‑I socket—fits fine. Match plug to socket type to ensure insertion. [Elektroda, daminek1234, post #16812241]
Do I need an active converter for this setup?
No active converter is needed when connecting DVI or DP to the 931BW’s DVI input. Active conversion is only for digital‑to‑analog (DVI‑D/DP to VGA). [Elektroda, Kasek21, post #16812288]
What resolution should I set after connecting?
Set 1440×900 at the monitor’s native 16:10 aspect ratio. This ensures pixel‑perfect scaling and clear text. It’s the panel’s native mode. ["Samsung SyncMaster 931BW specs"]
Is a DVI cable expensive or hard to find?
No. The forum notes DVI cables are cheap and available “EVERYWHERE,” costing only a few to several zlotys. Availability is broad online and in stores. [Elektroda, Kasek21, post #16812262]
Edge case: Why does my screen stay black over DP→DVI?
Some adapters need power or have handshake quirks. Try another DP port, reseat connections, or use a single DP→DVI cable. If chained, remove the chain first. [Elektroda, Kasek21, post #16814983]
What’s DVI‑D vs DVI‑I in plain terms?
DVI‑D carries digital signals only. DVI‑I can carry digital and analog in one connector. For the 931BW, use the digital path for best clarity. [Elektroda, Kasek21, post #16812288]
Will image quality differ between DVI and VGA on this monitor?
Digital DVI avoids analog noise and drift. The forum notes VGA can look close if you use a good cable, but DVI is the clean choice. [Elektroda, Kasek21, post #16812288]
